Re: odd 440 Block stamping numbers
[Re: sixpack4spd]
#3144635
05/15/23 01:05 AM
05/15/23 01:05 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Looks like it’s a Jan ‘68 casting block with a Feb, assy date for a 1969 model year. Little strange with the timing of that. No idea what’s up with the 877 stamping.
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks.
[Re: Chargerfan68]
#3144682
05/15/23 09:54 AM
05/15/23 09:54 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That looks like a 69 casting date to me . All the other markings look good good to me except that 877 , not sure what's up with that , the circular marks appear to be factory machining . The HP stamp being sideways is not surprising as it's a separate stamp used to make it .
[Re: Chargerfan68]
#3144687
05/15/23 10:31 AM
05/15/23 10:31 AM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That is a January 69 casting, the 9 sometimes looks like an 8. Looks good to me, except of course for the extra numbers...
JB Rhinehart, Realist
A-Body's RULE!
[Re: JohnRR]
#3144723
05/15/23 11:36 AM
05/15/23 11:36 AM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That looks like a 69 casting date to me . All the other markings look good good to me except that 877 , not sure what's up with that , the circular marks appear to be factory machining . The HP stamp being sideways is not surprising as it's a separate stamp used to make it . Could "877" be the first number on the second row from the top on a Lynch Road fender tag that identifies the engine (like on an A12 tag of 925, 926 ) or on this tag for a '69 383 Super Bee of 899?? Anyone ever see a fender tag (or broadcast sheet) with an 877 engine code?
[Re: sixpack4spd]
#3144868
05/15/23 11:35 PM
05/15/23 11:35 PM
Chargerfan68
New York, USA
I still think it’s strange that it’s stamped for 1969 model year “E” for a jan ‘68 casting block. To me, that means Feb, 3, 1969 assy date. Weird.
[Re: Rhinodart]
#3144870
05/15/23 11:38 PM
05/15/23 11:38 PM
Chargerfan68
New York, USA
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That is a January 69 casting, the 9 sometimes looks like an 8. Looks good to me, except of course for the extra numbers... In that case, you are correct and it would be normal. Looking at it again, i think you are right. Thx for pointing that out.
[Re: Chargerfan68]
#3144878
05/16/23 12:13 AM
05/16/23 12:13 AM
A12
N.E. OHIO, USA
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That is a January 69 casting, the 9 sometimes looks like an 8. Looks good to me, except of course for the extra numbers... In that case, you are correct and it would be normal. Looking at it again, i think you are right. Thx for pointing that out. It looks like 1 - 15 - 69 casting date to me. Just a "dirty" 9 IMO
[Re: Chargerfan68]
#3144900
05/16/23 08:09 AM
05/16/23 08:09 AM
JohnRR
U.S.S.A.
I still think it’s strange that it’s stamped for 1969 model year “E” for a jan ‘68 casting block. To me, that means Feb, 3, 1969 assy date. Weird. It wouldn't be the first time something like that happened. You mentioned earlier not seeing a 68 casting with the 69 rib , why???, because it's not a 68 casting .
[Re: A12]
#3144902
05/16/23 08:11 AM
05/16/23 08:11 AM
JohnRR
U.S.S.A.
Also strange that a ‘68 casting block would have the horizontal block reinforcement that came out for ‘69 blocks. That looks like a 69 casting date to me . All the other markings look good good to me except that 877 , not sure what's up with that , the circular marks appear to be factory machining . The HP stamp being sideways is not surprising as it's a separate stamp used to make it . Could "877" be the first number on the second row from the top on a Lynch Road fender tag that identifies the engine (like on an A12 tag of 925, 926 ) or on this tag for a '69 383 Super Bee of 899?? Anyone ever see a fender tag (or broadcast sheet) with an 877 engine code? I've never seen a Broadcast sheet engine code stamped on the ID pad . One thing to note the engine is not painted the correct color for a 69 HP build , the 877 might be a number stamped by the shop that rebuilt it ?
[Re: JohnRR]
#3144972
05/16/23 12:57 PM
05/16/23 12:57 PM
Posts: 735 New York
R/T1968R/T
New York
I owned that block years ago. Sold it to a guy in the Bronx NY. It was a Jan 69 cast block with a Feb build date. I didnt know what the other numbers were, I assumed a number from a machine shop. From what I remember it was NOT from a B Body. Jefferson plant I think, but that was a while ago so ???
