Poll for brake guys - NOS caliper opinion UPDATE/photos #312322
05/08/09 11:45 PM
05/08/09 11:45 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
Intelligent people can disagree.
My buddy and I do not share the same opinion on a pair of NOS F body calipers. The calipers are obviously unused, and the brake inlet is still capped. Take the cap off, and all looks pristine down the hole. There is some shelf rash and very light surface rusting. Dust boots are soft and intact. Nothing scary in the visual inspection.
The problem? Neither piston will budge upon application of compressed air with a rubber-tipped snozzle.
Person A: This is not good. These calipers are stuck. 2.75 inch piston diameter means 6 square inches of surface area (Pi are ROUND, Cornbread are square), which at 120psi air pressure means they won't budge with over 700 pounds of force. We need to get them apart, inspect them, and likely rebuild them.
Person B: Nice math, Archimedes. So how do you suggest we get the pistons UNstuck?
Person A: Well, as any professional knows, you hook them up to the vehicle's brake lines, bleed them, and then use the M.C.'s pressure advantange to get them pumped out.
Person B: So, we'll go to the trouble of doing all that, without even seeing if, once they get unstuck, they even hold pressure? Why don't we just do all that, but see if they hold pressure, can be pushed back, etc., BEFORE we tear them down.
Person A: But they're STUCK now. That means there's something wrong.
Person B: But if they free up, and don't leak...?
Person A: They are a problem waiting to happen.
Are you person A or B in this case?
Please vote
single choice
Votes accepted starting: 05/08/09 10:37 PM
You must vote before you can view the results of this poll.
Down to just a blue car now.
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312323
05/09/09 12:01 AM
05/09/09 12:01 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pulling the pistons out & visually inspecting them takes ten minutes per side.. If they look good you lost ten minutes, you can probably reuse the seals... If theres a problem I'd rather find it on the bench than on the road...
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312324
05/09/09 12:11 AM
05/09/09 12:11 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Spray a liberal amount of Kroil in the brake line hole and let it sit overnight with the piston side down so the Kroil flows around the piston. It will dissolve the rust and free the piston. Rinse it out with brake fluid after.
http://www.kanolabs.com/google/ <- Killer deal!
http://www.kanolabs.com/ <- Kroil info
Re: Poll for brake guys - NOS caliper opinion [Re: 1_WILD_RT] #312325
05/09/09 12:12 AM
05/09/09 12:12 AM
k.i.s.s. Open them up & see what you see. Seal and boot kits for them are dirt cheap and a visual inspection will uncover most all issues & yes I did vote.
Re: Poll for brake guys - NOS caliper opinion [Re: RapidRobert] #312326
05/09/09 12:18 AM
05/09/09 12:18 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I voted too,,, but I forgot the question....
I am truckless..
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312327
05/09/09 12:25 AM
05/09/09 12:25 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I voted but don't see option C , use them as cores for a WORKING rebuilt set ???
Re: Poll for brake guys - NOS caliper opinion [Re: JohnRR] #312328
05/09/09 08:13 AM
05/09/09 08:13 AM
Az
Crizila Offline
Crizila  Offline
Az
They will most likely be pitted to a point that no ammount of clean-up will save them. Cores got my vote. They're a dime a dozen!
Fastest 300
Re: Poll for brake guys - NOS caliper opinion [Re: Crizila] #312329
05/09/09 09:50 AM
05/09/09 09:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Let's see, last F body was buit in what? 81?
It's 2009, do math, that's 18 years.
Bet the rubber is bad. Might look ok but I would rebuild them anyway, ever hear of dryrot?
Don't be the exception.
Re: Poll for brake guys - NOS caliper opinion [Re: Supercuda] #312330
05/09/09 11:49 AM
05/09/09 11:49 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Go back to school.. Your math skills stink.. But your caliper knowledge is better..
Re: Poll for brake guys - NOS caliper opinion [Re: 1_WILD_RT] #312331
05/09/09 12:49 PM
05/09/09 12:49 PM
U.S.S.A.
U.S.S.A.
Re: Poll for brake guys - NOS caliper opinion [Re: JohnRR] #312332
05/10/09 06:43 PM
05/10/09 06:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Sorry, I don't remember the 90's
29 years, lol
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312333
05/10/09 09:09 PM
05/10/09 09:09 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
Update:
Person A: SEE! Only 30% of the poll respondants (after you take away the seed vote YOUR way), and none of the comments said go with them.
Person B: Yeah, but they're your Internet buddies, so of course they're going to support your position.
Person A: Not true. Nobody knew which position was mine. Besides, I know exactly ONE of the respondents personally, and most of them would rather bust my chops than come to my support.
Person B: Okay, let's tear them down and have a look.
So, we did. As it turns out, the quote below best describes the outcome (except his prediction on the speed at which two old guys and their beers can work):
Photo number one is BEFORE:
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312334
05/10/09 09:11 PM
05/10/09 09:11 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
With 20-20 hindsight, I suppose they would have been good to go, once they freed up.
BUT we both sleep easier after investing the time.
Photo number 2 is immediately upon teardown, with no cleaning at all:
Re: Poll for brake guys - NOS caliper opinion [Re: 68HemiB] #312335
05/10/09 09:13 PM
05/10/09 09:13 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
The seals were supple and good as is.
Thanks to everyone who took the time to vote and/or comment.
Photo number final is a representative glimpse of the caliper innards, after a simple wipe with a clean rag:
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: 68HemiB] #312336
05/10/09 09:38 PM
05/10/09 09:38 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I see you have the nice green plastic pistons that swell up and stick in the bores. Mopar had a big problem with those and our new `76 new yorker was off the road for a week or so with seized brakes waiting on chrysler to replace the calipers. They couldn`t get the parts so I took the car back and sanded the plastic junk pistons down to the correct size.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: gamagoat6x6] #312337
05/10/09 09:53 PM
05/10/09 09:53 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
Hmmmmmmmmm. More info, if you please.
Was there a TSB?
I will say that the tolerances seemed awfully tight...
Are you saying that all phenolic pistons are junk or just the original ones or just certain part numbers or certain batches or the caliper bores were undersize or what?
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: 68HemiB] #312338
05/10/09 10:26 PM
05/10/09 10:26 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
I've had several problems with the phenolic pistons also..they get stuck!
Metal pistons for Me.
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: 68HemiB] #312339
05/10/09 10:27 PM
05/10/09 10:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
While I personally am not a fan of phenolic brake pistons, auto manufacturers continue to use them in heavy duty applications such as Police Package vehicles... They have always had a higher occurance of sticking in calipers than steel pistons...And everytime I've taken one apart it seemed to have deposits on the sides of the piston... FWIW Glad the calipers looked good, sorry I wasted your time But at least it won't cause you to lose any sleep...
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: 1_WILD_RT] #312340
05/10/09 11:06 PM
05/10/09 11:06 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
No wasting of time - friends and tinkering... it's all good.
I have lead a sheltered life I guess, with little reason to fear phenolic pistons (not that I've ever personally run them). With the rep of low heat transfer and use in HD applications, I thought it would be a good upgrade for my buddy. Now, there's another reason to lose sleep.
How abouts another vote...
If these calipers were on your car, would you
single choice
Votes accepted starting: 05/10/09 10:05 PM
Re: Poll for brake guys - NOS caliper opinion UPDATE/photos [Re: 68HemiB] #312341
05/10/09 11:12 PM
05/10/09 11:12 PM
Oh no not another poll
