Source for brake backing plates ??? #3148696
06/04/23 08:28 PM
06/04/23 08:28 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Anyone reproducing brake backing plates for 8-3/4's or Dana's ??
Re: Source for brake backing plates ??? [Re: Stanton] #3148723
06/04/23 10:03 PM
06/04/23 10:03 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Doc Diff used to sell the entire setup, might ask him.
https://www.doctordiff.com/mopar-drum-brake-assembly.html
Re: Source for brake backing plates ??? [Re: Sniper] #3148733
06/04/23 11:32 PM
06/04/23 11:32 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I haven't seen any repros out there. I had been looking for a decent pair of 11x2.5 plates for awhile.
I got lucky and found a newer pair of NOS ones off ebay about 5 months ago.
Re: Source for brake backing plates ??? [Re: skdmark] #3148735
06/04/23 11:54 PM
06/04/23 11:54 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Are the backing plates 8 3/4 specific? I've been tripping over a set I pulled off a '77 9 1/4 rear months ago.
John
Re: Source for brake backing plates ??? [Re: SattyNoCar] #3148740
06/05/23 01:31 AM
06/05/23 01:31 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
That's what I get them from, Dodge vans with 9-1/4". If I remember, they have four bolts, but the plates have five holes.
Re: Source for brake backing plates ??? [Re: 375inStroke] #3148778
06/05/23 08:40 AM
06/05/23 08:40 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Reading some other posts (some quite old) it seems ALL Mopar diffs can use the same backing plates - 8-1/4, 8-3/4, 9-1/4, 9-3/4 - all interchangeable. HOWEVER, the plates will differ (obviously) between 10" and 11". Not so obviously they also differ depending on the shoe width - a wider shoe will need a plate with more offset from the mounting flange - and this will not be as visibly noticeable as the diameter!
Dr Diff currently (as of Friday) has no backing plates for his kits.
Worth noting is that virtually everything - EXCEPT backing plates - is available from RockAuto, etc.
Re: Source for brake backing plates ??? [Re: Stanton] #3148779
06/05/23 08:57 AM
06/05/23 08:57 AM
nowhere
nowhere
I have a set of 11" drum setup from an 88 M body on the 8 3/4 in my 65 Cuda (cut down C body axle).
Re: Source for brake backing plates ??? [Re: Sniper] #3148783
06/05/23 09:12 AM
06/05/23 09:12 AM
VA
dragon slayer Offline
VA
Are there pictures that show the difference in backing plate for the shoe width?
Re: Source for brake backing plates ??? [Re: dragon slayer] #3148822
06/05/23 11:22 AM
06/05/23 11:22 AM
BDW Offline
BDW  Offline
Re: Source for brake backing plates ??? [Re: BDW] #3148911
06/05/23 03:27 PM
06/05/23 03:27 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What magazine and issue (year/month) is that article from?
Re: Source for brake backing plates ??? [Re: Stanton] #3149025
06/05/23 11:45 PM
06/05/23 11:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
That was in mopar action sometime in the past year or so.
I want my fair share
