Rottella T
#312674
05/09/09 01:25 PM
05/09/09 01:25 PM
I am using Rottella T in my 440 Motor with about 1500 miles on it since rebuild. I heard that Rottella T is best for flat tappet motors. But I recently heard that it causes sludge build up. When I had the valve covers off every thing looked fine. I only drive about 700 miles a year. And change the oil once a year. Should I change to another oil or use the regular 10-40 modern oils with a separate zinc additive?
Re: Rottella T
#312677
05/09/09 01:54 PM
05/09/09 01:54 PM
RapidRobert
keep using it. The new Rotella doesn't have as much zinc as the old plastic white gallon jugs of it did but just add a zinc additive, use a good filter, frequent changes & you're good.
Re: Rottella T
#312678
05/09/09 03:20 PM
05/09/09 03:20 PM
Posts: 7,506 Az
Crizila
Az
Modern 10-40 with zinc additive. Most ( if not all ) new - 2010 diesel engines are going to after treatment ( convertors ) to meet new diesel emissions specs, so you can scratch using diesel oil for the hi zinc content shortly.
Fastest 300
Re: Rottella T
[Re: dOc …]
#312680
05/09/09 03:33 PM
05/09/09 03:33 PM
Posts: 7,506 Az
Crizila
Az
Again, I'd use an additive. A lot of whats out there ( lists of oils with hi zinc content ) is dated - not to mention all over the place re: just how much is in it.
Fastest 300
Re: Rottella T
[Re: dOc …]
#312683
05/09/09 03:43 PM
05/09/09 03:43 PM
RapidRobert
not sure but I have a couple of the good jugs left & I will check(& take pics) of an old/new container when I get out there(my new garage)
Re: Rottella T
#312686
05/09/09 06:54 PM
05/09/09 06:54 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
i've switched to rotella and i use a zinc additive and no problems yet. prior to that, i ran mobil 1 in my 440 and didnt have any problems. what i've herd is that you don't want to use any oil that says "energy conserving" oil can be a very touchy subject with some people. ![](/ubbthreads/images/graemlins/argue.gif) Greg
Re: Rottella T
[Re: CompSyn]
#312688
05/09/09 08:48 PM
05/09/09 08:48 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
The new API rating for diesel oil is CJ-4. The new CJ-4 oil is Ultra-low sulfur diesel (ULSD) for newer diesel emissions. The older API diesel oil rating is CI-4+ and is getting harder to find. In fact I talked with a parts department manager the other day who told me he cannot get the CI-4+ any longer. But there are a hand full of specialty companies still producing the CI-4+ diesel oil.
CompSyn
Depends on the weight. In 15w-40 that is true. But you can still buy Chevron Delo CI (not even CI+) in 10w-30. So far tests have shown that Rotella and Chevron still have marginally acceptable ZN levels (1250-1500 ppm from Staveley tests) but that could change at any time WITHOUT rolling the designation to CL.
Re: Rottella T
#312689
05/09/09 08:53 PM
05/09/09 08:53 PM
Pacnorthcuda
Rotella is NOT known for sludge build up. Weight wise the most likely oils to sludge are 10w-40 due to their high viscosity improver content. Synthetics not included (they don't need high amount to reach that weight designation)
Re: Rottella T
[Re: Pacnorthcuda]
#312690
05/09/09 11:04 PM
05/09/09 11:04 PM
Posts: 30,485 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
TS was closed by the time I got there but I made it to Menards .....
They have a BUNCH of Rotella that has a CI-4 rating.
Anyone see the ad that CompCams has ....with that special coating they have now ?
Re: Rottella T
[Re: dOc …]
#312691
05/10/09 12:26 AM
05/10/09 12:26 AM
Posts: 4,884 Michigan
MNobody
Wow the Menard's near Jackson, MI. only had cj-4 15w-40 i've been running that in mine with a solid cam with no issues but i hav'nt put a ton of miles on it either.
