The pre 1964 8.75 rear with tapered axle shafts
#3129595
03/15/23 12:02 PM
03/15/23 12:02 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Several 8.75s NEAR me for sale but they are the tapered axle style. Later common style are for sale too but on the other side of the state. (Both are expensive!) I searched here on Moparts and was not fully brought up to speed. So back in the day it took an aftermarket conversion axle to make the tapered style into the 1965 on up common style? No factory axle shafts are a direct swap? I'm looking for a rear for my 95 Dakota and that early B body unit is a great length- but not at the cost of weird pressed on- unavailable hubs and such. BTW- these tapered axle style rears for sale do not have the hubs otherwise I would do that conversion to run later drums.
Keep old mopars alive.
Re: The pre 1964 8.75 rear with tapered axle shafts
[Re: 2boltmain]
#3129625
03/15/23 01:19 PM
03/15/23 01:19 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
You can use the 1965 backing plates, drums and axles in your, the earlier housings, you may need to trim a small amount of the splines off the later axles depending on which year early housing and which body stye it came out of. The 1963 B body axles and housings are shorter than the 1965 B body housings,the 1964 B body housings are longer than the 1963 B body are I haven't tried to use any of the early C body 8 3/4 rear ends in any of my cars so no help on that All the early 3rd members had a device in the center of the carrier that the axles would butt up to and you needed to use shims between the brake backing plates and the rear end housing to set the end play If you use the later, better, green axle bearings you don't need to worry about that unless you end up with no end play on the axles, if that is the case then trim a little off the axles ends that go into the spider gears, drive gears inside the carriers IHTHs
[Re: Cab_Burge]
#3129636
03/15/23 01:50 PM
03/15/23 01:50 PM
2boltmain
Holland MI Ottawa
You can use the 1965 backing plates, drums and axles in your, the earlier housings, you may need to trim a small amount of the splines off the later axles depending on which year early housing and which body stye it came out of. The 1963 B body axles and housings are shorter than the 1965 B body housings,the 1964 B body housings are longer than the 1963 B body are I haven't tried to use any of the early C body 8 3/4 rear ends in any of my cars so no help on that All the early 3rd members had a device in the center of the carrier that the axles would butt up to and you needed to use shims between the brake backing plates and the rear end housing to set the end play If you use the later, better, green axle bearings you don't need to worry about that unless you end up with no end play on the axles, if that is the case then trim a little off the axles ends that go into the spider gears, drive gears inside the carriers IHTHs Cab I read a post from you dated from 2009 that was helpful. I don't need a rear end immediately but I am disheartened at how fast they sell on Facebook Marketplace- even the EXPENSIVE units. I may repack my tailer wheel bearings and buy a spare tire for it and trek a long ways for a complete unit out of a 69 road runner on the east side of MI.
[Re: 2boltmain]
#3129714
03/15/23 05:54 PM
03/15/23 05:54 PM
Posts: 3,076 Michigan
A727Tflite
You can use the 1965 backing plates, drums and axles in your, the earlier housings, you may need to trim a small amount of the splines off the later axles depending on which year early housing and which body stye it came out of. The 1963 B body axles and housings are shorter than the 1965 B body housings,the 1964 B body housings are longer than the 1963 B body are I haven't tried to use any of the early C body 8 3/4 rear ends in any of my cars so no help on that All the early 3rd members had a device in the center of the carrier that the axles would butt up to and you needed to use shims between the brake backing plates and the rear end housing to set the end play If you use the later, better, green axle bearings you don't need to worry about that unless you end up with no end play on the axles, if that is the case then trim a little off the axles ends that go into the spider gears, drive gears inside the carriers IHTHs Cab I read a post from you dated from 2009 that was helpful. I don't need a rear end immediately but I am disheartened at how fast they sell on Facebook Marketplace- even the EXPENSIVE units. I may repack my tailer wheel bearings and buy a spare tire for it and trek a long ways for a complete unit out of a 69 road runner on the east side of MI. How much are those 62-65 units selling for ?
[Re: A727Tflite]
#3129732
03/15/23 07:51 PM
03/15/23 07:51 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
For what Moser is selling their stuff for vs. big bucks for an old used abused housing...
things that make you go hmmmm
[Re: CMcAllister]
#3129773
03/15/23 10:58 PM
03/15/23 10:58 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
It’s probably too wide for you but I’ll have a drum to drum A100/C/E body rearend with moser axles and a 4.30 489 case for sale as soon as my Strange S60 arrives, and I could deliver it. The perch width is 46” on it compared to 44” for the B’s.
