Early dakota lug nuts #3145645
05/19/23 07:22 PM
05/19/23 07:22 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So I got the factory wheels on my 92 dakota, look like a 5 spoke chrome steel wheel with the spokes slightly slanted and they look a lot like the heavier doody trucks but the center cap looks like it is supposed to pop on over the lug nuts but I can't find the right lug nuts, is there a source for them new or somebody know where I can get a used set?
Re: Early dakota lug nuts [Re: HotRodDave] #3145705
05/20/23 05:24 AM
05/20/23 05:24 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If these are the wheels I'm thinking of, the caps go under the lug nuts. The bulge seat nuts are just a little bigger than the holes in the caps.
Angry white pureblood male
Re: Early dakota lug nuts [Re: ruderunner] #3146183
05/22/23 01:57 PM
05/22/23 01:57 PM
Kalispell Mt.
Kalispell Mt.
nope it's a chrome dome with no holes and a stamped in ram head and it just snaps over the lug nuts if you have the correct lug nuts.
Re: Early dakota lug nuts [Re: HotRodDave] #3146242
05/22/23 07:14 PM
05/22/23 07:14 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Ok, different wheels then. Pics?
Re: Early dakota lug nuts [Re: ruderunner] #3146280
05/22/23 09:59 PM
05/22/23 09:59 PM
Kalispell Mt.
Kalispell Mt.
I've tried many times sine the last board "update" to load pics and never been able to finger it out.
https://www.finishlinewheels.com/products/z02037u85-dodge-dakota-15x6-chrome-steel-oem-rim
This is what the wheel looks like
Re: Early dakota lug nuts [Re: ruderunner] #3146282
05/22/23 10:01 PM
05/22/23 10:01 PM
Kalispell Mt.
Kalispell Mt.
https://www.autolow.com/dodge-dakot...heel-center-cap-part-52039274-sd00018316
This is almost exactly what the center caps look like
Re: Early dakota lug nuts [Re: HotRodDave] #3146346
05/23/23 09:30 AM
05/23/23 09:30 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
arent these the right ones? they should work for thaat style cap
https://www.rockauto.com/en/moreinfo.php?pk=1848544&cc=1087589&pt=7676&jsn=885
In addition, certain years Fords (like a 98 crown vic) used a longer shank so the retaining ring came out further to secure the caps better. Using those on my 92 w250 to keep 1994 center caps on my 1996 F250 alcoa rims.
https://www.rockauto.com/en/moreinfo.php?pk=9841916&cc=1304020&pt=7676&jsn=1452
