Best way to install torsion bars
#3142085
05/02/23 07:11 PM
05/02/23 07:11 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
and trans back in my 66 Coronet from the bottom. First time I've even done it this way. My question is when i go to put the torsion bars back in do i put them in before i reattach the upper ball joints or do they go in after i attach the upper ball joints.? Just need some pointers on how to go about this the right way. Thanks.
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Best way to install torsion bars
[Re: bigblk66_coronet]
#3142093
05/02/23 07:45 PM
05/02/23 07:45 PM
Posts: 12,096 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Before.
You may need plenty of rotation on the forward socket in order to get the T'bar installed. Then you can simply use a floor jack to get the spindle into the top ball joint.
Another tip for torsion bars that fight you to get in or out is to get a 1" steel rope clamp and use it to hammer on when getting the T'bar into or out of place.
Master, again and still
[Re: DaveRS23]
#3142114
05/02/23 08:50 PM
05/02/23 08:50 PM
Posts: 21,513 N.E. OHIO, USA
A12
N.E. OHIO, USA
Before.
Another tip for torsion bars that fight you to get in or out is to get a 1" steel rope clamp and use it to hammer on when getting the T'bar into or out of place. I made this a while ago for torsion bar removal and installation, with a nice place to hit with a hammer or mallet. Works like a charm. Mike
[Re: IMGTX]
#3142388
05/03/23 09:13 PM
05/03/23 09:13 PM
bigblk66_coronet
illinois
thanks man thats a huge help!
440w/727
[Re: A12]
#3142519
05/04/23 02:21 PM
05/04/23 02:21 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Before.
Another tip for torsion bars that fight you to get in or out is to get a 1" steel rope clamp and use it to hammer on when getting the T'bar into or out of place. I made this a while ago for torsion bar removal and installation, with a nice place to hit with a hammer or mallet. Works like a charm. Mike Here is a tool I purchased from Mancini to assist with torsion bar removal/install. Mancini Racing Torsion Bar Removal/Install Tool
[Re: vinnyd76]
#3142568
05/04/23 08:02 PM
05/04/23 08:02 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Rope clamps are $7 or $8 a piece.
