stuck throttle! #3148844
06/05/23 12:23 PM
06/05/23 12:23 PM
gregsdart Offline OP
I am not sure what all went down exactly. I backed the car up in the driveway so i would have a bit of room, never trusting things will go perfect . I was right! I was trying to test the airshifter , which i put on an MSD shift light circuit. i had the rpm set at 3200 so i could get it to shift and still hold the car, or if it moved, stop it. After backing up i let go of the transbrake button and the car launched like the throttle was wide open. When the transbrake is activated, an ACD throttle controller colapses to my preset launch setting. Either my foot got in the way, or the throttle stuck, and away we went! I had my foot on the brakes hard, but that is no mach for almost a 1,000 hp!. I reached over and took a swipe at my switch panel, and hit the ignition switch off. I got it stopped about ten feet from the garage and trailer! All i can say is i say a prayer every time i get in that car, and I believe I got help!!!!!
Re: stuck throttle! [Re: gregsdart] #3148861
06/05/23 01:09 PM
06/05/23 01:09 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
On a lighthearted note... at least you know how your car hooks in your drive way. confused
Glad things went for the better vs what could of been.
STOP POTATO HATE!
Re: stuck throttle! [Re: Mr PotatoHead] #3148875
06/05/23 01:40 PM
06/05/23 01:40 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Scary ride Greg. Glad it didn't do any damage.
69 GTX 68 Road Runner
Re: stuck throttle! [Re: gregsdart] #3148881
06/05/23 01:41 PM
06/05/23 01:41 PM
I went through a fence at work years ago when my throttle stuck at WOT showing off entering the yard when no one could see me, that was in my old 415 HP M.W. 1963 Plymouth Belvedere, I had removed the throttle spring return bracket of the left front carb the day before and of course it swung under the throttle linkage on the carb hanging it wide open when I let off the throttle, I reach down after going through the fence and manage to turn the ignition switch off while doing donuts in the dirt field next door whiney
Murphy loves messing with us , HUH rant puke shruggy
I forgot to mention that the left rear wheel cylinder failed while I was on the brakes trying to stop it, it blew the piston out of the cylinder bore and away it went again going through the fence shock puke whiney I had to call my wife after work to come pick me and the car up with my old car hauler truck wrench The car still had the original rear end in it with the tapered axles with left hand lug nuts on the driver's side, what a pain it was getting the brake drum off the axle rant shruggy
What is the old saying, the bad things that happen to us that don't kill only make us stronger, I never wanted to be Superman whistling grin
Re: stuck throttle! [Re: Cab_Burge] #3148889
06/05/23 02:18 PM
06/05/23 02:18 PM
moparx Offline
moparx  Offline
eek that could have gone WAY bad in a hurry !
your Guardian Angle earned his or her wings certification for sure !!! nervous
beer
Re: stuck throttle! [Re: moparx] #3148893
06/05/23 02:39 PM
06/05/23 02:39 PM
an8sec70cuda Offline
Wow, that could have been way worse! Glad you got it shut down and didn't tear up anything!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: stuck throttle! [Re: an8sec70cuda] #3148900
06/05/23 02:53 PM
06/05/23 02:53 PM
The marks show the front wheels never turned a lick! and the slope actually steered the car away from that big pine on the left! Kinda like it threaded a needle! Future tests will be on jackstands, with enough room for tire growth!
Re: stuck throttle! [Re: gregsdart] #3148901
06/05/23 02:58 PM
06/05/23 02:58 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
You know, they make a msd ignition tester that will allow you to test all rpm "stuff" without starting the car.
Without Data, you’re just another guy with an opinion.
Re: stuck throttle! [Re: gregsdart] #3148909
06/05/23 03:24 PM
06/05/23 03:24 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Good thing you didn't clean up all those maple seeds. It might of launched harder. drive
Re: stuck throttle! [Re: GomangoCuda] #3148922
06/05/23 03:45 PM
06/05/23 03:45 PM
yes!
Re: stuck throttle! [Re: sr4440] #3148923
06/05/23 03:46 PM
06/05/23 03:46 PM
MSD tech said no! So please, who do i talk to to get a tester?
Re: stuck throttle! [Re: gregsdart] #3148932
06/05/23 04:09 PM
06/05/23 04:09 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I had one but, sold mine ..
work great
https://www.jegs.com/i/MSD-Ignition/121/8998/10002/-1
runs car thru complete sequence shifter click thru gears like a ghost is driving
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: stuck throttle! [Re: bigdad] #3148933
06/05/23 04:15 PM
06/05/23 04:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes they sell one and the newer version even allow you to simulate an entire run. It also is the only one that works with a grid, and its cheaper. Now figure out why the throttle hung open, get a tester as it can save you time, fuel and issuse and get to the track before it freezes again smile
You want this one...
https://proshop.summitracing.com/parts/msd-89981
Re: stuck throttle! [Re: Al_Alguire] #3148951
06/05/23 04:59 PM
06/05/23 04:59 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
A local guy made a pass with his air cleaner removed, but he left the seal ring between the air cleaner and carb. At speed the engine sucked that gasket into the carb, which then stuck the throttle. He ended up going over a dirt berm like Dukes of Hazzard!
Grant
Re: stuck throttle! [Re: Al_Alguire] #3148954
06/05/23 05:08 PM
06/05/23 05:08 PM
Al, The tech at Summit read off the specs on both and only the 8998 will test the shift light pattern, which is what i need. So it is on the way At $392 I hope it covers my issue! I did test the throttle stop/ transvrake sequence several times without a hicup. No issues, and plenty of clearance around the components. So i suspect it was due to the wrong shoes and my big feet,! rest assured, this lesson will not be forgotten.
Re: stuck throttle! [Re: gregsdart] #3148963
06/05/23 05:33 PM
06/05/23 05:33 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am glad the car is unharmed I can relate after my car throttle stuck 3yrs ago and I slid sideways into mt driveway gate.
Re: stuck throttle! [Re: gregsdart] #3148970
06/05/23 06:30 PM
06/05/23 06:30 PM
tboomer Offline
tboomer  Offline
You were very lucky Greg! Wow!
Re: stuck throttle! [Re: gregsdart] #3148978
06/05/23 06:49 PM
06/05/23 06:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My 89981 works the shifter just fine triggered the same way but with a grid. The older testers will NOT work with a grid. BUt I have one of those in the trailer as well still.
Re: stuck throttle! [Re: Al_Alguire] #3149023
06/05/23 11:33 PM
06/05/23 11:33 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
Glad you got it shut off Greg.
Re: stuck throttle! [Re: gregsdart] #3149033
06/06/23 01:47 AM
06/06/23 01:47 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Glad you didn’t get hurt!
