Big Block ARP head studs torque specs #3147473
05/29/23 07:13 PM
05/29/23 07:13 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
What is it ? You ever add more ?
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147481
05/29/23 07:35 PM
05/29/23 07:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Yes I added 10ft lbs with copper head gaskets and o ring
Re: Big Block ARP head studs torque specs [Re: Clanton] #3147487
05/29/23 08:35 PM
05/29/23 08:35 PM
birdtracker Offline
birdtracker  Offline
They will break with 20 or more foot pounds. I know this from my own personal experience. I have no clue why I wanted more torque! Birdtracker
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147491
05/29/23 08:50 PM
05/29/23 08:50 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Hemi is 80 with ARP lube. No. I assume a wedge is the same torque.
2011 Drag Pak Challenger
Re: Big Block ARP head studs torque specs [Re: rickseeman] #3147493
05/29/23 08:58 PM
05/29/23 08:58 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
the problem with put higher torque is it starts distorting cyl walls from what they were honed with torque plates
JAKES AUTOMOTIVE
Re: Big Block ARP head studs torque specs [Re: JAKE68] #3147505
05/29/23 10:47 PM
05/29/23 10:47 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I thought it was 80 but wasn't sure. I'll go 85 ish.
I'm lifting the heads and just trying to get a little more clamp.
Thanks gents
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147519
05/30/23 03:34 AM
05/30/23 03:34 AM
Call ARP and ask them for both the six sided head nuts and the 12 sided nuts with ARP lube and with oil scope
Stock BB Mopar 7/16 course thread head bolts are 65 Ft. lbs. with oil on the threads and the bottom of the bolt heads twocents
Re: Big Block ARP head studs torque specs [Re: Cab_Burge] #3147555
05/30/23 09:42 AM
05/30/23 09:42 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Can it an Indy block and heads. I had it wrote on the ARP box but can't find it
Found my box and paper with the specs. 80 ft #
Thanks again gents.
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147703
05/30/23 09:16 PM
05/30/23 09:16 PM
PA
moparacer Offline
moparacer  Offline
PA
I have been known to give them an extra 5....I have seen enough variables in torque wrenches to warrant that. on head gaskets I would rather be a smidge high than low.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Big Block ARP head studs torque specs [Re: JAKE68] #3147755
05/31/23 07:58 AM
05/31/23 07:58 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Excellent point and worth considering while using a stock block. This last build i used 30wt oil and only went to 70lb and it was sealing NO PROBLEM with about 750 n/a. One thing to consider is that with both an aluminum block and heads they grow and additionally load the fastener.
Re: Big Block ARP head studs torque specs [Re: HardcoreB] #3147763
05/31/23 08:57 AM
05/31/23 08:57 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I just opened a box of a new set for Indy aluminum heads. The instructions say 70 ft/lbs with their lube
Re: Big Block ARP head studs torque specs [Re: Stanton] #3147841
05/31/23 02:25 PM
05/31/23 02:25 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Post a pic of the spec sheet Stanton
When you make power like I do, even good parts are at there limit. I tryd to talk to Indy (Ken) about upgrading to 1/2 inch studs and he kept telling me I need to put one of there solid blocks in it. After enough of that I finally told him I have a solid blocks for my next combo but it ain't cast Indy [censored]. It's BAE lol. He was done after that, so I just put new rods and bearings in it with valve springs and same ole 440Source crank. Still one of the fastest 440-1 combos out there.
Re: Big Block ARP head studs torque specs [Re: moparacer] #3147850
05/31/23 03:17 PM
05/31/23 03:17 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree although Trick Flows instructions also say 70 ft lbs, I remember seeing 80 in the ARP instructions, and I think I torqued my head studs to 85 ft lbs according to the torque wrench
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147856
05/31/23 04:04 PM
05/31/23 04:04 PM
PA
O
Ody1003 Offline
Ody1003  Offline
O
PA
Be cautioned on over torque. Saved and old arp main stud torque spec. ARP recommended main torque with there lube 85lbs. with oil 135lbs. shows' you the difference when using different lubes. aluminum block and heads do grow and get tight. Played a lot with it on main bores and rod big end bores. can make noticeable change in round dimensions.
unfortunately over pulling on aluminum threads over torque can be bad on the threaded holes in block both ends.
Op, 440-1 heads. 2835lb demon 528c.i. 5.43/125mph. 3385 b-body 540c.i 5.74/120+ 9.00/150mph.
some fast 440-1 headed engines.
Re: Big Block ARP head studs torque specs [Re: HardcoreB] #3147857
05/31/23 04:06 PM
05/31/23 04:06 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Has anyone ever had water seepage into a cylinder using the INDY 70 foot pound spec and cometic gaskets on SR heads?
Would going to the 80 or 85 foot pound torque mentioned here help stop it?
Thanks!
Re: Big Block ARP head studs torque specs [Re: moparjohn] #3147864
05/31/23 04:39 PM
05/31/23 04:39 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
John that's usually surface finish to rough.
I'm an 1/8 miler this was last time out. Been faster
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147867
05/31/23 04:43 PM
05/31/23 04:43 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Thanks FastmOp for the quick reply and info.
Impressive times on the slip for sure!
Re: Big Block ARP head studs torque specs [Re: moparjohn] #3147941
06/01/23 08:42 AM
06/01/23 08:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Sorry Bud, I misread your title ... mine are head BOLTS - not studs.
Re: Big Block ARP head studs torque specs [Re: FastmOp] #3147989
06/01/23 01:30 PM
06/01/23 01:30 PM
Absolutely NOT tsk twocents
I use the manufacturers specs, with the lube they recommend up work twocents
Mopar FSM call for two different torque specs, the lower one is with clean surfaces and no lube, the second higher one is with oil on the threads scope
