Starter lug 90 degree adapter? #3140588
04/25/23 09:50 AM
04/25/23 09:50 AM
Port Huron, Michigan
MI_Custumz Offline OP
Does anyone know if there are 90 degree adapters for a Chevy 350 starter for the positive battery cable? I replaced the cables yesterday and the way it is mounted now, I want to redo it. It runs where it is supposed to until it gets to the starter. The cable has the flat end on it and runs on the outside of the starter on the header side. It's right against the starter, but would rather it run towards the block or along the starter the other way. I had it mounted towards the block, but the terminal end was touching the other lug on the solenoid and would jump the solenoid that way. I couldn't get it up at an angle to avoid touching the other lug. Any advice? I really don't want to spend the money on a new cable. Not sure if extending it out would be an option either. I believe the threads are 7/16.
Re: Starter lug 90 degree adapter? [Re: MI_Custumz] #3140626
04/25/23 12:52 PM
04/25/23 12:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Starter lug 90 degree adapter? [Re: MI_Custumz] #3140755
04/25/23 11:15 PM
04/25/23 11:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
They do make 90 degree battery cable lugs wink
Re: Starter lug 90 degree adapter? [Re: stumpy] #3140766
04/26/23 06:24 AM
04/26/23 06:24 AM
Those may work. I didn't realize it was able to be separated to use individual parts.
Re: Starter lug 90 degree adapter? [Re: TJP] #3140767
04/26/23 06:25 AM
04/26/23 06:25 AM
I'm sure they do. But I would rather not cut the cable.
Re: Starter lug 90 degree adapter? [Re: MI_Custumz] #3141131
04/28/23 06:28 AM
04/28/23 06:28 AM
Ended up dropping the starter and mounting the battery cable on an angle where it cleared the S terminal on the solenoid. Little harder getting the ignition wire on it that way, but it worked. Will keep the adapter saved for future reference.
