Thoughts on stripping the finish off rally wheel center caps #3131170
03/21/23 04:47 PM
03/21/23 04:47 PM
VA
AtomicDog Offline OP
VA
I have some old large bolt pattern acorn style rally wheel center caps (see photo) that I'd like to have stripped and powder coated. I tried bead blasting them and using EZ-Off oven cleaner to remove the existing coating off the center caps, but I'm not having any success. Any ideas as to what I can use to remove this tough, old-school coating/finish off these center caps?
CenterCap
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131185
03/21/23 05:55 PM
03/21/23 05:55 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
If the stuff is really stuck on there then just feather out any chips or rough edges with some sandpaper and repaint right over it.
I would just stick with paint instead of powder coating if it were me.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: Neil] #3131210
03/21/23 07:49 PM
03/21/23 07:49 PM
VA
VA
The finish (what's left of it) is on there really good. I really want to dissolve what's there, so that I can have the center caps powder coated, as I have a good source for a powder coater available to me. He just powder coated & UV coated my rally wheels and they came out excellent.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131245
03/21/23 09:09 PM
03/21/23 09:09 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Good Heat Gun & Scrapper.
Then some lacquer thinner to clean up.
You may want to scuff up any surfaces to be power coated.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: PhillyRag] #3131270
03/21/23 10:17 PM
03/21/23 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Propane torch? don't get them too hot though,
What kind of media were you using and at what pressure? If you were closer I might give them a pass in my blast cabinet beer
Re: Thoughts on stripping the finish off rally wheel center caps [Re: TJP] #3131288
03/21/23 11:17 PM
03/21/23 11:17 PM
VA
VA
I used 80-100 grit glass beads in a large SkatBlast cabinet @ 90 PSI. Unfortunately, the glass bead blasting doesn't seem to strip those center caps very well
I also used a heat gun to heat up that coating, but it didn't seem to make a dent in it.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131296
03/22/23 12:23 AM
03/22/23 12:23 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
How about silica sand?
Re: Thoughts on stripping the finish off rally wheel center caps [Re: Sunroofcuda] #3131358
03/22/23 09:52 AM
03/22/23 09:52 AM
VA
VA
Changing out the glass beads in my large cabinet is a real pain. I'd prefer to find some type of cost-effective chemical stripper that will make this job easy. Where's Walter White when you need him... stirthepot
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131414
03/22/23 11:57 AM
03/22/23 11:57 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Been there done this, the striping, the taping off, etc, cheaper to buy new ones.....
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131433
03/22/23 12:51 PM
03/22/23 12:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I use a more aggressive media that would likely take it off. Might look for someone nearby or talk to your powder coater. They usually blast things before coating. I'm assuming you're doing the entire cap including the chromed part(s)? beer
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131557
03/22/23 09:02 PM
03/22/23 09:02 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
100''s of degrees & didn't soften enough to scrap off?
If lacquer, won't blister like with some house paints.
Hope that's not what you were expecting.
It's paint, right?
Get a better heat gun then.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: PhillyRag] #3131603
03/23/23 02:09 AM
03/23/23 02:09 AM
VA
VA
I have a commercial grade heat gun. The heat didn't make it budge at all. Whatever this coating is that was used in the early-mid 70s, it's some tough stuff...
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131621
03/23/23 09:34 AM
03/23/23 09:34 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I didn't strip my paint off. I just filled in chips in the paint with a couple extra coats of paint sprayed on a piece of card board first and than dabbed on with a brush in the chips. Once all level. Just resprayed the entire center cap. Taped off as needed first. That was over 25 years ago and they still look good today.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131624
03/23/23 10:01 AM
03/23/23 10:01 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
soak them in brake fluid..
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131633
03/23/23 10:48 AM
03/23/23 10:48 AM
IMGTX Offline
IMGTX  Offline
You are sure you are trying to remove the paint and not the chrome right? shruggy
Mine were chrome with silver grey paint in the recessed area around the bolt holes. Outer trim and high point in the middle of the bolt holes were actually unpainted chrome.
I always had the bad luck of never getting the paint to stick. Sorry you are having the opposite problem.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: IMGTX] #3131638
03/23/23 11:05 AM
03/23/23 11:05 AM
California
biggE Offline
biggE  Offline
California
I use crushed walnut shell in the bead blaster
Re: Thoughts on stripping the finish off rally wheel center caps [Re: IMGTX] #3131717
03/23/23 03:08 PM
03/23/23 03:08 PM
VA
VA
It's may likely some sort of chrome remnants. It's the toughest stuff I've ever had to try to remove..
Re: Thoughts on stripping the finish off rally wheel center caps [Re: AtomicDog] #3131799
03/23/23 09:03 PM
03/23/23 09:03 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Argent was nothing more then lacquer paint.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: PhillyRag] #3132905
03/28/23 01:19 AM
03/28/23 01:19 AM
Missouri
70X Offline
70X  Offline
Missouri
Exactly. I think he is trying to get the chrome or whatever finish these are off, not the argent though.
Re: Thoughts on stripping the finish off rally wheel center caps [Re: 70X] #3132928
03/28/23 08:56 AM
03/28/23 08:56 AM
VA
VA
That's correct. I looked at the other center caps I have and there is a fair amount of chrome finish on them. It appears that is what I need to remove.
Has anyone used a muratic acid dip mix successfully to strip/remove the finish or should I be thinking of another way to chemically strip them?
