Re: BB dragster oil pan questions
[Re: 69dart]
#3126427
03/04/23 12:38 PM
03/04/23 12:38 PM
Posts: 1,363 Out of the State of Confusion
blue_stocker
Pretty shallow pan, might have been made for a dry sump or auxillary oil supply tank. The one pictured has a much deeper sump (7" at the front) and probably good for 7-8 quarts.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: 69dart]
#3126453
03/04/23 02:58 PM
03/04/23 02:58 PM
Posts: 43,206 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3126466
03/04/23 03:52 PM
03/04/23 03:52 PM
Posts: 11,589 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use an Accusump. Hard on the brakes is where you will need it.
Use an oil pressure warning light. Most guys use a 30 switch. Some use a 15.
Don't use a dipstick if you are using any kind of pan evap or vacuum pump system. Some guys will keep the dipstick tube intact, but pull the stick and put a vacuum cap on the tube.
[Re: CMcAllister]
#3126520
03/04/23 06:56 PM
03/04/23 06:56 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I run a similar oil pan with a dual line pick up on the street and race with no issues. Mine is a 7 qt pan, 3 in the Accusump and 1 in the filter so, a 11 qt system all together. No dipstick provision on mine either. I don't run a dipstick tube due to a vac pump.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3126527
03/04/23 07:22 PM
03/04/23 07:22 PM
Posts: 9,846 MI, usa
dvw
MI, usa
Mine runs a dipstick with the vacuum pump. Late model Jeep stick and yube (cut down) with an O-ring at the top that seals it. Doug
[Re: 69dart]
#3126714
03/05/23 02:19 PM
03/05/23 02:19 PM
Posts: 16,928 NC
440Jim
NC
So I filled it with water and it holds 6qts to the built in windage tray or 7 qts if I use the gasket molded windage tray.
I ran 6 qts in the old one so we should be okay.
I wanted the shorter pan for ground clearance as the old one was just a couple inches off the ground.
I'll probably use my old windage tray and stick with 7 qts. I like your approach. Some of that 7 qts will be "upstairs" in the motor/heads when running.
[Re: 440Jim]
#3126775
03/05/23 06:04 PM
03/05/23 06:04 PM
Cab_Burge
I like your approach. Some of that 7 qts will be "upstairs" in the motor/heads when running. It is interesting to fill the pan up with the amount of oil you want to run and mark the dipstick and then run the new motor for a while, 5+ minutes or more and then shut it off and let sit for a while and then look at your dipstick and see how much lower it reads now I'm thinking near a half a quart or a little more gets store in the oil passages and in the nooks and crevasse in the motor and heads
