rb blocks #314152
05/10/09 09:09 PM
05/10/09 09:09 PM
usa
hot67cuda Offline OP
usa
Stud girdles and allum main caps DO THEY WORK?They look like a good ideal.Any body have real would exp?I'll be making a little over 800 hp this year just curious.
Re: rb blocks [Re: hot67cuda] #314153
05/10/09 11:57 PM
05/10/09 11:57 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Yes they do work as the main girdle cap combo I make is now 90% of what I sell. I have hundreds of these kits out there and most are in the 650-850 hp range. Feedback has been very favorable and it was some experts on this board who helped design and make this kit pretty much the standard by which all others are judged. Give me a call anytime and I can help you out---Greg
www.bcrproducts.com
Re: rb blocks [Re: bcrproducts] #314154
05/10/09 11:58 PM
05/10/09 11:58 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Here is a set on a block
Re: rb blocks [Re: hot67cuda] #314155
05/11/09 04:17 PM
05/11/09 04:17 PM
I have seen and owned several RB blocks that cracked the main webs at less than 700 hp, I won't build a stock block to exceed 700 HP any more. Get yourself a good aftermarket block that has thick main webs, four or six bolts main caps and thick cylinder walls to start with instead of trynig to band aid a stock block
Re: rb blocks [Re: Cab_Burge] #314156
05/11/09 08:23 PM
05/11/09 08:23 PM
Texas, USA
68cuda2003 Offline
68cuda2003  Offline
Texas, USA
stupid question I guess, but I have been wondering for a while now... is it still recommended to run a girdle with an aftermarket block? thanks for the response.
Re: rb blocks [Re: 68cuda2003] #314157
05/11/09 09:59 PM
05/11/09 09:59 PM
The good aftermarket blocks probally don't need a girdle due to the engineering on increasing the strength and the better materials used in them. If you can swing buying a Compacted Graphite Iron block that is the way to go if your wanting the best cast iron block out there The high nickel blocks(Koffels sells) are better than the regular aftermarket cast grey iron blocks like the World and probally the Indy blocks. All the after market blocks are way better than the stock production blocks
