Callies wedge block pushrod clearanceRB block #3137295
04/12/23 04:16 AM
04/12/23 04:16 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Hello, I'm mocking up my new Callies block with Indy -1 heads and T&D rockers. Going to be a 511 cu in pump gas bracket engine. It quickly became rather obvious I'm going to have to do some major machining to the block for pushrod clearance. Indy says they have a CNC program but no pics. Would anyone happen to have a pic of the lifter valley after machining?
Re: Callies wedge block pushrod clearanceRB block [Re: 10sec440] #3137298
04/12/23 07:14 AM
04/12/23 07:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This is an old Mopar Mega block. But it's been lightened up including cutting the lifter valley. It originally was purchased as a short block from Indy by a friend. So I'm assuming it was their program
Doug
Re: Callies wedge block pushrod clearanceRB block [Re: dvw] #3137381
04/12/23 01:47 PM
04/12/23 01:47 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't have exactly the pic you want. But if you look at the Cometic gasket in the pic above, and on my pic...
I had 440-1 CNC 345 heads on a KB aluminum block (so ignore the block). Look at the tracing of the Cometic gasket, the tracing of the 440-1 head, and the location of the head bolt hole. I labeled the area that needed cutting. You don't have to remove everything like the Indy program (for lighter weight), but you may (likely) have some clearance work on the valley wall also.
Re: Callies wedge block pushrod clearanceRB block [Re: 440Jim] #3137395
04/12/23 02:41 PM
04/12/23 02:41 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I'm diggin the shade of orange on that block.
2011 Drag Pak Challenger
Re: Callies wedge block pushrod clearanceRB block [Re: 10sec440] #3137456
04/12/23 05:12 PM
04/12/23 05:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Pushrod clearance in the block & head is affected by PR diameter (duh) but also how much oscillating movement is present at the PR top with the short (PR side) rocker arm lever.
If you're going to open the holes, the new shape must of course allow the larger diameter, but a greater sweep at the RA is not a larger hole diameter, but a "stadium" shape: a circle @ correct OD, expanded with parallel sides.
Boffin Emeritus
Re: Callies wedge block pushrod clearanceRB block [Re: polyspheric] #3137541
04/12/23 10:43 PM
04/12/23 10:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I should add mine runs -1 heads and 7/16" push rods.
Doug
Re: Callies wedge block pushrod clearanceRB block [Re: dvw] #3137559
04/12/23 11:31 PM
04/12/23 11:31 PM
Doug
Straight or tapered?
Re: Callies wedge block pushrod clearanceRB block [Re: Cab_Burge] #3137647
04/13/23 08:14 AM
04/13/23 08:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
They are tapered at both ends. But not far enough that it alters block clearance. I did have to gring just a little on the heads for the intakes. It uses offset intake cups in the lifters as well.
Doug
Re: Callies wedge block pushrod clearanceRB block [Re: dvw] #3137751
04/13/23 03:30 PM
04/13/23 03:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Doug,
I think you and I are both running the Comp Cams 7/16" pushrods. 0.165" wall thickness.
This is where the taper is (both ends).
Re: Callies wedge block pushrod clearanceRB block [Re: dvw] #3137758
04/13/23 03:57 PM
04/13/23 03:57 PM
I like and use Manton pushrods for all my builds due to them making them when I order them. They don't have any shelf pushrods, all custom made when ordered.
The series 5 are my choice for race roller cam motors, I've seen 8 HP gain above 5000 RPM with no other changes than swapping out a set of Smith Bros,. 3/8x.120 wall to an Identical set of Mantons boogie up Ph.# 951-245-6565
I am a dealer for them and I can save you a little money on them, no a bunch, sorry blush They will drop ship them directly to you if you order them from me: Cab
Re: Callies wedge block pushrod clearanceRB block [Re: Cab_Burge] #3137768
04/13/23 04:27 PM
04/13/23 04:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Run as large(diamter) a pushrod as your wallet can afford. It does not matter in weight to the valvetrain but flex IS an issue. How much depends on spring pressure and cam ramps. Of course as you go up in diameter clearance becomes more necessary.
Re: Callies wedge block pushrod clearanceRB block [Re: 440Jim] #3137838
04/13/23 10:01 PM
04/13/23 10:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by 440Jim
Doug,
The shape is the same. But mine are steel color, not black. There is no name on them. Just length, diametre, and wall thickness numbers that look like yours. I was told they are Trend. I purchased them used with the heads and T&D paired rockers when I built the car in 2012.
Doug
