E-Body Brake Booster/Master Cylinder Replacement
#3144164
05/12/23 12:58 PM
05/12/23 12:58 PM
Posts: 2,331 Addison Twp, Mi.
RobG
Addison Twp, Mi.
My brakes system is soft. I want to replace these items, but on a budget. I am not worries about number matching parts - I like to drive my car all the time.
What would you recommend as a good replacement? Should I just order rebuilt components from my local auto parts store or is there a good specialty shop that won't break the bank?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: E-Body Brake Booster/Master Cylinder Replacement
[Re: 71birdJ68]
#3144297
05/13/23 03:11 AM
05/13/23 03:11 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Start with old school maintenance routine what type fluid? DOT 5 OVER time will do that. It is the worse as absorbs moisture. But all fluid can. So... Last was last time brakes were treated to a good bleeding? Manually adjust by you in rear if auto ones have not been doi g a good job. If calipers are no leak? Sticky ? If no to both you could still just get kits to do a look see. Clean, look see, and hone, clean, assemble. Some new parts are trash. I try to always refresh the ones I have now. (Ie) May be better and just do the needed maintenance or quick rebuild. Hey ya did it back when nothing was available, or to poor to get new! And with new stuff being junk to me it's the same [i][/i]as none offered. Maybe worse as you don't want to take better parts off than you are putting on. I rebuilt my calipers, but found NOS wheel cylinders, old stock master cylinder kit, and has been a long time but new rubber for booster and tested check valve. Could check and if need be Booster Dewy (so?) I am kinda an idiot but bought extra drums and rotors when i saw things getting out sourced. But you can find them good USA Raybestos, Bendix, etc good to get just to have and pads, shoes they don't eat food they just sit and wait.
[Re: 340SIX]
#3144314
05/13/23 07:29 AM
05/13/23 07:29 AM
RobG
Addison Twp, Mi.
Hello gents - here is more information that you requested:
WHen i push the brake pedal, I am getting a "wooosh" sound - as if the brake booster is leaking. I am also seeing a leak in the master cylinder seals. The pedal is going almost all the way down when the car stops.
I can bleed the brakes and flush the system - that hasn't been done in 20 years, but I believe the booster is the main issue on the front disc/rear drum setup on mu Cuda. As hard as I try, I cannot get the brakes to lock-up..
Re: E-Body Brake Booster/Master Cylinder Rplacement
[Re: Greentween]
#3144655
05/15/23 07:42 AM
05/15/23 07:42 AM
RobG
Addison Twp, Mi.
So who has a good booster at a reasonable price? What remanufactured units do you think are good?
[Re: RobG]
#3144680
05/15/23 09:42 AM
05/15/23 09:42 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3147301
05/28/23 07:47 PM
05/28/23 07:47 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
If it were me I would rebuild your the booster you have rather than buying one from a local auto parts store. I believe these guys can rebuild it. (IF you do determine it is the booster.) https://www.powerbrakebooster.com/I haven't had good luck with new after market parts but that is just my experience.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
