Re: Head gasket selection
[Re: racerx]
#3128711
03/12/23 10:57 AM
03/12/23 10:57 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I would use cometic. With as many layers as possible in the desired thickness.
Could not pay me to use copper.
[Re: Cab_Burge]
#3128858
03/12/23 09:16 PM
03/12/23 09:16 PM
Posts: 1,629 pa
572charger
pa
ive been using cometics on my hemi with a f-2 procharger at 21 lbs of boost on pump e85 its all about the tune up !!!!!! i have 160 lb injectors and a fast xfi to control it
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#3128921
03/13/23 06:16 AM
03/13/23 06:16 AM
Posts: 4,068 Mo.
racerx
Mo.
ive been using cometics on my hemi with a f-2 procharger at 21 lbs of boost on pump e85 its all about the tune up !!!!!! i have 160 lb injectors and a fast xfi to control it How that setup holding up for you @21 lbs of boost i assume you have an aftermarket block?
[Re: INTMD8]
#3128922
03/13/23 06:18 AM
03/13/23 06:18 AM
Posts: 4,068 Mo.
racerx
Mo.
Could not pay me to use copper. Have you had a bad personal experience with copper gaskets?
[Re: racerx]
#3128982
03/13/23 11:05 AM
03/13/23 11:05 AM
INTMD8
Lake Villa Il
Could not pay me to use copper. Have you had a bad personal experience with copper gaskets? Yes. Just my opinion but I very much dislike them. Have to re-torque after heat cycling and was never able to get them to seal perfectly be it coolant or combustion. I think MLS is in all ways superior.
[Re: INTMD8]
#3128986
03/13/23 11:13 AM
03/13/23 11:13 AM
Posts: 2,916 A shed in England
Tig
A shed in England
Could not pay me to use copper. With a 4.840" bore spacing, a 4.56" bore with a wedge head, copper is all you can get (at least it used to be). To be fair though we never had any issues.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: racerx]
#3128997
03/13/23 11:39 AM
03/13/23 11:39 AM
Posts: 4,672 Wichita
GY3
Wichita
Not boost but 250 shot of nitrous with Cometics and no issues.
Re-used them a couple of times now.
[Re: GY3]
#3129028
03/13/23 12:42 PM
03/13/23 12:42 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Cometic. I also just dislike using copper gaskets. They work fine and all, but dealing w/ o-rings on the deck and silicone to stop water leaks is just a pain in the hind end.
