'69 RR 383 auto if it's real it's a bargain #3133311
03/29/23 02:06 PM
03/29/23 02:06 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Facts are stubborn things.
Re: '69 RR 383 auto if it's real it's a bargain [Re: larrymopar360] #3133377
03/29/23 04:02 PM
03/29/23 04:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hmm...guess it was Spring Green with V21.
Green dash - or just the pads ? - but apparently a black interior is a curiosity.
Also, if that was rust at the quarters, I wouldn't expect that on a car from Citrus Hts.
Could just be body damage, but for the area at the rt rocker seam.
Left fender appears to have been bondo'd at some point.
Might not take too much to make it a half-decent driver.
Sure needs a more descriptive ad.
Re: '69 RR 383 auto if it's real it's a bargain [Re: topside] #3133418
03/29/23 05:29 PM
03/29/23 05:29 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Wouldn’t those plates indicate it didn’t start in ca? 80s plates?
I want my fair share
Re: '69 RR 383 auto if it's real it's a bargain [Re: SomeCarGuy] #3133435
03/29/23 06:36 PM
03/29/23 06:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That used to be the case, but God only knows what their DMV does now.
Sometimes even years ago a clerk would insist on a new plate.
The car's original plate - if it originated new in CA - would be very late in the alphabet for black plates, or very early for the blue.
I had '69s that started with Y & Z (black) and A (blue).
Re: '69 RR 383 auto if it's real it's a bargain [Re: topside] #3133477
03/29/23 08:17 PM
03/29/23 08:17 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'm guessing floors are rusted. To what extent??? But the price is low enough to repair them. Trunk looks good. Grille looks real good. Looks like the original tail pipes still there. Engine compartment looks good and unsilenced air cleaner there, original radiator. Painted at one time under hood? Looks like wires to ballast resistor might have paint on them. Car looks somewhat unmolested. I wish it was close to me, it really deserves a look at this price and I love 727/column shifts.
Re: '69 RR 383 auto if it's real it's a bargain [Re: larrymopar360] #3133544
03/30/23 07:25 AM
03/30/23 07:25 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I like it.
Earning every penny of that moderator paycheck.
DBAP
Re: '69 RR 383 auto if it's real it's a bargain [Re: not_a_charger] #3133703
03/30/23 06:00 PM
03/30/23 06:00 PM
Germany
fc7_plumcrazy Offline
Germany
I like it, too
Carsten
Re: '69 RR 383 auto if it's real it's a bargain [Re: fc7_plumcrazy] #3133710
03/30/23 06:28 PM
03/30/23 06:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Spring Green with green interior.
Looks like a solid car with some potential to be a decent driver.
If I was a painter, I would sure make a stab for it .
But my gut the car is long gone and the add will stay till its expires.
Re: '69 RR 383 auto if it's real it's a bargain [Re: gtx6970] #3133752
03/30/23 09:49 PM
03/30/23 09:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Look again at the interior: signs of green dash pads under black, but the rest of the interior appears to be original black.
Maybe the pads were replaced & re-dyed/repainted due to damage, or ???
Re: '69 RR 383 auto if it's real it's a bargain [Re: topside] #3133825
03/31/23 09:40 AM
03/31/23 09:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I saw the green peeking out from under the dye black paint on the dash pads.
Keep in mind seat covers and door panels have ben avail for many many years . So its very likely the seats and door panels have been recovered, OR ( most likely scenario ) switched from another car altogether.
Without seeing a data tag and / or the car in person ,. Its hard to say which is correct . But my money is the interior in that car is not the original interior to that car
Re: '69 RR 383 auto if it's real it's a bargain [Re: gtx6970] #3133828
03/31/23 09:50 AM
03/31/23 09:50 AM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
So then the Headliner plus the surrounding parts must have been changed/dyed to.
Anyway, I like it alot and it would be interesting to see what was the original interior color.
Re: '69 RR 383 auto if it's real it's a bargain [Re: SuperRob] #3134012
03/31/23 06:59 PM
03/31/23 06:59 PM
Germany
Germany
go ahead and ask for the fender tag, Rob
Carsten
Re: '69 RR 383 auto if it's real it's a bargain [Re: SuperRob] #3134013
03/31/23 06:59 PM
03/31/23 06:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Its 50 years old and A LOT can happen in that time.
As an example.
About 30 - 35 years ago a friend of mine in northern Ky bought and flipped a red with red interior 1970 Cuda 440 six barrel auto car.
The kid that bought it ( he was maybe early - mid 20s at the time ) , went to the local auto parts store and bought A LOT of black vinyl die and sprayed the entire interior black before it left the shop. The Glass and inst cluster was taped off with news paper to keep most of it off the glass . Seats and door panels were pulled and layed in the gravel driveway and rattle caned it all black. Including the carpet and console . Then any overspray was cleaned up with a razor blade and lacquer thinner. 100% true story. I watched him do it and was in shock. As I m a sucker for red interior cars
When he drove it away it was now red with black interior. And was a real deal V code console auto car . I wish I knew where that car was today. No idea where it ended up as I never saw it again
It was a factory shaker car, but Jim kept the shaker and all its components. Switched it with another hood from a red cuda parts car
As far as I know Jim still has all the shaker stuff in his basement
Re: '69 RR 383 auto if it's real it's a bargain [Re: fc7_plumcrazy] #3134014
03/31/23 07:09 PM
03/31/23 07:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Carsten
I just sent seller a message for just that and if the car is still avail
Re: '69 RR 383 auto if it's real it's a bargain [Re: gtx6970] #3134054
03/31/23 09:52 PM
03/31/23 09:52 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
says it's sold. i liked it too1
KID
Re: '69 RR 383 auto if it's real it's a bargain [Re: Kidsixpack] #3134104
04/01/23 08:42 AM
04/01/23 08:42 AM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
The same person has a Challenger for sale for the same price and color?
https://www.facebook.com/marketplac...lace_profile&referral_code=undefined
1970 Duster 340 clone
Re: '69 RR 383 auto if it's real it's a bargain [Re: BrianT] #3134559
04/02/23 07:28 PM
04/02/23 07:28 PM
Germany
Germany
I would have taken the RR anyday over the 73 Challenger
Re: '69 RR 383 auto if it's real it's a bargain [Re: fc7_plumcrazy] #3134800
04/03/23 03:11 PM
04/03/23 03:11 PM
Davis, California, USA
MrBelvedere2 Offline
This car was for sale for about 2 or 3 weeks, if i had the extra $$ I would of bought it. Looks like someone did scoop it up and is now trying to flip it for 29k on CL.
https://sacramento.craigslist.org/cto/d/rancho-cordova-1969-plymouth-roadrunner/7606189393.html
1965 Plymouth Belvedere II hardtop
Re: '69 RR 383 auto if it's real it's a bargain [Re: MrBelvedere2] #3134807
04/03/23 03:26 PM
04/03/23 03:26 PM
Went from being a good deal to not a good deal.
DBAP
Re: '69 RR 383 auto if it's real it's a bargain [Re: not_a_charger] #3134867
04/03/23 07:17 PM
04/03/23 07:17 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
That was really my kind of RR. I love the '69 grille. I love the plane jane look and column shift. Priced great and unmolested (relatively speaking). I'd have driven mostly as is. Just no room for another right now.
