7 degree locks #3148405
06/03/23 01:55 PM
06/03/23 01:55 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Setting up my heads (Edelbrock RPM) for an aluminum rod 383. On my old 383 906/OEM rods I was spinning 6800-6900 through the lights, so I am thinking with the new combo I will pick up 3-4 mph and be spinning 7200-7300 so I have upped my spring pressure to around 410. It took some time to find the right spring which I now have a set of Comp 929 and 977. My problem now is finding retainers that fit the springs. I have a set of Comp Ti to fit the the 977 spring but they are 7 degree. Just wanted some feedback on running the 7 degree locks, as I have read where some shops do not hesitate to run 7 degree stuff while some claim pull through at anything north of 350. I am 155/410 at .580 net lift
When you are sizing retainers if you can get within .010 for inner and outer is that sufficient or do both really need to be a press fit? The ones I referenced above are .000/+.010 which at this point I am calling good.
Thanks for the help.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: 7 degree locks [Re: clovis] #3148425
06/03/23 02:58 PM
06/03/23 02:58 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Always used 10-degree locks and titanium retainers for an engine like that. No idea if the 7-degree would hold up, I would think the quality of you retainer is the main issue not the degree of the lock. I know even with 10-degree titanium retainers sometimes on fresh up the locks would be sunk a little in the retainer. It is kind of one of those things you just use 10-degree keepers because they tell you to. No experience but a good quality retainer should hold up with 7-degree locks.
Re: 7 degree locks [Re: clovis] #3148458
06/03/23 04:59 PM
06/03/23 04:59 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I don’t see those in my Comp catalog.
Re: 7 degree locks [Re: fast68plymouth] #3148520
06/04/23 12:19 AM
06/04/23 12:19 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Maybe they’re not Comp-It is the one on the left in the photo.
'75 Plymouth Duster
Re: 7 degree locks [Re: clovis] #3148521
06/04/23 12:37 AM
06/04/23 12:37 AM
Out of the State of Confusion
blue_stocker Offline
Ferrea valves highly recommenmds NOT using springs with dampers with Ti retainers as they claim it'll shred them leading to catastrophic engine failure. It might be a good idea to look into this...protect your investment.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: 7 degree locks [Re: blue_stocker] #3148556
06/04/23 10:02 AM
06/04/23 10:02 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would not personally trust a 7mm in titanium. I thought the whole 10 degree basically was to prevent pull out on Ti.
Especially if used. People forget that titanium's are wear parts and should get replaced.
Just my twocents
That being said I have run aluminum retainers 7 degree with the recommended mopar spring for the.557 cam 30 year ago and never dropped a valve, but probably only put 2-3 hundred runs on them before moving on/up.
So they would probably work fine. At least for a few thousand runs.
All that being said my personal fav is the lightweight h-13's
Re: 7 degree locks [Re: B1MAXX] #3148581
06/04/23 12:31 PM
06/04/23 12:31 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Take it as internet reading but one of the citied reasons for 10 degree locks was ease of disassembly and having just taken a set of 7 degrees out of these beads I get it. It also states that a 7 degree has more clamping pressure which is why NASCAR use the Super 7 which are apparently 8 degrees. There was one comment that a Super 7 is a 3/8” 7* lock that is adjusted for different valve sizes.
My 10 degree Ti retainers do have a small wear grove around the edge of the first step from the dampner. I do think I am going to prep my springs this time and remove all the edges maybe even on the dampner. I not notice that a 1.500 spring in the Edelbrock spring cups do have a very slight interference fit. I think I want to avoid a situation where it could try and pick up the cup. I think it is just the edge of the spring catching it.
'75 Plymouth Duster
Re: 7 degree locks [Re: clovis] #3148623
06/04/23 03:14 PM
06/04/23 03:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If your Ti retainers show wear then you've been dumping gritty Ti dust in your oil. That stuff accelerates wear throughout the engine. Ok for race but not the best for long duration street use.
Have you dug through the Isky catalog to see if they had compatible parts?
- Stu Harmon
Re: 7 degree locks [Re: feets] #3149247
06/06/23 10:44 PM
06/06/23 10:44 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Was on vacation when I started this, so I am home now and wanted to add some pictures.
