BB dragster oil pan questions #3126416
03/04/23 12:00 PM
03/04/23 12:00 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I'm swapping the old moroso pan on the roadster for a dragster style moroso style pan with swinging pickup as part of my winter updates and have a couple questions I'm hoping the experts can help with.
I can't find much on moroso's website and this pan was a swap meet find.
How many quarts of oil do these oil pans hold?
It's 4.5" deep at the back and 3.5" deep at the front.
There is no dipstick provision which makes me nervous but I guess if it's got pressure it's fine 🤣.
Also any tips for the single external pickup appreciated as well.
This fancy stuff is foreign to me.
Thank You!!!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: BB dragster oil pan questions [Re: 69dart] #3126427
03/04/23 12:38 PM
03/04/23 12:38 PM
Out of the State of Confusion
blue_stocker Online rolleyes
blue_stocker  Online Rolleyes
Pretty shallow pan, might have been made for a dry sump or auxillary oil supply tank. The one pictured has a much deeper sump (7" at the front) and probably good for 7-8 quarts.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: BB dragster oil pan questions [Re: blue_stocker] #3126433
03/04/23 12:52 PM
03/04/23 12:52 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So I filled it with water and it holds 6qts to the built in windage tray or 7 qts if I use the gasket molded windage tray.
I ran 6 qts in the old one so we should be okay.
I wanted the shorter pan for ground clearance as the old one was just a couple inches off the ground.
I'll probably use my old windage tray and stick with 7 qts.
68 Dart - 340
66 Belvedere - 400
Re: BB dragster oil pan questions [Re: 69dart] #3126453
03/04/23 02:58 PM
03/04/23 02:58 PM
I've ground notches on the sides of the oil pan rails on more than one aluminum oil pan to clear the engine oil dip stick up wrench scope Grind a little at a time until it fits okay, don't go hog wild on it tsk I've also had to shorten, cut the end off the dipsticks so they don't hit the bottom of the oil pans scope shruggy I do fill the pans up with the oil amount I want to run and then mark that as the new full mark, you can drain one quart out and mark that as the new add mark also work scope
if you're going to run that shallow oil pan I would add a 3 quart Accusump to your engine twocents
Re: BB dragster oil pan questions [Re: Cab_Burge] #3126463
03/04/23 03:46 PM
03/04/23 03:46 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Good tip on the dipstick.
Ran 6-7 qts in the other pan.
An accusump - Even if it holds the same 6-7 qts of oil?
The swinging pickup is 3/16 off the bottom of the pan.
This is just junk bracket 383.
Those other pans must hold like 10 or 12 qts for fast hemi stuff.
68 Dart - 340
66 Belvedere - 400
Re: BB dragster oil pan questions [Re: Cab_Burge] #3126466
03/04/23 03:52 PM
03/04/23 03:52 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Use an Accusump. Hard on the brakes is where you will need it.
Use an oil pressure warning light. Most guys use a 30 switch. Some use a 15.
Don't use a dipstick if you are using any kind of pan evap or vacuum pump system. Some guys will keep the dipstick tube intact, but pull the stick and put a vacuum cap on the tube.
Re: BB dragster oil pan questions [Re: CMcAllister] #3126520
03/04/23 06:56 PM
03/04/23 06:56 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run a similar oil pan with a dual line pick up on the street and race with no issues. Mine is a 7 qt pan, 3 in the Accusump and 1 in the filter so, a 11 qt system all together. No dipstick provision on mine either. I don't run a dipstick tube due to a vac pump.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: BB dragster oil pan questions [Re: 6PKRTSE] #3126527
03/04/23 07:22 PM
03/04/23 07:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine runs a dipstick with the vacuum pump. Late model Jeep stick and yube (cut down) with an O-ring at the top that seals it.
Doug
Re: BB dragster oil pan questions [Re: dvw] #3126566
03/04/23 10:00 PM
03/04/23 10:00 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
After some delicate grinding and filing by hand the dipstick fits again. Hopefully the new gaskets come so I can finish up.
That hemi looks like a serious ripper.
Thanks!
68 Dart - 340
66 Belvedere - 400
Re: BB dragster oil pan questions [Re: 69dart] #3126714
03/05/23 02:19 PM
03/05/23 02:19 PM
NC
440Jim Offline
440Jim  Offline
NC
I like your approach. Some of that 7 qts will be "upstairs" in the motor/heads when running.
Re: BB dragster oil pan questions [Re: 440Jim] #3126775
03/05/23 06:04 PM
03/05/23 06:04 PM
iagree It is interesting to fill the pan up with the amount of oil you want to run and mark the dipstick and then run the new motor for a while, 5+ minutes or more and then shut it off and let sit for a while and then look at your dipstick and see how much lower it reads now scope work twocents
I'm thinking near a half a quart or a little more gets store in the oil passages and in the nooks and crevasse in the motor and heads scope
