8-3/4 into F body? #3141895
05/02/23 01:02 AM
05/02/23 01:02 AM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
Which one would be the proper width, 70 B body?
Thanks! wave
Re: 8-3/4 into F body? [Re: slantzilla] #3141902
05/02/23 02:55 AM
05/02/23 02:55 AM
I think the NHRA stocker guys use to use 1967 to 1972 A body 8 3/4 for their Volare and Aspens twocents scope shruggy
Re: 8-3/4 into F body? [Re: Cab_Burge] #3141909
05/02/23 06:56 AM
05/02/23 06:56 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Friend put a late 60s C body rear in his.
Re: 8-3/4 into F body? [Re: moparjim79] #3141954
05/02/23 11:00 AM
05/02/23 11:00 AM
west palm beach, florida
modelmakerinc Offline
66 or 67 B Body. spring pads are > 1" difference from stock. the slop in the bushings and chassis allow a direct bolt in without modifying the axle. You need to remove the leaf spring isolators too, i used my stock F body main leaf and added the spring pack from a 67 BB B body with a new through bolt
here's my build little info on the rear though https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2116859/1.html
15x10 3.5" backspace 295 50 15 tires.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 8-3/4 into F body? [Re: modelmakerinc] #3141975
05/02/23 12:13 PM
05/02/23 12:13 PM
Park Forest, IL
Park Forest, IL
Thanks for the replies. beer
Re: 8-3/4 into F body? [Re: slantzilla] #3142142
05/02/23 10:17 PM
05/02/23 10:17 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I also used a 66-67 B body rear in my 80 F body with the same year B body main leaf and the balance of leaves coming from SS packs. These years are 59.5" wide. 68-70 are 60.125". This may create possible fender lip interference depending on your choice of wheel and tire. I also dumped all the iso-clamp system for conventional spring eyes and shock mounts.
I had 15x8 Dragstars with 4.5" backspace and a 295/65x15 tire. Had to severely roll and hammer the fender lip up and it would still kiss the edge of the tire on dips. You can see the thin shiny streak on the shoulder in the pic below.
Re: 8-3/4 into F body? [Re: TC@HP2] #3142156
05/03/23 12:26 AM
05/03/23 12:26 AM
5thAve Offline
5thAve  Offline
Yep those B body ones are the closest. One of my Ms has 255-60 tires on it's 8 3/4 that fit no problems, might be an issue if the springs are sagging,
Re: 8-3/4 into F body? [Re: 5thAve] #3142161
05/03/23 04:14 AM
05/03/23 04:14 AM
Missouri
70X Offline
70X  Offline
Missouri
We put a 70 B Body housing into a 78 Aspen with no problems, set right on pads
Re: 8-3/4 into F body? [Re: slantzilla] #3142268
05/03/23 12:42 PM
05/03/23 12:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's info somebody posted before:
Factory axle dimensions (7.25" and 8.25") for all F/J/M cars:
•Housing flange to flange: 54.34"
•Perch center to perch center: 44.46"
Here's the '65-'67 B-body specs:
-Housing flange to flange: 54 1/4"
-Perch centers: 44"
Re: 8-3/4 into F body? [Re: John_Kunkel] #3142279
05/03/23 01:17 PM
05/03/23 01:17 PM
iagree the 66 67 B body is as close to a straight up swap as possible to the F body.
Re: 8-3/4 into F body? [Re: modelmakerinc] #3142289
05/03/23 02:29 PM
05/03/23 02:29 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
If you still run the ISO setup then you can use a 1 9/16" hole saw to open the spring perch to accept the locating pin and rubber isolator combination. Just bolt a plate to the underside of the spring perch so the arbor has something to bite into.
Re: 8-3/4 into F body? [Re: MarkZ] #3142611
05/04/23 10:55 PM
05/04/23 10:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can move the springs far enough a 66-70 B body bolts right in. If you are worried about the slight perch difference? Move the rear shackle hangers. Pull the bumper with its supports. You can drill new holes in the frame rail and mount the shackle inward and forward if you like. Each drum will be 5/16" further toward the outside. Using a 727? A 727 driveshaft from a Duster fits perfect.
Doug
Re: 8-3/4 into F body? [Re: dvw] #3142731
05/05/23 07:44 PM
05/05/23 07:44 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I used a 68 B body 8 3/4 in my Mirada. It was slightly narrower than original 7 1/4 but pretty close. I got rid of the iso stuff at the same time, but it went on the springs no problem. I know on paper there's about 1/4" difference per side but as I remember I ddint have to force anything at all.
I had 275/60's on 7 " cop wheels at first but the 4 1/4" backspace put the side wall very close to the inner wheel wells. 8" wheels with a 4" backspace fit a lot better.
