Re: Hemi Headers in an Ebody
[Re: Chip]
#3144326
05/13/23 08:58 AM
05/13/23 08:58 AM
Posts: 12,037 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
WOW, what a way to post a question.
Anyway, I have always put my Hemis and trans in from the bottom as a complete unit. There is no room to do anything with headers otherwise. I don't know if it can even be done from the top because I have never even tried. It certainly seems like a much larger wrestling match dropping it in from the top.
Let us know how it goes.
Master, again and still
[Re: DaveRS23]
#3144328
05/13/23 09:07 AM
05/13/23 09:07 AM
Posts: 4,564 Motor City
6PKRTSE
Motor City
My is Slightly different. I have a tubular K frame with coil overs. I welded up my 4 piece Hooker Super Comp headers as on piece and can install them both at once from underneath with the engine installed.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Chip]
#3144337
05/13/23 09:55 AM
05/13/23 09:55 AM
Posts: 1,362 Out of the State of Confusion
blue_stocker
Are they really different from a B-body with the same OEM restrictions?
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: blue_stocker]
#3144455
05/13/23 07:55 PM
05/13/23 07:55 PM
Posts: 76 MASSACHUSETTS
Chip
MASSACHUSETTS
Are they really different from a B-body with the same OEM restrictions? Who makes thos headers blue-stocker?
[Re: 71birdJ68]
#3144480
05/13/23 09:20 PM
05/13/23 09:20 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
One thing no one has asked the OP is whether he is planning on 2 1/8" or 2 1/4" tubes. On my 2 1/4" TTIs, the lower row of bolts are an absolute pain to get to. Now, with his fender wells removed, it might be easier on the OP's car. But still around the shock tower could be a problem.
[Re: DaveRS23]
#3144483
05/13/23 09:30 PM
05/13/23 09:30 PM
blue_stocker
These are an older nos Hooker 2-1/8 race set I bought 4-5 years ago for a b-body project car I sold before moving to Tennessee. Ceramic coated, adjustable but the struts and primary tubes for lengthening didn't come with this set. Can't say how old they are but I can say it was before Hooker turned into crap mfg...these are very nice headers.
[Re: Chip]
#3144662
05/15/23 08:35 AM
05/15/23 08:35 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have the TTI 2.25" primary 4" collector headers on my '70 cuda. It has all stock front suspension and everything else. The passenger side header will go in the car after the motor is in. If you unbolt it, it will just about fall out of the car. Bolts aren't that bad to do from underneath the car. Had to do a little massaging to the top outer primary tube to clear the torsion bar ahead of the collector. The driver's side Needs to be in the car prior to the motor going in. Most of those bolts are easily done from up top. I do have a motorplate instead of factory mounts.
[Re: DaveRS23]
#3145218
05/17/23 09:26 PM
05/17/23 09:26 PM
Posts: 707 California
BigDaddy440
California
One thing no one has asked the OP is whether he is planning on 2 1/8" or 2 1/4" tubes. On my 2 1/4" TTIs, the lower row of bolts are an absolute pain to get to. Now, with his fender wells removed, it might be easier on the OP's car. But still around the shock tower could be a problem. I'm glad you brought this point up. I have a friend with an extra set of TTI 2.25" headers (#214s) for my 70 540" Hemi powered E body, but I'd like to run Hotchkis Torsion Bars and either a Firm-Feel or Borgeson steering box. I'm wondering if the 2.25's will work, or will I need to go with the TTI 2.125" versions... Anyone know or have experience with this? K Member is stock.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#3145385
05/18/23 07:06 PM
05/18/23 07:06 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
One thing no one has asked the OP is whether he is planning on 2 1/8" or 2 1/4" tubes. On my 2 1/4" TTIs, the lower row of bolts are an absolute pain to get to. Now, with his fender wells removed, it might be easier on the OP's car. But still around the shock tower could be a problem. I'm glad you brought this point up. I have a friend with an extra set of TTI 2.25" headers (#214s) for my 70 540" Hemi powered E body, but I'd like to run Hotchkis Torsion Bars and either a Firm-Feel or Borgeson steering box. I'm wondering if the 2.25's will work, or will I need to go with the TTI 2.125" versions... Anyone know or have experience with this? K Member is stock. Aren't those steering boxes smaller that the original power boxes? And the 'bars shouldn't matter. My block is a World iron and the 2 1/4 tubes are all over the stock power box. I slotted the box mounting holes so I could move the box over just a bit and dimpled the tube that was right up against the box. I also slid a piece of insolation between the tube and the box trying to reduce the heat in the box. Engine location is critical. My K is by Al Debevic.
