Head gasket selection #3128701
03/12/23 10:00 AM
03/12/23 10:00 AM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
What head gasket you all using on your boosted application with say 20 lbs of boost? Will Cometic three-layer work or do you all just go copper?
Re: Head gasket selection [Re: racerx] #3128711
03/12/23 10:57 AM
03/12/23 10:57 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I would use cometic. With as many layers as possible in the desired thickness.
Could not pay me to use copper.
Re: Head gasket selection [Re: racerx] #3128800
03/12/23 04:00 PM
03/12/23 04:00 PM
I've used SCE copper head gaskets on a lot of roots blown Mopar motors as well as on SB and BB blown Chevy motors. On your deal I would have the block and heads machine for receiver grooves and use steel wire O rings on the block or heads, your choice and receiver grooves on the other parts up scope
I've been able to reuse them several times after they have been raced ad driven on the street, you must anneal them each time before using them to get them soft again so they reseal good and properly wrench scope up
SCE makes them in several different versions for blown motors, talk to their techs to see which ones they recommend for your deal. 661-728-9200 scope up
I'm going to use them on my new heads up no prep B1-MC crank driven supercharged motor on E85 with north of 30 Lbs. of boost, hopefully they will seal real well on that combination luck
Re: Head gasket selection [Re: Cab_Burge] #3128858
03/12/23 09:16 PM
03/12/23 09:16 PM
pa
572charger Offline
572charger  Offline
pa
ive been using cometics on my hemi with a f-2 procharger at 21 lbs of boost on pump e85 its all about the tune up !!!!!! i have 160 lb injectors and a fast xfi to control it
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Head gasket selection [Re: 572charger] #3128921
03/13/23 06:16 AM
03/13/23 06:16 AM
Mo.
Mo.
How that setup holding up for you @21 lbs of boost work i assume you have an aftermarket block?
Re: Head gasket selection [Re: INTMD8] #3128922
03/13/23 06:18 AM
03/13/23 06:18 AM
Mo.
Mo.
Have you had a bad personal experience with copper gaskets?
Re: Head gasket selection [Re: Cab_Burge] #3128923
03/13/23 06:28 AM
03/13/23 06:28 AM
Mo.
Mo.
Cab.....My plan is to get the turbos mockup on this block then transfer this setup over to an aftermarket block.
Re: Head gasket selection [Re: racerx] #3128982
03/13/23 11:05 AM
03/13/23 11:05 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes. Just my opinion but I very much dislike them.
Have to re-torque after heat cycling and was never able to get them to seal perfectly be it coolant or combustion.
I think MLS is in all ways superior.
Re: Head gasket selection [Re: INTMD8] #3128986
03/13/23 11:13 AM
03/13/23 11:13 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
With a 4.840" bore spacing, a 4.56" bore with a wedge head, copper is all you can get (at least it used to be). To be fair though we never had any issues.
Re: Head gasket selection [Re: racerx] #3128997
03/13/23 11:39 AM
03/13/23 11:39 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Not boost but 250 shot of nitrous with Cometics and no issues.
Re-used them a couple of times now.
'63 Dodge 330
11.19 @ 121 mph
Re: Head gasket selection [Re: GY3] #3129028
03/13/23 12:42 PM
03/13/23 12:42 PM
an8sec70cuda Offline
Cometic. up
I also just dislike using copper gaskets. They work fine and all, but dealing w/ o-rings on the deck and silicone to stop water leaks is just a pain in the hind end.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Head gasket selection [Re: an8sec70cuda] #3129048
03/13/23 01:41 PM
03/13/23 01:41 PM
I was told by the owner of SCE to use a coating of spray on "Copper Coat" to help seal them on stock blocks and heads, that has work well for me up scope
They have added a bunch of different options on the copper head gaskets now such as teflon linings around all the water ports in the block and heads to help seal them up upscope
Re: Head gasket selection [Re: Cab_Burge] #3129144
03/13/23 07:18 PM
03/13/23 07:18 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Cometic has a fairly new 5 layer gasket that works pretty well on the boosted stuff.....NOT cheap.
Todd
Re: Head gasket selection [Re: sasquatch] #3129235
03/14/23 07:55 AM
03/14/23 07:55 AM
Mo.
Mo.
ToDD,,,,do you carry these gaskets?
Re: Head gasket selection [Re: racerx] #3129543
03/15/23 03:53 AM
03/15/23 03:53 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yes I am a Cometic dealer and stock some common sizes but if we have to order it is the ol waiting game.
Todd
Re: Head gasket selection [Re: sasquatch] #3129549
03/15/23 07:22 AM
03/15/23 07:22 AM
Mo.
Mo.
Thx Todd up
