Overheating Question #3148097
06/02/23 06:32 AM
06/02/23 06:32 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
While driving my car down the road, the water temperature rises between 220-235. However when I stop it lowers to 200.....
I have an aluminum radiator with 50/50 mix and an electric fan located between the radiator and the motor (pull fan). 185 thermostat
Where should I start?
Re: Overheating Question [Re: WS68SSC] #3148100
06/02/23 07:19 AM
06/02/23 07:19 AM
Andrewh Online content
Andrewh  Online Content
it sounds like your fan isn't pulling enough air at speed and becomes a block.
you can test this by turning off the fan while at speed, and see if the temp stays low.
if it still goes up then it is a flow restriction, which you would need to investigate, stuff like a collapsing hose at speed. you could stuff it into neutral at highway speed and see if it goes down or put a go pro into the engine compartment and watch the lower rad hose.
fan solution would be to get a better fan, or cut vent slats into any kind of shroud you have, flaps really that only open at speed,.
Re: Overheating Question [Re: WS68SSC] #3148117
06/02/23 08:23 AM
06/02/23 08:23 AM
tboomer Offline
tboomer  Offline
Are you running a relay for the fan? And as mentioned how about the shroud? work
Re: Overheating Question [Re: tboomer] #3148127
06/02/23 09:06 AM
06/02/23 09:06 AM
VA
dragon slayer Offline
VA
More info on the motor and water pump and pulley ratio.
Re: Overheating Question [Re: dragon slayer] #3148164
06/02/23 11:39 AM
06/02/23 11:39 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
As well as,
is this a new occurrence
New motor,
new radiator,
new car (to you)
initial and total timing
There are many things that can cause your condition so a bit more overall information is needed to help beer
Re: Overheating Question [Re: TJP] #3148171
06/02/23 11:49 AM
06/02/23 11:49 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
a pic of your setup would help
Re: Overheating Question [Re: bonefish] #3148176
06/02/23 12:04 PM
06/02/23 12:04 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Basic information
What car?
What engine?
What fan?
What's stock or not?
Geez, pulling teeth is easier.
Re: Overheating Question [Re: WS68SSC] #3148250
06/02/23 03:28 PM
06/02/23 03:28 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You have an electric fan between the rad and the engine mounted fan ???
WHY ????
Re: Overheating Question [Re: JohnRR] #3148280
06/02/23 05:16 PM
06/02/23 05:16 PM
nowhere
nowhere
WHY ????
Good catch there, missed that myself
Re: Overheating Question [Re: Sniper] #3148315
06/02/23 09:32 PM
06/02/23 09:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
WHY ????
me as well, Answer: to cause overheating issues whistling twocents
Re: Overheating Question [Re: JohnRR] #3148343
06/03/23 03:05 AM
06/03/23 03:05 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
no manual fan. just an electric one
Re: Overheating Question [Re: WS68SSC] #3148345
06/03/23 05:34 AM
06/03/23 05:34 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Well, I think this was the issue with the overheating....glad I caught it early
Re: Overheating Question [Re: JohnRR] #3148348
06/03/23 05:45 AM
06/03/23 05:45 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
WHY ????
It doesn't have a manual fan. Just an electric one
Re: Overheating Question [Re: WS68SSC] #3148355
06/03/23 08:26 AM
06/03/23 08:26 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I see a lot of the radiator that doesn't have a shroud, Fan only pulls air threw a part of the radiator and not the whole thing!
Re: Overheating Question [Re: Moparite] #3148370
06/03/23 10:40 AM
06/03/23 10:40 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
His temp goes up going down the road and comes back down at idle. A shroud likely won't help that. I would however like to see a better picture of the fan. It may be restricting air flow at speed. Also radiator construction details would help. 4 rows of 1/2 or 5/8" tubes doesn't work as well as 2 rows of 1 or 1 1/4” tubes. Fin density is also relevant.
Re: Overheating Question [Re: WS68SSC] #3148374
06/03/23 10:47 AM
06/03/23 10:47 AM
GomangoCuda Offline
GomangoCuda  Offline
Good catch on the rocker arm. Replace them all with better stuff.
But I doubt that caused the overheating problem.
I just looked at that rocker pic again. Did you clean it up or is it really as dry as it looks? Sure looks like no oil.
Re: Overheating Question [Re: WS68SSC] #3148421
06/03/23 02:37 PM
06/03/23 02:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
WHY ????
Once you get it running again, if the temp problem remains, try sealing ALL the openings around the radiator including the hood to radiator support.
We can then go back to questions on the combination previously asked to try and help. beer
Re: Overheating Question [Re: TJP] #3148423
06/03/23 02:48 PM
06/03/23 02:48 PM
moparx Offline
moparx  Offline
a good hood to core support seal is a must to force all air, whether moving or not, through the radiator.
beer
