Re: Fuse \ Relay block
[Re: TJP]
#3127317
03/07/23 04:09 PM
03/07/23 04:09 PM
Posts: 630 Ct
Wirenut
Ct
How many circuits do you need ? and what anticipated amperage per circuit ? If each circuit was good for 30 amps I can always fuse down. 4 relays maybe 6 or more circuits. Modernizing my 65 and would prefer to put new loads on a new system rather than tax the existing.
[Re: volaredon]
#3127320
03/07/23 04:13 PM
03/07/23 04:13 PM
Posts: 630 Ct
Wirenut
Ct
Hit the junkyard. Look under the hoods of newer vehicles, I've pirated a few for my uses. I like the ones under the hood of 89-92 rangers. I used one to delete all my fusible links on my 85 D150 by running everything that used to have a fusible link in it thru the fuse box instead. We did the same on my son's ramcharger when we deleted the TBI and went 4bbl, that one came from a 98 zx2.(escort) Thanks for the reply. Those days are gone here in ct . Any yards remove the parts for you . Also don’t want a bunch of splices . Want to be able to go right to the fuse or relay. The key thing I’m looking for is something with a common positive bus bar so all fuses are powered instead of having to feed each one from a positive lug or bar
[Re: NITROUSN]
#3127378
03/07/23 08:20 PM
03/07/23 08:20 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I source the components and do systems according to what it is and how much stuff there is. Typically I like to locate relays near the component it is controlling. Separate components, as opposed to all-in-one assemblies, allows for quick repair/replacement in the field in the event of a failure.
Littlelfuse/Bussmann makes nice stuff and usually have what I need. Relays and other parts are from notChina places as well.
[Re: Wirenut]
#3127485
03/08/23 12:07 PM
03/08/23 12:07 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
AndyF mentioned the MSD Relays some time ago. I took a look back then and they have a nice form factor and some pretty interesting features. Holley just sent me an email saying that they have added some part #s and some of the MSD Relays are on sale (Holley owns MSD). Check out: https://www.holley.com/products/electrical/wiring_and_relays/ There are lower priced relays with less functionality and higher priced solid-state relays. See: https://www.holley.com/products/electrical/wiring_and_relays/parts/7566-4 The lower priced relays do NOT have a common input power bus. The more pricy solid-state relays like this high-current part: https://www.holley.com/products/electrical/wiring_and_relays/parts/7564-HC have a single power input bus. The solid-state relays are cool because they switch fast enough to take a PWM (Pulse Width Modulation) signal on the relay control circuit and produce a PWM output for the load side of the relay. So if you need the really fast switching of a solid-state relay, these parts are a good option. Read the .pdf instructions at the link for each part# to get more detail. Full disclosure - I haven't purchased one of these yet but I have several of these part #s on my Summit wish list.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#3127488
03/08/23 12:19 PM
03/08/23 12:19 PM
Posts: 4,674 Wichita
GY3
Wichita
Leash Electronics has a lot of neat stuff and can custom make you what you need.
He's out of Arkansas.
[Re: Wirenut]
#3127502
03/08/23 01:23 PM
03/08/23 01:23 PM
Posts: 2,237 ILLINOIS
volaredon
ILLINOIS
Hit the junkyard. Look under the hoods of newer vehicles, I've pirated a few for my uses. I like the ones under the hood of 89-92 rangers. I used one to delete all my fusible links on my 85 D150 by running everything that used to have a fusible link in it thru the fuse box instead. We did the same on my son's ramcharger when we deleted the TBI and went 4bbl, that one came from a 98 zx2.(escort) Thanks for the reply. Those days are gone here in ct . Any yards remove the parts for you . Also don’t want a bunch of splices . Want to be able to go right to the fuse or relay. The key thing I’m looking for is something with a common positive bus bar so all fuses are powered instead of having to feed each one from a positive lug or bar That's how most factory stock ones are, some are always hot, others are hot w/ the key. I cut my fuse box about 10" away from the box itself, so I had plenty of lead to work with. I then butt connected them ( bare un insulated crimps) then soldered them and heat shrunk every splice with the " good" heat shrink, the heavier walled stuff with the built in adhesive that oozes out as the heat is applied and the tubing shrinks
[Re: volaredon]
#3127529
03/08/23 02:48 PM
03/08/23 02:48 PM
Posts: 19,406 north of coder
moparx
heavy wall heat shrink with the adhesive is marine grade stuff. i use that a lot. as always, there are many places to obtain this from, and some are better than others. shop around and compare brands at different places. some places add a markup to the [same] product just because you purchase from their "name".
[Re: Wirenut]
#3127721
03/09/23 04:23 AM
03/09/23 04:23 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You might be looking at the Bussman 15300 series fuse/relay boxes. They come in different configurations: https://www.eaton.com/us/en-us/catalog/emobility/series-15300-rear-terminal-mini-fuse-relay.htmlPages 48-49 of the catalog: https://www.eaton.com/content/dam/eaton/products/emobility/CPCD_Transportation_Catalog.pdfNormally 1530(3 or 5) - 2 is the 5 Micro relay and 10 fuse base. I believe it has one positive buss to all the fuses, and another buss for the relay grounds (when triggered on the high side.) If using non-polarized relays, the relay bus could be connected to power through one of the fuses, and triggered on the low side. I'm not sure why Amazon is $90? I actually ordered that one from Amazon on Aug 11, 2020 and it was $39.02 back then. Waytek is $42.85 for the 15305 (metric screws) version -2-2-4 I noticed you can get them pre-wired with the fuses and relays on E-Bay, but they are expensive, $230: https://www.ebay.com/itm/132449489662
