Page 1 of 3 1 2 3
Rottella T #312674
05/09/09 01:25 PM
05/09/09 01:25 PM
Anonymous OP
Anonymous OP
I am using Rottella T in my 440 Motor with about 1500 miles on it since rebuild. I heard that Rottella T is best for flat tappet motors. But I recently heard that it causes sludge build up. When I had the valve covers off every thing looked fine. I only drive about 700 miles a year. And change the oil once a year. Should I change to another oil or use the regular 10-40 modern oils with a separate zinc additive?
Re: Rottella T #312675
05/09/09 01:31 PM
05/09/09 01:31 PM
Montana
67DodgeCharger Offline
On vacation
On vacation
Montana
It might look good in the rocker area but when it builds up in the lifter valley you will have lifter failure. A good synthetic oil will protect the valvetrain. But like the show you may have watch this morning an additive with a good motor oil will protect your motor.
I used a rottella for the breakin on my motor and it worked great. Then I used a regular motor oil for 500 miles and then switched to a good synthetic afterwards. It has 3000 miles on it now and holds good oil pressure. This is my daily driver so I put about 10K miles per year.
Re: Rottella T [Re: 67DodgeCharger] #312676
05/09/09 01:50 PM
05/09/09 01:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I hear different, it is heavy in detergents an keeps the engine very clean, i don't know how often truckers change their oil but i'm sure its not 3K.
Re: Rottella T #312677
05/09/09 01:54 PM
05/09/09 01:54 PM
keep using it. The new Rotella doesn't have as much zinc as the old plastic white gallon jugs of it did but just add a zinc additive, use a good filter, frequent changes & you're good.
Re: Rottella T #312678
05/09/09 03:20 PM
05/09/09 03:20 PM
Az
Crizila Offline
Crizila  Offline
Az
Modern 10-40 with zinc additive. Most ( if not all ) new - 2010 diesel engines are going to after treatment ( convertors ) to meet new diesel emissions specs, so you can scratch using diesel oil for the hi zinc content shortly.
Fastest 300
Re: Rottella T [Re: RapidRobert] #312679
05/09/09 03:25 PM
05/09/09 03:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Slightly OT ....
Anyone here know the designation on any oil container that indicates heavy zinc content?
I have got a couple of motors going together and will be using NON-roller cam.
I would use a roller but since the roller lifters I have heard of here and elsewhere are not reliable .....I will pass on that idea.
Re: Rottella T [Re: dOc !] #312680
05/09/09 03:33 PM
05/09/09 03:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Again, I'd use an additive. A lot of whats out there ( lists of oils with hi zinc content ) is dated - not to mention all over the place re: just how much is in it.
Fastest 300
Re: Rottella T [Re: dOc !] #312681
05/09/09 03:37 PM
05/09/09 03:37 PM
I think the orig rotella jugs had "CI"
Re: Rottella T [Re: RapidRobert] #312682
05/09/09 03:41 PM
05/09/09 03:41 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Cool ...THX
Is that CI an "industry" rating ?
Re: Rottella T [Re: dOc !] #312683
05/09/09 03:43 PM
05/09/09 03:43 PM
not sure but I have a couple of the good jugs left & I will check(& take pics) of an old/new container when I get out there(my new garage)
Re: Rottella T [Re: RapidRobert] #312684
05/09/09 03:47 PM
05/09/09 03:47 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I am going into-town later and will stop-off at Tractor Supply and see what is on their oil containers.
They have a pretty good selection of specialty diesel and HD tractor oils.
Re: Rottella T [Re: dOc !] #312685
05/09/09 06:08 PM
05/09/09 06:08 PM
Tractor Supply
that's where I got mine at & ~2 years ago they switched to the new stuff. Same shape white gallon jug but w a different label and definitely not "CI". I think the new letters are "CL" OR "CJ"
Re: Rottella T #312686
05/09/09 06:54 PM
05/09/09 06:54 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i've switched to rotella and i use a zinc additive and no problems yet.
prior to that, i ran mobil 1 in my 440 and didnt have any problems.
what i've herd is that you don't want to use any oil that says "energy conserving"
oil can be a very touchy subject with some people.
Greg
Re: Rottella T [Re: joelson6] #312687
05/09/09 08:37 PM
05/09/09 08:37 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The new API rating for diesel oil is CJ-4. The new CJ-4 oil is Ultra-low sulfur diesel (ULSD) for newer diesel emissions. The older API diesel oil rating is CI-4+ and is getting harder to find. In fact I talked with a parts department manager the other day who told me he cannot get the CI-4+ any longer. But there are a hand full of specialty companies still producing the CI-4+ diesel oil.
CompSyn
Re: Rottella T [Re: CompSyn] #312688
05/09/09 08:48 PM
05/09/09 08:48 PM
Kirkland, Washington
Pacnorthcuda Offline
CompSyn
Depends on the weight. In 15w-40 that is true. But you can still buy Chevron Delo CI (not even CI+) in 10w-30.
So far tests have shown that Rotella and Chevron still have marginally acceptable ZN levels (1250-1500 ppm from Staveley tests) but that could change at any time WITHOUT rolling the designation to CL.
Re: Rottella T #312689
05/09/09 08:53 PM
05/09/09 08:53 PM
Rotella is NOT known for sludge build up. Weight wise the most likely oils to sludge are 10w-40 due to their high viscosity improver content. Synthetics not included (they don't need high amount to reach that weight designation)
Re: Rottella T [Re: Pacnorthcuda] #312690
05/09/09 11:04 PM
05/09/09 11:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
TS was closed by the time I got there but I made it to Menards .....
They have a BUNCH of Rotella that has a CI-4 rating.
Anyone see the ad that CompCams has ....with that special coating they have now ?
Re: Rottella T [Re: dOc !] #312691
05/10/09 12:26 AM
05/10/09 12:26 AM
MNobody Offline
MNobody  Offline
Wow the Menard's near Jackson, MI. only had cj-4 15w-40 i've been running that in mine with a solid cam with no issues but i hav'nt put a ton of miles on it either.
Re: Rottella T [Re: dOc !] #312692
05/10/09 12:38 AM
05/10/09 12:38 AM
but I made it to Menards They have a BUNCH of Rotella that has a CI-4 rating.
Buy it, thats real good stuff.
Re: Rottella T [Re: RapidRobert] #312693
05/10/09 12:59 AM
05/10/09 12:59 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Brad Penn Racing oil, Valvoline Racing, and my favorite Mobil Delvac1 Full Synthetic Diesel oil. YMMV
I also run EDM solid lifters...
Page 1 of 3 1 2 3
