return or deadhead
#3121868
02/15/23 09:09 PM
02/15/23 09:09 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
hi guys, carburetor guys carburetor guys let’s talk fuel systems. What are most of you guys running return system or are you dead heading please share car and ETs. Motor etc.
Re: return or deadhead
[Re: CMcAllister]
#3121873
02/15/23 09:35 PM
02/15/23 09:35 PM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
68 Dart .. 527 hp small block runs 10.90s - Product Engineering pump and filter combo ....return is on the pump returns thru -8 hose back to the cell ..-10 line from pump to regulator in front of car .. have been as fast as 10.40 with this pump set up but with a different motor
[Re: rebel]
#3121910
02/15/23 11:20 PM
02/15/23 11:20 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Single 4bbl on a deadhead. Using a Magnafuel pump with a bypass at the pump. Running 8.9s on pumpgas. Similar, but with dual 4 bbl and mine is an Aeromotive 3000 pump with the bypass and filter at the pump. Also street car on pump gas.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DusterKid]
#3121956
02/16/23 09:23 AM
02/16/23 09:23 AM
Posts: 4,457 Washington
madscientist
Washington
Return. I can’t think of a reason to not use a return line, but Shilo says his is a dead head system and his stuff runs…well…FREAKING HARD.
[Re: madscientist]
#3121964
02/16/23 09:59 AM
02/16/23 09:59 AM
Posts: 2,933 A shed in England
Tig
A shed in England
MagnaFuel 500 2 x -10 pick up with -8 return at the pump. -12 to the reg (Aeromotive) and -8 to the 2 x 4 Dominators. Overkill for the fuel system but I was chasing a fueling issue (top end lean out) at the time and upsized all the fuel lines. The fueling system turned out not to be the issue but according to the data it helped
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: RAY1969CARS]
#3121965
02/16/23 10:02 AM
02/16/23 10:02 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
For several years I ran a simple deadhead system on my cuda using the little Aeromotive street rod 11203 pump and a -8 feed line. Ran 9.50s at 140+ mph at 3800 lbs. pump gas and all motor. I upgraded to the Aeromotive A1000 pump using a -10 feed and -8 return. It ran no faster, but I didn't expect it to. I went w/ the return system to help vapor lock issues on the street...and it helped greatly. Still using the same system feeding both the motor and the nitrous system well into the 8 sec range. Using a stock tank w/ a welded on sump. Two -10 feed lines Y'd at the pre-pump filter inlet. The return is plumbed into the stock pickup tube.
[Re: an8sec70cuda]
#3121975
02/16/23 11:11 AM
02/16/23 11:11 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
For several years I ran a simple deadhead system on my cuda using the little Aeromotive street rod 11203 pump and a -8 feed line. Ran 9.50s at 140+ mph at 3800 lbs. pump gas and all motor. I upgraded to the Aeromotive A1000 pump using a -10 feed and -8 return. It ran no faster, but I didn't expect it to. I went w/ the return system to help vapor lock issues on the street...and it helped greatly. Still using the same system feeding both the motor and the nitrous system well into the 8 sec range. Using a stock tank w/ a welded on sump. Two -10 feed lines Y'd at the pre-pump filter inlet. The return is plumbed into the stock pickup tube. how long would it take for it to vapor lock?
[Re: RAY1969CARS]
#3121982
02/16/23 11:30 AM
02/16/23 11:30 AM
an8sec70cuda
For several years I ran a simple deadhead system on my cuda using the little Aeromotive street rod 11203 pump and a -8 feed line. Ran 9.50s at 140+ mph at 3800 lbs. pump gas and all motor. I upgraded to the Aeromotive A1000 pump using a -10 feed and -8 return. It ran no faster, but I didn't expect it to. I went w/ the return system to help vapor lock issues on the street...and it helped greatly. Still using the same system feeding both the motor and the nitrous system well into the 8 sec range. Using a stock tank w/ a welded on sump. Two -10 feed lines Y'd at the pre-pump filter inlet. The return is plumbed into the stock pickup tube. how long would it take for it to vapor lock? When you shut the car off after it was hot and then try to restart it. If I got caught in stop and go traffic during the hot summer months it would start doing it also.
[Re: an8sec70cuda]
#3122002
02/16/23 12:15 PM
02/16/23 12:15 PM
Posts: 16,519 On the run…
BloFish
On the run…
Aeromotive pump, with two Aeromotive filters and Aeromotive regulator that is deadheaded. I have a separate Aeromotive regulator designed for a return, but just haven’t felt the need to change it as of yet. 500 stroker with a single carburetor puts out 615hp on the dyno.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3122004
02/16/23 12:25 PM
02/16/23 12:25 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I have a 69 dart with a stock fuel tank, a blue pump, going to a regulator, and I noticed a hammering type sound at the regulator and my AFR gauge would go lean
to give you a more complete picture of the fuel system, which is being switched out today however, I just don’t want to do all this at the same thing occur
It’s a 3/8 sending unit going into the pump, going into a half inch aluminum line that goes to my regulator
The new system I’m putting in is a fuel cell with a -8 line going to the pump going to the 1/2 line. plastic tank
and of course, I’m trying to rethink it and thinking about a return line
however, I know I deadhead system as work for years for most people
[Re: RAY1969CARS]
#3122028
02/16/23 01:28 PM
02/16/23 01:28 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Dead head stuff here on all of the cars. Weldon pumps with bypass to cell from pump set between 27-32 depending on car. All regulated down to 4.8-5lbs at carb. All 4 port Weldon regulators for single carbs. No issues ever with this setup. Been .99x-1.0 60's with this set up. Same stuff we run in the Vette. If its good enough for aerospace industry and Nasa it is good enough for a racecar.
[Re: RAY1969CARS]
#3122029
02/16/23 01:28 PM
02/16/23 01:28 PM
Al_Alguire
Las Vegas
I guess right now I’m not 100% sure if it’s vapor lock or cavitation
Sidenote, this happens when my fuel tank is full How big is your vent?
[Re: Al_Alguire]
#3122047
02/16/23 02:02 PM
02/16/23 02:02 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Stock vent on the tank it is small the size of a vacuum hose
Great point though I’m a pipefitter so you think I would probably think about that I know how important venr line is
