motor plate gaskets #3144284
05/12/23 11:19 PM
05/12/23 11:19 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi.
how is everyone sealing the motor plate to engine and water pump housing .
mine has developed a leak , been in there about 10 years now ?
any special gaskets for this area ?
thank you !
Re: motor plate gaskets [Re: calrobb2000] #3144285
05/12/23 11:25 PM
05/12/23 11:25 PM
Originally Posted by calrobb2000
hi.
thank you !
which motor?
If it is a BB or a gen 2 hemiroid motor I use two water pump gaskets, one on each side wrench scope up twocents
Re: motor plate gaskets [Re: calrobb2000] #3144293
05/13/23 01:42 AM
05/13/23 01:42 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
I use Superformance gaskets. Then I used Ultra black and rub it in the gaskets, no leaks.
America First!
Re: motor plate gaskets [Re: carnut68] #3144308
05/13/23 06:40 AM
05/13/23 06:40 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2 superformance gaskets with clear silicone sealer, no leaky.
Re: motor plate gaskets [Re: rickraw] #3144316
05/13/23 07:30 AM
05/13/23 07:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ultra Grey RTV. We've run the car 10 years this way. It's been apart for maintenance. It's been together at least 3 years at a time between maintenace. Never had a leak. No weepage seen during disasembly either. Used to use gaskets. Some times they'ld leak. Been at the track many times when others have had when using gaskets on a plate.
Doug
Re: motor plate gaskets [Re: dvw] #3144324
05/13/23 08:45 AM
05/13/23 08:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Doug
x2
Re: motor plate gaskets [Re: B1MAXX] #3144329
05/13/23 09:09 AM
05/13/23 09:09 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
X3
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: motor plate gaskets [Re: B1MAXX] #3144331
05/13/23 09:10 AM
05/13/23 09:10 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Gaskets with a thin layer of RTV on both sides of mine. I also have mine studed so it all slips on nice and easy.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: motor plate gaskets [Re: 6PKRTSE] #3144338
05/13/23 09:59 AM
05/13/23 09:59 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
O rings. I O ringed the plate.
Re: motor plate gaskets [Re: markz528] #3144380
05/13/23 01:18 PM
05/13/23 01:18 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Interesting work
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: motor plate gaskets [Re: BloFish] #3144395
05/13/23 02:13 PM
05/13/23 02:13 PM
PA.
"Little"John
"Little"John
PA.
Any thing that guys over think on. If I run my engine in the race car past three years I do a little winter maintenance and take the engine plate and water pump off, clean it, and reseal it. Gaskets or No Gaskets it’s part of my program. Easy-peasy. Don’t overthink it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: motor plate gaskets [Re: markz528] #3144397
05/13/23 02:17 PM
05/13/23 02:17 PM
That is a option if you have access to a good machine shop and you're going to be working on the motor in and out of the car a lot when you need to remove the plate or elephant ears up scope
Re: motor plate gaskets [Re: Cab_Burge] #3144425
05/13/23 05:28 PM
05/13/23 05:28 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
all these replies using specific sealants etc... & all I do is make a gasket from a beer carton, smear grease on it & its good to go, & I do this on all my motors. never had a fail yet & I've been doing this for 30+ years.
Re: motor plate gaskets [Re: rebel] #3144508
05/14/23 08:42 AM
05/14/23 08:42 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
No gaskets and Right Stuff. Let it cure 24 hrs before you add coolant.
Re: motor plate gaskets [Re: fbs63] #3144527
05/14/23 10:41 AM
05/14/23 10:41 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
You'll need an air hammer to get it apart. hammer
America First!
Re: motor plate gaskets [Re: carnut68] #3144610
05/14/23 08:39 PM
05/14/23 08:39 PM
PA
moparacer Offline
moparacer  Offline
PA
Permatex Ultra Grey here. Never a leak.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: motor plate gaskets [Re: moparacer] #3144661
05/15/23 08:30 AM
05/15/23 08:30 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Superformance gaskets. I put them on dry. No issues yet.
69 GTX 68 Road Runner
Re: motor plate gaskets [Re: moparacer] #3144663
05/15/23 08:37 AM
05/15/23 08:37 AM
an8sec70cuda Offline
iagree No gaskets, just grey silicone. Been doing it like this since 2006 w/ no leaks ever.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: motor plate gaskets [Re: an8sec70cuda] #3144804
05/15/23 07:43 PM
05/15/23 07:43 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: motor plate gaskets [Re: Dartsport540] #3144955
05/16/23 11:40 AM
05/16/23 11:40 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Black or Grey RTV will seal it with no gaskets needed. Been doing ours that way for years with no issues
