Recurving a points distributor help. #313247
05/09/09 09:54 PM
05/09/09 09:54 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Can someone either point me to a great shop that can
recurve my distributor in the Minneapoiis area
or send me a link on how to limit total on the one
I currently have please? My car runs awesome at
18 before, but that puts me into the 40's total
and I go knock, knock,knock. Not good for engine
life!
Re: Recurving a points distributor help. [Re: Dart 340] #313248
05/09/09 10:03 PM
05/09/09 10:03 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Do a search on here going back about a year, I can't remember who it was that posted but there is a chart that shows how long the slots need to be for the desired mechanical advance... Great thread with pics and all.
Darren
Re: Recurving a points distributor help. [Re: Ludington1] #313249
05/09/09 10:09 PM
05/09/09 10:09 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
What are the specks on your engine?
I got a dizzy machine, and am willing set up a distibuter for you.
Convx4@yahoo.com
Re: Recurving a points distributor help. [Re: Dart 340] #313250
05/09/09 10:14 PM
05/09/09 10:14 PM
Can you take out the center clip & dissassemble it to weld/shorten the slots and if you have a spare dist w good bushings you could prep it & get it ready to drop in & minimize your downtime. What eng is this.
Re: Recurving a points distributor help. [Re: RapidRobert] #313251
05/10/09 12:12 AM
05/10/09 12:12 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Re: Recurving a points distributor help. [Re: hooziewhatsit] #313252
05/10/09 12:16 AM
05/10/09 12:16 AM
thank you
Re: Recurving a points distributor help. [Re: convx4] #313253
05/10/09 01:05 AM
05/10/09 01:05 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I didn't build it so I cannot tell you exactly
what compression ration is, but compression test
is about 185 psi. Cam is eddy Performer RPM, intake
is eddy air gap RPM, and bouncing back and forth
between 3310 750 and a 670 street avenger.
A833 trans. The current disty doesnt seem to bring
in all advance until well above 4K
Re: Recurving a points distributor help. [Re: Dart 340] #313254
05/10/09 01:36 AM
05/10/09 01:36 AM
proably has the orig light spring & the heavyone with the long loop on one end. Definitely open it up,clean everything & change them/shorten the slots
Re: Recurving a points distributor help. [Re: RapidRobert] #313255
05/10/09 07:07 AM
05/10/09 07:07 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
As RR said it sounds like you need to shorten the slots a bit. Also try just removing the heavy spring and running with just the remaining one lite spring. That should give you full advance around 2200 or so. Dave
Re: Recurving a points distributor help. [Re: quickd100] #313256
05/10/09 10:21 AM
05/10/09 10:21 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I'm pretty good with a welder so I can give it a
shot to shorten them up I guess.
That would explain why it runs soooo good with about
18 advance and pretty much all the time. Only time
I noticed the knock was under really heavy load, which was very seldom, or all out pedal on the floor. I was shocked to see it still advancing at way above 4K. I have a timing tape on the balancer
too for what it's worth.
Isn't all in by 2200 kind of low? I am guessing
a max of about 38 should keep me safe?
Re: Recurving a points distributor help. [Re: Dart 340] #313257
05/10/09 10:38 AM
05/10/09 10:38 AM
(1) no (2) small block? 35 total wo the vac adv connected is a good baseline. ANY ping you can hear back it off more until you can put in a heavier spring/and or less initial.
Re: Recurving a points distributor help. [Re: RapidRobert] #313258
05/10/09 10:55 AM
05/10/09 10:55 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Robert,
I dropped initial back down to 10 before, sure
hurts performance, but not the motor for now. The
car actually runs like 10-15 degrees hotter too!
Thanks for your help.
