The pre 1964 8.75 rear with tapered axle shafts #3129595
03/15/23 12:02 PM
03/15/23 12:02 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
Several 8.75s NEAR me for sale but they are the tapered axle style. Later common style are for sale too but on the other side of the state. (Both are expensive!) I searched here on Moparts and was not fully brought up to speed. So back in the day it took an aftermarket conversion axle to make the tapered style into the 1965 on up common style? No factory axle shafts are a direct swap? I'm looking for a rear for my 95 Dakota and that early B body unit is a great length- but not at the cost of weird pressed on- unavailable hubs and such. BTW- these tapered axle style rears for sale do not have the hubs otherwise I would do that conversion to run later drums.
Keep old mopars alive.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3129614
03/15/23 12:48 PM
03/15/23 12:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I am sure you can have new shafts made to convert to one piece axles and run later brakes.
I know Dutchman lists this as an option.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: Sniper] #3129616
03/15/23 12:56 PM
03/15/23 12:56 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
drive Yup , and www.doctordiff.com has the Parts in Stock ! wave Cass knows His 8.75s ! Call Him ! drive Ronnie
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 1969ronnie] #3129617
03/15/23 12:59 PM
03/15/23 12:59 PM
Holland MI Ottawa
2
Holland MI Ottawa
Thanks.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3129620
03/15/23 01:03 PM
03/15/23 01:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by 2boltmain
I'm looking for a rear for my 95 Dakota and that early B body unit is a great length.
Be aware that the early B-body rears are different widths.
http://www.moparts.org/Tech/Archive/axle/17.html
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3129625
03/15/23 01:19 PM
03/15/23 01:19 PM
You can use the 1965 backing plates, drums and axles in your, the earlier housings, you may need to trim a small amount of the splines off the later axles depending on which year early housing and which body stye it came out of.
The 1963 B body axles and housings are shorter than the 1965 B body housings,the 1964 B body housings are longer than the 1963 B body are I haven't tried to use any of the early C body 8 3/4 rear ends in any of my cars so no help on that blush
All the early 3rd members had a device in the center of the carrier that the axles would butt up to and you needed to use shims between the brake backing plates and the rear end housing to set the end play wrench scope
If you use the later, better, green axle bearings you don't need to worry about that unless you end up with no end play on the axles, if that is the case then trim a little off the axles ends that go into the spider gears, drive gears inside the carriers scope wrench
IHTHs luck
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: Cab_Burge] #3129636
03/15/23 01:50 PM
03/15/23 01:50 PM
Holland MI Ottawa
2
Holland MI Ottawa
IHTHs luck
Cab I read a post from you dated from 2009 that was helpful. I don't need a rear end immediately but I am disheartened at how fast they sell on Facebook Marketplace- even the EXPENSIVE units. I may repack my tailer wheel bearings and buy a spare tire for it and trek a long ways for a complete unit out of a 69 road runner on the east side of MI.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3129714
03/15/23 05:54 PM
03/15/23 05:54 PM
A727Tflite Offline
A727Tflite  Offline
IHTHs luck
How much are those 62-65 units selling for ?
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: A727Tflite] #3129732
03/15/23 07:51 PM
03/15/23 07:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
For what Moser is selling their stuff for vs. big bucks for an old used abused housing...
things that make you go hmmmm
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: CMcAllister] #3129773
03/15/23 10:58 PM
03/15/23 10:58 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
It’s probably too wide for you but I’ll have a drum to drum A100/C/E body rearend with moser axles and a 4.30 489 case for sale as soon as my Strange S60 arrives, and I could deliver it. The perch width is 46” on it compared to 44” for the B’s.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: Blusmbl] #3129836
03/16/23 10:08 AM
03/16/23 10:08 AM
Holland MI Ottawa
2
Holland MI Ottawa
Ideally a flange to flange measurement of 54-57" would be ideal. Avails me to actual rear/back spacing Weld has on their Draglite wheels. I'm really hoping something much close to Holland MI pops up. I have a utility trailer. Its just I really don't feel like a trek across the state with it. Shoot me a PM here though with your price. And thanks.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: A727Tflite] #3129840
03/16/23 10:13 AM
03/16/23 10:13 AM
Holland MI Ottawa
2
Holland MI Ottawa
What I am seeing on Marketplace is NON sure grip units- Heavily rusted -without drums and brake components for $300-$800. "Sure grip" units heavily rusted-complete and non complete for $900-$1500. Same for Ford 9." The more reasonably priced units are the furthest distance wise from me. But I don't need one ASAP. Its just my OCD drives me nuts!
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3129892
03/16/23 01:18 PM
03/16/23 01:18 PM
moparx Offline
moparx  Offline
and i have a tapered axle housing [only] that is in great shape stacked against the wall for years nobody wants. shruggy
i figured someday [?] i might want to shorten an 8 3/4 housing for something, and i would just use this one.
beer
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: moparx] #3129982
03/16/23 08:06 PM
03/16/23 08:06 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I probably scrapped a dozen or more of those tapered axle 8 3/4 in my younger years! But then again, the solid axle 8 3/4s were plentiful and cheap.
I'm a hard core Mopar guy, but those ford 8.8 rears are hard to beat for the price, gear choices, and availability. The last one was a 3:73, limited slip, disc brake one that cost $150. With the correct $10 bolt on pinion yoke, my Mopar drive shaft bolted up.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: moparx] #3130010
03/16/23 10:33 PM
03/16/23 10:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I happen to have a shortening jig for multiple make rear ends if your interested PM me wink beer
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3130016
03/16/23 10:43 PM
03/16/23 10:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
IHTHs luck
I scrapped a max wedge housing when I left calif in 94, couldn't find a taker. Also scrapped an e body 8-3/4 housing with axles and backing plates about 15 years ago. Again, no takers frown Should've held onto both. Currently can't find a home for a 64 BB 727 console shift with driveshaft or a BB 727 74 vintage.
But as soon as i scrap them they'll both be worth $$$ whistling
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: TJP] #3130114
03/17/23 12:04 PM
03/17/23 12:04 PM
Holland MI Ottawa
2
Holland MI Ottawa
Its obvious on marketplace that many have had a moment of: "Oh sh#!- that rear end that's been in the field for 30 years is now worth a fortune." I say this because many pics are of a heavily rusted/crusted assemblies in a field/yard with high weeds growing around it ---and a hefty price. Not just mopar units either.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: 2boltmain] #3130118
03/17/23 12:33 PM
03/17/23 12:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A wrecking yard near me used to have a huge pile of rear ends waiting for the price of scrap to peak. Lots of flange axle 8 3/4's and truck Dana 60's. $50 for anything in the pile.
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: John_Kunkel] #3130151
03/17/23 02:23 PM
03/17/23 02:23 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
If you can find one with hubs this conversion is fairly easy: http://hotrodsandhemis.com/TaperedAxleBrakes.html
Re: The pre 1964 8.75 rear with tapered axle shafts [Re: TooMany62s] #3130162
03/17/23 02:54 PM
03/17/23 02:54 PM
GA
roadrunninMark Offline
GA
I am sure it has been covered before but what about using a "mini spool" to change over an open end unit? I know there will be responses saying that a spool is terrible for a street car but I would like to hear from those that have them and what their experiences are. I have an open end in by barracuda and would like to put in a sure grip but prices are ridiculous at the moment. A mini spool is a lot less but what would I be opening myself up to by going that route? Not for a daily driven car but more of a fair weather cruiser.