Here are some pictures of the retainers. Like Dwayne said above they are not Comp and I have not been able to find many possibilities for a 7* 11/32 Ti retainer with the measurements I have 1.375/1.060/.680. I assume they are 7* 11/32 retainers, as when I assembly them on the bare 11/32 valve out of the head they stay in place and the locks look to sit where they need. They are thinner (.075) on the top portion, but otherwise they fit the Comp 977 spring very well.
59269FFD-2CFF-4FF7-BB56-6D8DEE5D9CAA.jpegEC8A55DD-DDC3-4250-BFD9-B567C989E72B.jpeg810B1A3A-3CEB-44C3-BC0F-99ABDACC5C13.jpeg
'75 Plymouth Duster
Re: 7 degree locks [Re: clovis] #3149249
06/06/23 10:48 PM
06/06/23 10:48 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Here are a few of how the they fit the valve.
2D8BF02E-F12A-4EED-9E79-B54388D6278A.jpeg2C94CB3F-D05C-4A8F-909B-3D63ED3708CD.jpeg1EBFAB80-7EF8-40E9-9226-9834D65B0EEA.jpegA2E0FE7D-979F-4410-935E-4033AF989013.jpeg
'75 Plymouth Duster
Re: 7 degree locks [Re: clovis] #3149285
06/07/23 07:56 AM
06/07/23 07:56 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
run them. my twocents They are probably old Trick Titaniums.
Re: 7 degree locks [Re: clovis] #3149351
06/07/23 11:09 AM
06/07/23 11:09 AM
Boise
Moparteacher Offline
Boise
Are you sure they are titanium, and not aluminum. I have a set of old school aluminum retainers that look very similiar, but then don't just about all retainers look similiar...?
Have you checked the engagement by looking at the contact area with some machinist dye?
BTW, Manley makes a 7 degree titanium retainer for their Super 7 locks.
Re: 7 degree locks [Re: clovis] #3149437
06/07/23 03:58 PM
06/07/23 03:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
looks good to me up
I would run them twocents
Re: 7 degree locks [Re: Moparteacher] #3149453
06/07/23 04:35 PM
06/07/23 04:35 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
That is a great question. Once you start looking at them they do appear to be a lot more scratched and dented than my other Ti retainers so maybe they are. I guess I will see if I can make some sparks tonight or some marks on glass.
I guess I can also put a little dye on them to check the engagement.
Anyone know if the Edelbrock 7* locks that come on the heads are stamped or machined? I was thinking of using the locks that came on the heads unless the census is not too.
'75 Plymouth Duster
Re: 7 degree locks [Re: Moparteacher] #3149541
06/07/23 08:58 PM
06/07/23 08:58 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They are definately titanium. I look at it every day at work. They are a bit knocked around though. As has been mentioned, I'd not run a dampener spring in them.
Alan Jones
Re: 7 degree locks [Re: LA360] #3149584
06/07/23 10:20 PM
06/07/23 10:20 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Yep, rubbed on the glass tonight and they left a mark so Ti it is.
Can you simply remove a dampner from a spring that came with one or is that a no no?
'75 Plymouth Duster
Re: 7 degree locks [Re: clovis] #3149635
06/08/23 07:45 AM
06/08/23 07:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Thats a no no in my mind, the springs (inner/outer) that have a damper are wound the same direction without a damper they are opposite .
How many dampened springs are out there running on titanium retainers right now? Thousands, maybe millions.
Re: 7 degree locks [Re: B1MAXX] #3149745
06/08/23 03:06 PM
06/08/23 03:06 PM
It only takes one dampener wearing through a Ti retainer causing engine part failures from the debris to learn to NOT use any valve springs with dampeners with Ti retainers tsk shruggy
Tool steel retainers are my current choice with valve springs with dampeners up scope
As far as 7 degree locks being bad keep in mind many different types of auto racing races (NASCAR, sports car, drag races, desert races and endurance races like the 24 hours at Le Mans and Daytona)were won with 7 degrees valve locks in the past due to that being the only option back then shruggy work shruggy
Re: 7 degree locks [Re: Cab_Burge] #3149770
06/08/23 03:51 PM
06/08/23 03:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Most of these engines are only raced at two Mopar events a year. Last about 126 years at that rate.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 7 degree locks [Re: pittsburghracer] #3149872
06/08/23 11:30 PM
06/08/23 11:30 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Thanks for all the help.
Anyone know if the locks that come on the Edelbrock heads are stamped or machined? Just wanted to see if I could use them without much worry.
'75 Plymouth Duster
