Re: Overheating Question
[Re: WS68SSC]
#3148100
06/02/23 07:19 AM
06/02/23 07:19 AM
Andrewh
it sounds like your fan isn't pulling enough air at speed and becomes a block. you can test this by turning off the fan while at speed, and see if the temp stays low. if it still goes up then it is a flow restriction, which you would need to investigate, stuff like a collapsing hose at speed. you could stuff it into neutral at highway speed and see if it goes down or put a go pro into the engine compartment and watch the lower rad hose. fan solution would be to get a better fan, or cut vent slats into any kind of shroud you have, flaps really that only open at speed,.
[Re: dragon slayer]
#3148164
06/02/23 11:39 AM
06/02/23 11:39 AM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
More info on the motor and water pump and pulley ratio. As well as, is this a new occurrence New motor, new radiator, new car (to you) initial and total timing There are many things that can cause your condition so a bit more overall information is needed to help
[Re: WS68SSC]
#3148250
06/02/23 03:28 PM
06/02/23 03:28 PM
Posts: 75,068 U.S.S.A.
JohnRR
U.S.S.A.
While driving my car down the road, the water temperature rises between 220-235. However when I stop it lowers to 200..... I have an aluminum radiator with 50/50 mix and an electric fan located between the radiator and the motor (pull fan). 185 thermostat
Where should I start? You have an electric fan between the rad and the engine mounted fan ??? WHY ????
[Re: JohnRR]
#3148280
06/02/23 05:16 PM
06/02/23 05:16 PM
Posts: 6,290 nowhere
Sniper
nowhere
Where should I start? You have an electric fan between the rad and the engine mounted fan ??? WHY ???? Good catch there, missed that myself
[Re: Sniper]
#3148315
06/02/23 09:32 PM
06/02/23 09:32 PM
TJP
Omaha Ne
Where should I start? You have an electric fan between the rad and the engine mounted fan ??? WHY ???? Good catch there, missed that myself me as well, Answer: to cause overheating issues
[Re: JohnRR]
#3148348
06/03/23 05:45 AM
06/03/23 05:45 AM
Posts: 299 Chicago adjacent
WS68SSC
Newest
Newest
Chicago adjacent
Where should I start? You have an electric fan between the rad and the engine mounted fan ??? WHY ???? It doesn't have a manual fan. Just an electric one
[Re: Moparite]
#3148370
06/03/23 10:40 AM
06/03/23 10:40 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
I see a lot of the radiator that doesn't have a shroud, Fan only pulls air threw a part of the radiator and not the whole thing! His temp goes up going down the road and comes back down at idle. A shroud likely won't help that. I would however like to see a better picture of the fan. It may be restricting air flow at speed. Also radiator construction details would help. 4 rows of 1/2 or 5/8" tubes doesn't work as well as 2 rows of 1 or 1 1/4” tubes. Fin density is also relevant.
[Re: WS68SSC]
#3148374
06/03/23 10:47 AM
06/03/23 10:47 AM
GomangoCuda
Good catch on the rocker arm. Replace them all with better stuff. But I doubt that caused the overheating problem.
I just looked at that rocker pic again. Did you clean it up or is it really as dry as it looks? Sure looks like no oil.
[Re: WS68SSC]
#3148421
06/03/23 02:37 PM
06/03/23 02:37 PM
TJP
Omaha Ne
Where should I start? You have an electric fan between the rad and the engine mounted fan ??? WHY ???? It doesn't have a manual fan. Just an electric one Once you get it running again, if the temp problem remains, try sealing ALL the openings around the radiator including the hood to radiator support. We can then go back to questions on the combination previously asked to try and help.
