Accusump Issue ? #3124460
02/25/23 11:06 AM
02/25/23 11:06 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
I just seen a thread on F/Book where two Super Stockers came together after an "Accusump failure" occurred at the finish line (John Dourlet and Justin Jerome).
I can't see an accusump failing other than the pipe falling off which I wouldn't consider to be an accusump failure anyway shruggy
Anyone know anything more specific? I'm interested to know as I've ran one for years and would like a heads up on what to check. up
Re: Accusump Issue ? [Re: Tig] #3124473
02/25/23 12:01 PM
02/25/23 12:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I know nothing, but if the AS performed as advertised, but was unable to keep the pressure up (AS capacity too small for the engine to run WOT for 5 seconds)...?
How did they determine the size of the discharge hose & fittings going back to the engine? Too small = not really helping?
Boffin Emeritus
Re: Accusump Issue ? [Re: Tig] #3124474
02/25/23 12:02 PM
02/25/23 12:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by Tig
Hi All.
I just saw that also , and have the same question , what failed ?
Re: Accusump Issue ? [Re: Tig] #3124485
02/25/23 12:37 PM
02/25/23 12:37 PM
Illinois
gearhead01 Online content
gearhead01  Online Content
Illinois
I did a quick search and found a post in an aviation forum of a failure after landing (thankfully).
Looking at the photos posted Accusump Failure and the comments in the thread,
I think it may have been caused by where the mounting clamps are located, and the plumbing after the control valve. Unsupported valve, vibration may have fatigued the threaded connection in the tube.
Not sure of the failure mode in the Super Stock crash.
Canton has a Do's and Don'ts section on their website. Canton
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Accusump Issue ? [Re: gearhead01] #3124500
02/25/23 01:09 PM
02/25/23 01:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have seen three electric valve failures with an accumsump over the years one was mine and thankfully happened in the lanes. All lost the seals in the solenoid..
Re: Accusump Issue ? [Re: polyspheric] #3124519
02/25/23 02:22 PM
02/25/23 02:22 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Something broke on the Accusump and oiled the track causing the crash.
Re: Accusump Issue ? [Re: Tig] #3124530
02/25/23 03:01 PM
02/25/23 03:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Interested as I and most everyone else I deal with has one on their car. Moroso typically, with the electric valve.
Plumbing failure most likely, The unit itself is pretty robust. Unless someone screwed up the snap ring or the groove servicing the thing.
Re: Accusump Issue ? [Re: CMcAllister] #3124531
02/25/23 03:03 PM
02/25/23 03:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Both cars pretty much a write off. Nice Mopars, one a 1 of 55 Hemi Belvedere.
Checking around to see what failed.
Re: Accusump Issue ? [Re: CMcAllister] #3124579
02/25/23 06:02 PM
02/25/23 06:02 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have had a A.S. on my car for many years with an electric solenoid. Maybe it's time to swap it out for a new one.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Accusump Issue ? [Re: 6PKRTSE] #3124583
02/25/23 06:12 PM
02/25/23 06:12 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Just for the record they were Stock Eliminator cars not Super Stock .. the RO23 car was running A/SA and the Duster was running E/SA ... still a shame two nice cars ! ....on a positive note a C/SA 69 Cuda went on to Win Stock Eliminator ! according to Classracer.com the owner of the Duster has already purchased another Duster to replace the one that was wrecked .. if you go back a few months on Classracer .com under Stock and Super / Stock then under driver interviews Bobby Fazio did an episode and interview on Justin Jerome and his Duster .. Cool interview ! I've always liked the small block " A ' body Stockers !
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Accusump Issue ? [Re: 11secdart] #3124610
02/25/23 08:30 PM
02/25/23 08:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The 1/8” plastic oil line broke I guess lol. Of course I’ll have one on my car, plumbed right into where the oil filter goes, 1/2” pipe treads I think, it’ll be a # 8 braided line
Re: Accusump Issue ? [Re: cudaman1969] #3124614
02/25/23 08:46 PM
02/25/23 08:46 PM
Sticky South
Rodenteliminator Offline
Sticky South
It would take some work but looking at the pics in the other post I wouldn’t write them as totaled,I would start hunting a parts for the RO that qtr outer will be hard to find, some pulling and prying on the rest of it. Doug
Sorry honey I spent the rent
Re: Accusump Issue ? [Re: Rodenteliminator] #3124618
02/25/23 09:04 PM
02/25/23 09:04 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There is no plastic line on an Accusump. Braided steel line feeds the engine. Either a fitting broke. The snap ring for the piston retainer popped out. Or the solenoid broke.
Doug
Re: Accusump Issue ? [Re: dvw] #3124706
02/26/23 09:12 AM
02/26/23 09:12 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I read somewhere else that the end plates have been known to "pop off". Not saying that's what happened in this case but has anyone else heard of that ?
I've never seen one taken apart nor can I find any pics / exploded diagrams. Are they rebuildable by manufacturer only ? Canton offers a rebuild service.
Re: Accusump Issue ? [Re: Tig] #3124728
02/26/23 10:32 AM
02/26/23 10:32 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My end caps are threaded on. I don't see them just popping off.
Re: Accusump Issue ? [Re: Al_Alguire] #3124751
02/26/23 11:54 AM
02/26/23 11:54 AM
gregsdart Offline
gregsdart  Offline
I went to a ball valve and control rod/cable . No failures now .
Re: Accusump Issue ? [Re: gregsdart] #3124763
02/26/23 12:19 PM
02/26/23 12:19 PM
PA
moparacer Offline
moparacer  Offline
PA
I have a moroso 3 quart with electric valve that I have ran on my cars literally for 23 years without a problem.
The way the moroso electric valve is built, I don't see how it could ever fail to cause a leak unless the bolts that connect the 2 halves worked loose. I cant see how anyone could ever screw up those snap rings or grooves either. But where there's a will, there's a way I guess....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Accusump Issue ? [Re: moparacer] #3124781
02/26/23 01:31 PM
02/26/23 01:31 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
John and Justin are two really nice guys.
Glad they were not hurt.
Re: Accusump Issue ? [Re: 6PKRTSE] #3124794
02/26/23 02:25 PM
02/26/23 02:25 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
I don't know the brand or if anyone besides Accusump manufactures these, but something went terribly wrong with this one. Thankfully the pilot was landing when this occurred..Could have been real bad!
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Accusump Issue ? [Re: U code RR] #3124796
02/26/23 02:33 PM
02/26/23 02:33 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Wow, looks like where the clamp was mounted near the end and at the thinnest portion near threads all the vibration from the plane wore through the housing body.
