66 belvedere convert single master cyl. to dual? #3127120
03/06/23 10:55 PM
03/06/23 10:55 PM
N.Y.
sixpacksteve Offline OP
N.Y.
need to convert. don't trust single.
whats needed?
which correct master cyl. and prop valve?
Hell Hath No Fury Like Mine
Re: 66 belvedere convert single master cyl. to dual? [Re: sixpacksteve] #3127140
03/07/23 12:39 AM
03/07/23 12:39 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
get a 1.031 master cyl for disc drum non power
plenty on e bay
get new not reman .
Re: 66 belvedere convert single master cyl. to dual? [Re: calrobb2000] #3127159
03/07/23 04:26 AM
03/07/23 04:26 AM
Originally Posted by calrobb2000
hi
plenty on e bay
get new not reman .
The smaller master cylinder bores will stop better than the larger ones will, a lot better especially on non power brakes up scope
I used either a 7/8 or 15/16 M.C. (CRS now blush)on my 1966 Coronet Deluxe that I converted to disc brakes on the front wrench
I haven't driven it much and I do have a problem with the current M.C. it is not holding pressure very well, time to try again on a different one whiney shruggy
Re: 66 belvedere convert single master cyl. to dual? [Re: Cab_Burge] #3127175
03/07/23 08:48 AM
03/07/23 08:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My 66 is converted.
Using everything from a 67 B body.
Still manual drum brakes
Re: 66 belvedere convert single master cyl. to dual? [Re: gtx6970] #3127184
03/07/23 09:44 AM
03/07/23 09:44 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by gtx6970
My 66 is converted.
This is the way to do it.
Re: 66 belvedere convert single master cyl. to dual? [Re: 6PakBee] #3127187
03/07/23 09:53 AM
03/07/23 09:53 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
First is it disc drum or drum drum.If all drum no need for PP valve.We use nothing but C body 70 masters Either disc drum or drum drum.Mines going on 25 years my kids was 15 at least when he sold the 62
Chrysler Firepower
Re: 66 belvedere convert single master cyl. to dual? [Re: Cab_Burge] #3127203
03/07/23 10:41 AM
03/07/23 10:41 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
hi
plenty on e bay
get new not reman .
This is 100% correct. Use the larger and you will never panic stop it . I made that mistake.
I converted my 65 to dual circuit and followed the ehrenberg disco tech swap. No prop valve , just use an adjustable valve in the rear line and experiment on damp pavement so rears just lock up first. It will be the best improvement you make to this car . My parts came from a 74 dart fwiw
Re: 66 belvedere convert single master cyl. to dual? [Re: Wirenut] #3127282
03/07/23 02:04 PM
03/07/23 02:04 PM
moparx Offline
moparx  Offline
wagner part numbers for reference. [these are rebuilt disc brake masters]
1 1/32" : F88787
15/16" : F80266
these are 74-75 dart applications.
beer
Re: 66 belvedere convert single master cyl. to dual? [Re: sixpacksteve] #3128112
03/10/23 12:27 PM
03/10/23 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
whats needed?
Disc/drum or drumdrum? If drum/drum there was no proportioning valve , it is just a distribution block with a switch to trigger the brake warning light.
Re: 66 belvedere convert single master cyl. to dual? [Re: 6PakBee] #3128320
03/11/23 07:06 AM
03/11/23 07:06 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
My 66 is converted.
Owning both a '65 and '67, this is what I did to my manual drum/drum '65. It worked fine. I sourced the brass splitter block on the frame rail and an OEM MC from a salvage yard and had it rebuilt. Bench bleed the MC carefully. I don't recall if I needed the shaft from the pedal, but I'm a parts hoarder, so I probably got it too off the donor car. The rear steel lines I reused as feasible, and bent and flared the second line myself. I have good bending skills and tools, and easy to get it right having my '67 right there for reference. I recall it was a little hard to source the second fitting at the MC, it has a particular size or thread.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 66 belvedere convert single master cyl. to dual? [Re: 67SATisfaction] #3128533
03/11/23 06:14 PM
03/11/23 06:14 PM
moparx Offline
moparx  Offline
if my feeble memory serves me right, [laugh2] the sizes are 1/2-20, and 9/16-18.
i think i have some of those in my drawer of brass fittings, as well as the factory fittings i have squirreled away over the years.
if i called these sizes wrong, i'll go out and measure them.
beer
