Best way to install torsion bars #3142085
05/02/23 07:11 PM
05/02/23 07:11 PM
illinois
bigblk66_coronet Offline OP
illinois
and trans back in my 66 Coronet from the bottom. First time I've even done it this way. My question is when i go to put the torsion bars back in do i put them in before i reattach the upper ball joints or do they go in after i attach the upper ball joints.? Just need some pointers on how to go about this the right way. Thanks.
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: Best way to install torsion bars [Re: bigblk66_coronet] #3142089
05/02/23 07:29 PM
05/02/23 07:29 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I'm no expert, but I took mine off before and reinstalled them after. Maybe there is a better way, but it worked for me.
Re: Best way to install torsion bars [Re: bigblk66_coronet] #3142093
05/02/23 07:45 PM
05/02/23 07:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Before.
You may need plenty of rotation on the forward socket in order to get the T'bar installed. Then you can simply use a floor jack to get the spindle into the top ball joint.
Another tip for torsion bars that fight you to get in or out is to get a 1" steel rope clamp and use it to hammer on when getting the T'bar into or out of place.
Master, again and still
Re: Best way to install torsion bars [Re: DaveRS23] #3142114
05/02/23 08:50 PM
05/02/23 08:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by DaveRS23
Before.
I made this a while ago for torsion bar removal and installation, with a nice place to hit with a hammer or mallet. Works like a charm.
Mike
Re: Best way to install torsion bars [Re: bigblk66_coronet] #3142124
05/02/23 09:28 PM
05/02/23 09:28 PM
Back the torsion bar bolt adjusters out all the way if you haven't done that already and then crank, pull, down on the lower control arm to help slide the end of the torsion bar into its hole before thinking of hooking up the spindle to the upper arm twocents shruggy
Re: Best way to install torsion bars [Re: bigblk66_coronet] #3142265
05/03/23 12:34 PM
05/03/23 12:34 PM
IMGTX Offline
IMGTX  Offline
You want the lower control arm to rotate so like Cab said back out the adjusters all the way but don't remove the bolts, leave them threaded in the arm.
Make sure the shock is disconnected and the pivot nut is loose.
Make sure the Lower Ball joint, Upper Ball joint OR Upper control arms pivots are disconnected. Any of the three will work to give you the ability to rotate the Lower arm enough to get the T-bar in.
If you have the brakes and spindle connected to the LCA it helps to have a jack under the LCA to support the weight.
I grease both sockets and the ends of the bar. More for corrosion protection than lubrication. IIRC the service manual says to.
Insert the Tbar into position with the rear hex sticking out of the rear of the transmission crossmember. I usually have the LCA completely loose and slip the LCA on the front of the Tbar then slide them into the K-Frame as an assembly but since your LCA is still holding the brakes and spindle slide the Tbar in from the back (Transmission Crossmember) may be the best option.
Rotate the LCA by hand or jack until you can slide the T-bar into the LCA and the transmission crossmember. I will often use a rubber mallet to coax it in at the back.
Once it is engaged on both ends I use a mallet and wood dowel (don't want to scratch or ding the bar) to drive the bar in at the back.
Old Broom handles work great. Once you can get the clip in the socket you are done.
Jack up he LCA, connect the Ball joint & Shock.
Set the ride height and then while the suspension is still on the ground tighten the LCA pivot.
Hope it helps
Re: Best way to install torsion bars [Re: IMGTX] #3142388
05/03/23 09:13 PM
05/03/23 09:13 PM
illinois
illinois
thanks man thats a huge help!
Re: Best way to install torsion bars [Re: bigblk66_coronet] #3142478
05/04/23 11:13 AM
05/04/23 11:13 AM
IMGTX Offline
IMGTX  Offline
One thing I forgot to mention is that if you install the LCA on the end of the Tbar and slide them in as an assembly. Do not forget the Strut Rod. DAMHIK. LOL
That technique is better with a bare LCA with nothing attached like the brakes and such.
Re: Best way to install torsion bars [Re: IMGTX] #3142511
05/04/23 01:57 PM
05/04/23 01:57 PM
You only do that once, usually wrench whistling shruggy
Re: Best way to install torsion bars [Re: A12] #3142519
05/04/23 02:21 PM
05/04/23 02:21 PM
Macomb, MI
V
vinnyd76 Offline
vinnyd76  Offline
V
Macomb, MI
Before.
Mike
Here is a tool I purchased from Mancini to assist with torsion bar removal/install.
Mancini Racing Torsion Bar Removal/Install Tool
Re: Best way to install torsion bars [Re: vinnyd76] #3142568
05/04/23 08:02 PM
05/04/23 08:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Rope clamps are $7 or $8 a piece.
Re: Best way to install torsion bars [Re: DaveRS23] #3142591
05/04/23 09:41 PM
05/04/23 09:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That's what I made mine with up
