904 issue
#3148160
06/02/23 11:26 AM
06/02/23 11:26 AM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Race trans, A&A brake( have yet to use it just foot brake it) Made a pass at track, car just sat there like it was spinning/ slipping, went 1.90 60 foot, acts like it “ catches” then takes off. Made another pass, same thing. Car always hooks, 1.45 ish 60 foot. Drove it back to pits, all three forward gears seem to work just idling around. Reverse doesn’t work, put car in park, want to creep forward
Any ideas? Trans has been in car several seasons, never done anything but change fluid
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: 904 issue
[Re: B3422W5]
#3148190
06/02/23 12:53 PM
06/02/23 12:53 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Sounds like a problem in the rear clutch, probably overpowered the Belleville spring and popped the piston out of its bore.
Re: 904 issue
[Re: stumpy]
#3148376
06/03/23 11:07 AM
06/03/23 11:07 AM
John_Kunkel
Rio Linda, CA
A failed sprag won't affect Reverse or make it creep forward in Park.
Re: 904 issue
[Re: stumpy]
#3152372
06/17/23 07:19 PM
06/17/23 07:19 PM
B3422W5
Portage,michigan
Smoked front band..ran with it out of adjustment my guy said, and rear clutches smoked and welded together.
