512 gets hot quick #3148144
06/02/23 10:17 AM
06/02/23 10:17 AM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
Got a mild 512 based on a 400 big block in a dodge 4x4 and it gets hot in just a few miles. fresh engine, good compression and leakdown. New high volume water pump and 4 core aluminum radiator, twin electric fans and 7 blade clutch fan as well. Tried 180,160, and no thermostat. Gets to 240 in about five miles just driving. I has MLR gaskets on it and I pulled the engine out of desperation and pulled the heads off to try and find something. No cracks or signs of coolant in the heads or oil. holes in the head gaskets are normal. I have an old set of Clark copper gaskets from a race engine laying around and they have a couple extra holes in them for more water ports. I read the slits at the top are to vent steam and air as the water runs across the head. Most stock gaskets have no holes open along the bottom. The copper gaskets do. Has anybody had experience opening these holes up to improve cooling?
Re: 512 gets hot quick [Re: jwb123] #3148156
06/02/23 11:10 AM
06/02/23 11:10 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Cant tell by your photo. Is the pump turning in the right direction? Did you verify the gauge is accurate?
Re: 512 gets hot quick [Re: jwb123] #3148170
06/02/23 11:48 AM
06/02/23 11:48 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Those 2 Electric fans could be restricting air, is the clutch fan engaging when it’s hot?
Re: 512 gets hot quick [Re: rickraw] #3148173
06/02/23 11:55 AM
06/02/23 11:55 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
That serpentine belt have a tensioner?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 512 gets hot quick [Re: 68 HEMI GTS] #3148174
06/02/23 12:01 PM
06/02/23 12:01 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
yes drill the holes, you can see the "rust" spot on the cometics in your pic, but lay the copper on top for reference.
....BAD A$$ STREET CAR.....
Re: 512 gets hot quick [Re: jwb123] #3148268
06/02/23 04:34 PM
06/02/23 04:34 PM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
The fans were not on their when I started the project, it got hot without them. The water pump I used is a FlowCooler 12 vane and it is not dependent on rotation like a stock pump. Serpentine belt is tight. it is kind of driving me crazy because their is just not reason I can see.
Re: 512 gets hot quick [Re: jwb123] #3148276
06/02/23 04:55 PM
06/02/23 04:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
when I 1st built my 400/512 I had the block hot tanked & then I flushed the cooling passages out with the freeze plugs out, put it all together , 1st test drive all was good, 185ish temp, then it started running hot, turns out that my new Champion 4 row radiator got plugged up from rusty scale breaking loose , replaced the radiator with a ECP 2 row & installed an Gano screen in the upper hose, at 1st it caught a lot of metal scale & I would clean it out when I did an oil change, now when I check the screen it stays clean. the 4 row Champion had very small tubes, a small chunk would plug the tube.
Re: 512 gets hot quick [Re: CSK] #3148278
06/02/23 05:08 PM
06/02/23 05:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
Are you saying the pump spins in the opposite direction of “normal”?
If so, the first thing I would have tried is a set of stock pulleys to see if the direction made any difference.
Re: 512 gets hot quick [Re: fast68plymouth] #3148285
06/02/23 05:43 PM
06/02/23 05:43 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I’m guessing it is the flowkooler 1679, which “looks” like it could work either direction…..
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 512 gets hot quick [Re: jwb123] #3148292
06/02/23 06:36 PM
06/02/23 06:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What part number are you running? I only see one and it is #1679 and rotation is clockwise. Pump
Re: 512 gets hot quick [Re: NITROUSN] #3148308
06/02/23 08:56 PM
06/02/23 08:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I drill out a a couple extra holes. But now I just have Cometic do it for me. I also add extra material in the corners . They will custom build them pretty fast.
Re: 512 gets hot quick [Re: jwb123] #3148309
06/02/23 09:00 PM
06/02/23 09:00 PM
West Palm Beach, Florida
Craig J Online content
Craig J  Online Content
what diameter is the pulley on the water pump?
what diameter is the pulley on the crankshaft?
edit: How much clearance between the back side of the blades on the water pump and the surface on the housing?
Re: 512 gets hot quick [Re: Craig J] #3148359
06/03/23 09:17 AM
06/03/23 09:17 AM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
direction of pully rotation is clockwise. I got the engine torn down completely now. I washed the block in my parts washer, without freeze plugs, but in looking down in the block I still see come crap that I did not get out. Going to wash again and back wash the radiator, drill extra cooling holes in head gasket. And see what happens. The engine is the original one in the truck, and it had some expanding freeze plugs installed sometime in the past, and in looking at the crap in the bottom of the block, I am wondering if someone had dumped a bunch of stop leak in it, and it is breaking loose with the new rebuild and fresh antifreeze.
Re: 512 gets hot quick [Re: FastmOp] #3148360
06/03/23 09:19 AM
06/03/23 09:19 AM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
Do you have them drilled similar to the copper ones in my pictures? And where exactly is material added in the corners?
Re: 512 gets hot quick [Re: CSK] #3148429
06/03/23 03:04 PM
06/03/23 03:04 PM
moparx Offline
moparx  Offline
i have been thinking about one of those, "just because", as a precaution.
beer
Re: 512 gets hot quick [Re: moparx] #3148484
06/03/23 07:59 PM
06/03/23 07:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
Its made like a minnow trap, I also put a little magnet in the trap area, it caught LOTS of rusty metal chunks., the 1st one I got was see through, I now have the aluminum one.
Re: 512 gets hot quick [Re: jwb123] #3148666
06/04/23 06:24 PM
06/04/23 06:24 PM
iowa
copchaser Offline
copchaser  Offline
iowa
What brand of radiator are you running? I hope it's not a Champion Ebay special. Actually, I do because they are garbage. Those things can't cool a lawn mower.
