Re: 70 Challenger Gas Gauge Dilemma!
[Re: DJVCuda]
#3146340
05/23/23 09:13 AM
05/23/23 09:13 AM
Posts: 147 Canada
EW1BH27
Canada
Did you make sure the float doesn't have a pin hole in it. Doesn't take much gas in it to keep it at the bottom. Might try adding a ground wire. Picture from Moparts from ages ago. My video of the ground wire in action. https://www.youtube.com/watch?v=gV_HMJa5maY
[Re: EW1BH27]
#3146341
05/23/23 09:18 AM
05/23/23 09:18 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Thanks for the reply! I checked the float out of the tank - moved the float up and down manually and watched the gauge only move up to 1/8th of a tank while it was plugged in and grounded. Thats what stumped me - because I can ground the sending unit wire and it goes all the way to full - didnt let it because i didnt want to fry the gauge.
I can certainly try the ground wire trick to the float though!
[Re: TJP]
#3146550
05/24/23 09:52 AM
05/24/23 09:52 AM
Posts: 147 Canada
EW1BH27
Canada
PS: By the way I meant to write that's it's pretty cool your dad (original owner) still has the car. Hope it stays in your family. Oh yeah, if there's a poor ground at the pivot point that'll definitely increase the resistance. And just to stress, if you do add the wire make 100% it doesn't interfere with the arm's movement. That's why I made the green wire on mine longer than the pictured one.
[Re: EW1BH27]
#3146560
05/24/23 10:43 AM
05/24/23 10:43 AM
Posts: 10,752 North Dakota
6PakBee
North Dakota
I've used this for flexible grounds on low current applications. Copper Soldering Wick
[Re: DJVCuda]
#3146677
05/24/23 08:17 PM
05/24/23 08:17 PM
DJVCuda
Atco NJ
[Re: DJVCuda]
#3146699
05/24/23 10:17 PM
05/24/23 10:17 PM
Posts: 15,483 Omaha Ne
TJP
Omaha Ne
UPDATE!
Ok- Had a gauge and sending unit from a 70 satellite to check things out as a double check!
IE
Wired the satellite gauge up and it worked fine - out of the car but from the plug and ground at the tank.
Pulled the front seat to get to the back of the gauge and checked from there:
Had the sending unit in the car with jumper wires, to eliminate the wire from the gauge to the sending unit and it didnt work. Jumped in the satellite gauge ( after voltage reducer, before gauge ) and it worked. Plugged the wires back and ran a jumper wire from the outlet of the gauge to sender and it didnt work.
This sounds to me that the gauge is dead. Even though I can make it move with 12v by grounding out the sending unit wire at the back of the car!
WHEW! if you put 12V to the gauge there is a good chance it's fried. Your description of what you've done is a bit confusing IE: Double checked the OHM's from both gauges. - 10 empty, 70 full I believe on both did you mean sending units????Jumped in the satellite gauge ( after voltage reducer, before gauge ) and it worked. Gauge or sending unit ???Plugged the wires back and ran a jumper wire from the outlet of the gauge to sender and it didnt work.
[Re: TJP]
#3146819
05/25/23 04:26 PM
05/25/23 04:26 PM
DJVCuda
Atco NJ
haha... yes i posted after a long couple hours in the garage and it shows! if you put 12V to the gauge there is a good chance it's fried. - Just touched it to see if it would move - Your description of what you've done is a bit confusing IE:
Double checked the OHM's from both gauges. - 10 empty, 70 full I believe on both did you mean sending units???? YES Meant sending units!
Jumped in the satellite gauge ( after voltage reducer, before gauge ) and it worked. Gauge or sending unit ??? Gauge and it worked
Plugged the wires back and ran a jumper wire from the outlet of the gauge to sender and it didnt work. confused - I tried to eliminate the gauge, then the wire to the sender by removing the 5v supply to the gauge first - with a new gauge ( satty) and jumped to the sending unit. - that worked. I then plugged the gause back in and removed the other side, the outlet of the gauge in the dash to eliminate the wire. it didnt work.
THe gauge only goes up to 1/4 tank when its supposed to read full
Hope that helps!
[Re: DJVCuda]
#3146852
05/25/23 10:23 PM
05/25/23 10:23 PM
TJP
Omaha Ne
the gauge is powered by the 5v Limiter. The limiter is actually fed 12V and the points inside the limiter flutteropen and closed on about a 40% duty cycle thereby limiting the output voltage to 5V. that 5V is fed to the gauges via the circuit panel. the sending unit signal is a variable resistor to ground. That variable resistance is what makes the gauge read. You likely have an intermittent ground issue with the sending unit that is making you chase your tail. BTDT you can try a 10, 23? and 70 ohm resistor between the sending unit connector and ground MAKE SURE YOUR GROUND IS CLEAN and that your jumpers are not intermittent ( been bit by that more than once). The gauge should read High, Mid range and Low with each resistor. Give the gauge time to react when connected as they are slow to respond.
[Re: TJP]
#3147017
05/27/23 05:51 AM
05/27/23 05:51 AM
Posts: 5,924 ohio
ruderunner
ohio
If the Sattelite gauge works correctly when connected to the car wiring, that much proves out.
I'm thinking cluster ground or dash ground. Does the temp gauge work correctly? Oil pressure?
Angry white pureblood male
