stuck throttle!
#3148844
06/05/23 12:23 PM
06/05/23 12:23 PM
Posts: 9,983 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am not sure what all went down exactly. I backed the car up in the driveway so i would have a bit of room, never trusting things will go perfect . I was right! I was trying to test the airshifter , which i put on an MSD shift light circuit. i had the rpm set at 3200 so i could get it to shift and still hold the car, or if it moved, stop it. After backing up i let go of the transbrake button and the car launched like the throttle was wide open. When the transbrake is activated, an ACD throttle controller colapses to my preset launch setting. Either my foot got in the way, or the throttle stuck, and away we went! I had my foot on the brakes hard, but that is no mach for almost a 1,000 hp!. I reached over and took a swipe at my switch panel, and hit the ignition switch off. I got it stopped about ten feet from the garage and trailer! All i can say is i say a prayer every time i get in that car, and I believe I got help!!!!!
Re: stuck throttle!
[Re: gregsdart]
#3148861
06/05/23 01:09 PM
06/05/23 01:09 PM
Posts: 9,397 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
On a lighthearted note... at least you know how your car hooks in your drive way. Glad things went for the better vs what could of been.
STOP POTATO HATE!
Re: stuck throttle!
[Re: Mr PotatoHead]
#3148875
06/05/23 01:40 PM
06/05/23 01:40 PM
Posts: 10,019 MN
JERICOGTX
MN
Scary ride Greg. Glad it didn't do any damage.
69 GTX
68 Road Runner
Re: stuck throttle!
[Re: gregsdart]
#3148881
06/05/23 01:41 PM
06/05/23 01:41 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Re: stuck throttle!
[Re: moparx]
#3148893
06/05/23 02:39 PM
06/05/23 02:39 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Wow, that could have been way worse! Glad you got it shut down and didn't tear up anything!
Re: stuck throttle!
[Re: an8sec70cuda]
#3148900
06/05/23 02:53 PM
06/05/23 02:53 PM
gregsdart
The marks show the front wheels never turned a lick! and the slope actually steered the car away from that big pine on the left! Kinda like it threaded a needle! Future tests will be on jackstands, with enough room for tire growth!
Re: stuck throttle!
[Re: gregsdart]
#3148901
06/05/23 02:58 PM
06/05/23 02:58 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
You know, they make a msd ignition tester that will allow you to test all rpm "stuff" without starting the car.
Without Data, you’re just another guy with an opinion.
Re: stuck throttle!
[Re: gregsdart]
#3148932
06/05/23 04:09 PM
06/05/23 04:09 PM
Posts: 34,867 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
You know, they make a msd ignition tester that will allow you to test all rpm "stuff" without starting the car. MSD tech said no! So please, who do i talk to to get a tester? I had one but, sold mine .. work great https://www.jegs.com/i/MSD-Ignition/121/8998/10002/-1runs car thru complete sequence shifter click thru gears like a ghost is driving
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: stuck throttle!
[Re: bigdad]
#3148933
06/05/23 04:15 PM
06/05/23 04:15 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Yes they sell one and the newer version even allow you to simulate an entire run. It also is the only one that works with a grid, and its cheaper. Now figure out why the throttle hung open, get a tester as it can save you time, fuel and issuse and get to the track before it freezes again You want this one... https://proshop.summitracing.com/parts/msd-89981
Re: stuck throttle!
[Re: Al_Alguire]
#3148954
06/05/23 05:08 PM
06/05/23 05:08 PM
gregsdart
Yes they sell one and the newer version even allow you to simulate an entire run. It also is the only one that works with a grid, and its cheaper. Now figure out why the throttle hung open, get a tester as it can save you time, fuel and issuse and get to the track before it freezes again You want this one... https://proshop.summitracing.com/parts/msd-89981 Al, The tech at Summit read off the specs on both and only the 8998 will test the shift light pattern, which is what i need. So it is on the way At $392 I hope it covers my issue! I did test the throttle stop/ transvrake sequence several times without a hicup. No issues, and plenty of clearance around the components. So i suspect it was due to the wrong shoes and my big feet,! rest assured, this lesson will not be forgotten.
Re: stuck throttle!
[Re: gregsdart]
#3148978
06/05/23 06:49 PM
06/05/23 06:49 PM
Al_Alguire
Las Vegas
Yes they sell one and the newer version even allow you to simulate an entire run. It also is the only one that works with a grid, and its cheaper. Now figure out why the throttle hung open, get a tester as it can save you time, fuel and issuse and get to the track before it freezes again You want this one... https://proshop.summitracing.com/parts/msd-89981 Al, The tech at Summit read off the specs on both and only the 8998 will test the shift light pattern, which is what i need. So it is on the way At $392 I hope it covers my issue! I did test the throttle stop/ transvrake sequence several times without a hicup. No issues, and plenty of clearance around the components. So i suspect it was due to the wrong shoes and my big feet,! rest assured, this lesson will not be forgotten. My 89981 works the shifter just fine triggered the same way but with a grid. The older testers will NOT work with a grid. BUt I have one of those in the trailer as well still.
