Re: 8-3/4 into F body?
[Re: slantzilla]
#3141902
05/02/23 02:55 AM
05/02/23 02:55 AM
Posts: 43,248 Bend,OR USA
Cab_Burge
[Re: slantzilla]
#3142268
05/03/23 12:42 PM
05/03/23 12:42 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's info somebody posted before:
Factory axle dimensions (7.25" and 8.25") for all F/J/M cars:
•Housing flange to flange: 54.34"
•Perch center to perch center: 44.46"
Here's the '65-'67 B-body specs:
-Housing flange to flange: 54 1/4"
-Perch centers: 44"
[Re: modelmakerinc]
#3142289
05/03/23 02:29 PM
05/03/23 02:29 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
If you still run the ISO setup then you can use a 1 9/16" hole saw to open the spring perch to accept the locating pin and rubber isolator combination. Just bolt a plate to the underside of the spring perch so the arbor has something to bite into.
[Re: MarkZ]
#3142611
05/04/23 10:55 PM
05/04/23 10:55 PM
Posts: 9,863 MI, usa
dvw
MI, usa
You can move the springs far enough a 66-70 B body bolts right in. If you are worried about the slight perch difference? Move the rear shackle hangers. Pull the bumper with its supports. You can drill new holes in the frame rail and mount the shackle inward and forward if you like. Each drum will be 5/16" further toward the outside. Using a 727? A 727 driveshaft from a Duster fits perfect. Doug
