904 issue #3148160
06/02/23 11:26 AM
06/02/23 11:26 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Race trans, A&A brake( have yet to use it just foot brake it)
Made a pass at track, car just sat there like it was spinning/ slipping, went 1.90 60 foot, acts like it “ catches” then takes off.
Made another pass, same thing. Car always hooks, 1.45 ish 60 foot.
Drove it back to pits, all three forward gears seem to work just idling around.
Reverse doesn’t work, put car in park, want to creep forward
Any ideas? Trans has been in car several seasons, never done anything but change fluid
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 904 issue [Re: B3422W5] #3148190
06/02/23 12:53 PM
06/02/23 12:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sounds like a problem in the rear clutch, probably overpowered the Belleville spring and popped the piston out of its bore.
Re: 904 issue [Re: John_Kunkel] #3148232
06/02/23 02:56 PM
06/02/23 02:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Could it be a sprag issue?
Re: 904 issue [Re: stumpy] #3148376
06/03/23 11:07 AM
06/03/23 11:07 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A failed sprag won't affect Reverse or make it creep forward in Park.
Re: 904 issue [Re: John_Kunkel] #3148386
06/03/23 12:16 PM
06/03/23 12:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I didn't know that. Thanks for the info. up
Re: 904 issue [Re: stumpy] #3152372
06/17/23 07:19 PM
06/17/23 07:19 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Smoked front band..ran with it out of adjustment my guy said, and rear clutches smoked and welded together.
1.41 best 60 foot
6.60 at 103.90 1/8
