pulling the chute #3148152
06/02/23 10:40 AM
06/02/23 10:40 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
How do pull your chute do you pull it before your off the gas or after you are off the gas what is your procedure??? Thanks
Re: pulling the chute [Re: dragon] #3148161
06/02/23 11:27 AM
06/02/23 11:27 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
You may get different answers on this.
For safety reasons, put your hand on the handle once the car is in high gear. Pull it a little before the stripe, and drive into it. Pull it then off the throttle, you will get the hang of it after a few pulls. The idea is for it to blossom just at or after the stripe. Also the reason for having your hand on the handle in high gear , is if anything goes wrong your already there to pull it.
....BAD A$$ STREET CAR.....
Re: pulling the chute [Re: n20mstr] #3148166
06/02/23 11:41 AM
06/02/23 11:41 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You want it open as soon as possible, so as said above, as you approach the finish line, push the lever then go about your business. It will all feel natural and automatic. The safety is enormous. No matter what happens, brake failure, fire, throttle hung, car gets out of shape, blowout, no matter what, you are in so much better position. You'll like it so much won't be able to go back. It just feels unsafe...because it is.
2011 Drag Pak Challenger
Re: pulling the chute [Re: rickseeman] #3148203
06/02/23 01:33 PM
06/02/23 01:33 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You want to drive into the chute - so pull the handle before the finish line - it will take you a little practice to find the right spot - the worst thing you can do is not be under power when that chute hits as the suspension unloads - I did that once and it scared the hell out of me!
00
If you watch pro-stock closely they actually use the chute to drop the front end of the car at the finish line - takes practice
Re: pulling the chute [Re: DoubleD] #3148228
06/02/23 02:48 PM
06/02/23 02:48 PM
How do you decide on what size and how many chutes to use? My new car will need them for running over 150 MPH in the 1/4 mile, probably above 165 MPH+ up to maybe 200+ MPH later luck
Re: pulling the chute [Re: Cab_Burge] #3148241
06/02/23 03:05 PM
06/02/23 03:05 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Stroud can probably give you a recommendation on that.
Re: pulling the chute [Re: rickseeman] #3148260
06/02/23 03:55 PM
06/02/23 03:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
200mph requires 2 chutes. As for deploying it whats been said.
Re: pulling the chute [Re: Cab_Burge] #3148482
06/03/23 07:58 PM
06/03/23 07:58 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Weight vs Speed, Stroud has a CHART that can help. Most likely you will need a Stroud 420 and as stated if 200 or more MPH the rules require 2.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: pulling the chute [Re: W.I.N. Racing] #3148609
06/04/23 02:01 PM
06/04/23 02:01 PM
moparx Online content
moparx  Online Content
in the slower classes, is it possible to get too large of a chute ?
if so, what would the effect[s] be ?
beer
Re: pulling the chute [Re: moparx] #3148618
06/04/23 02:31 PM
06/04/23 02:31 PM
if so, what would the effect[s] be ? beer
teeth marks in the steering wheel work whistling grin
Re: pulling the chute [Re: Cab_Burge] #3148876
06/05/23 01:40 PM
06/05/23 01:40 PM
HAHAHAHA !!!
my old man put teeth marks on the perfect wood grain steering wheel that was on my 64 barracuda, but it wasn't from "pullin' the chute". it was from hitting a telephone pole. laugh2
beer
