Re: Big Block ARP head studs torque specs
[Re: FastmOp]
#3147491
05/29/23 08:50 PM
05/29/23 08:50 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
What is it ? You ever add more ? Hemi is 80 with ARP lube. No. I assume a wedge is the same torque.
2011 Drag Pak Challenger
[Re: rickseeman]
#3147493
05/29/23 08:58 PM
05/29/23 08:58 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
the problem with put higher torque is it starts distorting cyl walls from what they were honed with torque plates
JAKES AUTOMOTIVE
[Re: Cab_Burge]
#3147555
05/30/23 09:42 AM
05/30/23 09:42 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Can it an Indy block and heads. I had it wrote on the ARP box but can't find it
Found my box and paper with the specs. 80 ft #
Thanks again gents.
[Re: FastmOp]
#3147703
05/30/23 09:16 PM
05/30/23 09:16 PM
Posts: 2,504 PA
moparacer
PA
I have been known to give them an extra 5....I have seen enough variables in torque wrenches to warrant that. on head gaskets I would rather be a smidge high than low.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: JAKE68]
#3147755
05/31/23 07:58 AM
05/31/23 07:58 AM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
the problem with put higher torque is it starts distorting cyl walls from what they were honed with torque plates Excellent point and worth considering while using a stock block. This last build i used 30wt oil and only went to 70lb and it was sealing NO PROBLEM with about 750 n/a. One thing to consider is that with both an aluminum block and heads they grow and additionally load the fastener.
[Re: Stanton]
#3147841
05/31/23 02:25 PM
05/31/23 02:25 PM
FastmOp
Hot Rod Ridge
Post a pic of the spec sheet Stanton When you make power like I do, even good parts are at there limit. I tryd to talk to Indy (Ken) about upgrading to 1/2 inch studs and he kept telling me I need to put one of there solid blocks in it. After enough of that I finally told him I have a solid blocks for my next combo but it ain't cast Indy [censored]. It's BAE lol. He was done after that, so I just put new rods and bearings in it with valve springs and same ole 440Source crank. Still one of the fastest 440-1 combos out there.
[Re: moparjohn]
#3147941
06/01/23 08:42 AM
06/01/23 08:42 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Post a pic of the spec sheet Stanton Sorry Bud, I misread your title ... mine are head BOLTS - not studs.