[Re: Blusmbl]
#3129836
03/16/23 10:08 AM
03/16/23 10:08 AM
2boltmain
Holland MI Ottawa
It’s probably too wide for you but I’ll have a drum to drum A100/C/E body rearend with moser axles and a 4.30 489 case for sale as soon as my Strange S60 arrives, and I could deliver it. The perch width is 46” on it compared to 44” for the B’s. Ideally a flange to flange measurement of 54-57" would be ideal. Avails me to actual rear/back spacing Weld has on their Draglite wheels. I'm really hoping something much close to Holland MI pops up. I have a utility trailer. Its just I really don't feel like a trek across the state with it. Shoot me a PM here though with your price. And thanks.
[Re: A727Tflite]
#3129840
03/16/23 10:13 AM
03/16/23 10:13 AM
2boltmain
Holland MI Ottawa
What I am seeing on Marketplace is NON sure grip units- Heavily rusted -without drums and brake components for $300-$800. "Sure grip" units heavily rusted-complete and non complete for $900-$1500. Same for Ford 9." The more reasonably priced units are the furthest distance wise from me. But I don't need one ASAP. Its just my OCD drives me nuts!
[Re: 2boltmain]
#3130016
03/16/23 10:43 PM
03/16/23 10:43 PM
Posts: 15,366 Omaha Ne
TJP
Omaha Ne
You can use the 1965 backing plates, drums and axles in your, the earlier housings, you may need to trim a small amount of the splines off the later axles depending on which year early housing and which body stye it came out of. The 1963 B body axles and housings are shorter than the 1965 B body housings,the 1964 B body housings are longer than the 1963 B body are I haven't tried to use any of the early C body 8 3/4 rear ends in any of my cars so no help on that All the early 3rd members had a device in the center of the carrier that the axles would butt up to and you needed to use shims between the brake backing plates and the rear end housing to set the end play If you use the later, better, green axle bearings you don't need to worry about that unless you end up with no end play on the axles, if that is the case then trim a little off the axles ends that go into the spider gears, drive gears inside the carriers IHTHs Cab I read a post from you dated from 2009 that was helpful. I don't need a rear end immediately but I am disheartened at how fast they sell on Facebook Marketplace- even the EXPENSIVE units. I may repack my tailer wheel bearings and buy a spare tire for it and trek a long ways for a complete unit out of a 69 road runner on the east side of MI. I scrapped a max wedge housing when I left calif in 94, couldn't find a taker. Also scrapped an e body 8-3/4 housing with axles and backing plates about 15 years ago. Again, no takers Should've held onto both. Currently can't find a home for a 64 BB 727 console shift with driveshaft or a BB 727 74 vintage. But as soon as i scrap them they'll both be worth $$$
[Re: TJP]
#3130114
03/17/23 12:04 PM
03/17/23 12:04 PM
2boltmain
Holland MI Ottawa
Its obvious on marketplace that many have had a moment of: "Oh sh#!- that rear end that's been in the field for 30 years is now worth a fortune." I say this because many pics are of a heavily rusted/crusted assemblies in a field/yard with high weeds growing around it ---and a hefty price. Not just mopar units either.
[Re: 2boltmain]
#3130118
03/17/23 12:33 PM
03/17/23 12:33 PM
Posts: 25,804 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A wrecking yard near me used to have a huge pile of rear ends waiting for the price of scrap to peak. Lots of flange axle 8 3/4's and truck Dana 60's. $50 for anything in the pile.
[Re: TooMany62s]
#3130162
03/17/23 02:54 PM
03/17/23 02:54 PM
Posts: 2,937 GA
roadrunninMark
GA
I am sure it has been covered before but what about using a "mini spool" to change over an open end unit? I know there will be responses saying that a spool is terrible for a street car but I would like to hear from those that have them and what their experiences are. I have an open end in by barracuda and would like to put in a sure grip but prices are ridiculous at the moment. A mini spool is a lot less but what would I be opening myself up to by going that route? Not for a daily driven car but more of a fair weather cruiser.
