Bigger oil pan for 360 in early 1963/1966 A bodies #3137848
04/13/23 11:16 PM
04/13/23 11:16 PM
Cab_Burge Offline OP
I'm looking for a larger capacity center sump oil pan for a 360 motor in my 1965 Valliant, I'm hoping for a bolt in and no fabricating or modifying one help
Barnd and part numbers will be appreciated, thanks in advance: Cab
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: Cab_Burge] #3137862
04/14/23 02:24 AM
04/14/23 02:24 AM
NY
B1duster Online content
B1duster  Online Content
NY
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: B1duster] #3137864
04/14/23 02:42 AM
04/14/23 02:42 AM
Thanks up Cab
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: Cab_Burge] #3137865
04/14/23 05:21 AM
04/14/23 05:21 AM
MD
1965fish Offline
1965fish  Offline
MD
I put that pan in my 65' Valiant wagon and had to notch the K frame a little.
1965 Plymouth Barracuda Formula S
1965 Plymouth Valiant 200 Convertible
1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104
2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile
1965 Plymouth Valiant Signet 2DR HT
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: 1965fish] #3137904
04/14/23 09:13 AM
04/14/23 09:13 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I bought mine from here, nice quality and customer service is great ..
https://kevkoracing.com/collections/mopar-oil-pans-1
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: 1965fish] #3137976
04/14/23 02:30 PM
04/14/23 02:30 PM
I'm good with notching the K member a little sawzall weld upgrin
Was your car a 273 C.I. V8 or slant six car originally? The reason I'm asking is the steering linkage between the pitman arm on the steering box and the idler arm, my car is a slant six car and I've heard on here that the 273 V8 cars had a different bent, curve steering drag link on them confused help
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: Cab_Burge] #3138025
04/14/23 06:06 PM
04/14/23 06:06 PM
NY
NY
I believe you’re gonna need a V8 draglink. 63-65 had different links for 6cyl and v8.
In 66 they all had the V8 link, with a 6 or 8
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: Cab_Burge] #3138054
04/14/23 09:12 PM
04/14/23 09:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Can’t remember but the 67 and up were the same. We stuck a 340 in a 65 valiant that had a /6 and only thing different was the converter hub size that went into the crank (we had a ring made) no issue with drag link iirc.
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: B1duster] #3138064
04/14/23 10:13 PM
04/14/23 10:13 PM
NY
NY
Here you go. Top is /6 63-65, Bottom is 63-65 v8 & in 66 /6 and v8
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: B1duster] #3138140
04/15/23 08:52 AM
04/15/23 08:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
We probably had a 66 then
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: B1duster] #3138190
04/15/23 12:17 PM
04/15/23 12:17 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
The shallow one did come on some slant 6 '66 cars. I took that photo and the top one was off my slant 6 '66 Dart. I think '66 was just a weird year, with some slants coming with the shallow link and some coming with the dropped link. Maybe the factories were just using old stock they had on hand?
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: mopowers] #3138221
04/15/23 01:47 PM
04/15/23 01:47 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My '66 had the shallow link on it. Who knows if it was original or not. I'd never heard of the '66 all getting the deep bar before.
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: slantzilla] #3138227
04/15/23 02:25 PM
04/15/23 02:25 PM
NY
NY
https://www.classicindustries.com/product/1966/dodge/dart/parts/ml4249.html
I’m not sure where I read that, but I have a 66 dart /6 and I’ll take a look.
I hope I’m right. Check out the price of a repro
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: B1duster] #3138271
04/15/23 05:10 PM
04/15/23 05:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Wow could fine a junker for that price
Re: Bigger oil pan for 360 in early 1963/1966 A bodies [Re: cudaman1969] #3138304
04/15/23 06:59 PM
04/15/23 06:59 PM
B1duster, yes thats the pic I found but it said too big to move. yeah for that price I shoulda grabbed that one for $150 I saw awhile back! from what I understand they used some V8 ones on /6 cars depending on what was in stock on the assy line at the time especially in '66. No harm no foul. RR
