return or deadhead #3121868
02/15/23 09:09 PM
02/15/23 09:09 PM
CA.
RAY1969CARS Offline OP
CA.
hi guys, carburetor guys
carburetor guys let’s talk fuel systems. What are most of you guys running return system or are you dead heading please share car and ETs. Motor etc.
Re: return or deadhead [Re: RAY1969CARS] #3121869
02/15/23 09:17 PM
02/15/23 09:17 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Return now. It just works too nice not to.
Re: return or deadhead [Re: CMcAllister] #3121873
02/15/23 09:35 PM
02/15/23 09:35 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
68 Dart .. 527 hp small block runs 10.90s - Product Engineering pump and filter combo ....return is on the pump returns thru -8 hose back to the cell ..-10 line from pump to regulator in front of car .. have been as fast as 10.40 with this pump set up but with a different motor
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: return or deadhead [Re: 11secdart] #3121881
02/15/23 09:56 PM
02/15/23 09:56 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Single 4bbl on a deadhead. Using a Magnafuel pump with a bypass at the pump. Running 8.9s on pumpgas.
Re: return or deadhead [Re: RAY1969CARS] #3121891
02/15/23 10:20 PM
02/15/23 10:20 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Quick fuel 427 pump 100 micron filter dead head Pro Stock regulator runs fast enough sometimes whistling
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: return or deadhead [Re: rebel] #3121910
02/15/23 11:20 PM
02/15/23 11:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Similar, but with dual 4 bbl and mine is an Aeromotive 3000 pump with the bypass and filter at the pump. Also street car on pump gas.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: return or deadhead [Re: RAY1969CARS] #3121948
02/16/23 08:39 AM
02/16/23 08:39 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
4 cars in the stable, 3 have deadhead and 1 has a return. The 4th had a deadhead system for years but I switched it to a return style last year. Cars run 10.50-11.70s. The reason I switched the one to a return style is to try and see if it would work better with pump gas. 2 cars we run AV gas and 2 we run a mixture of pump gas/race gas. We've had issues with pump gas boiling in carb on a hot day. Since I switched the one car to a return style I ran straight pump gas last year and didn't have any issues with the pump gas boiling. I will eventually be switching the 2nd car over to a return style at some point so we no longer have to mix fuel.
Re: return or deadhead [Re: DusterKid] #3121956
02/16/23 09:23 AM
02/16/23 09:23 AM
Washington
madscientist Offline
Washington
Return. I can’t think of a reason to not use a return line, but Shilo says his is a dead head system and his stuff runs…well…FREAKING HARD.
Re: return or deadhead [Re: madscientist] #3121964
02/16/23 09:59 AM
02/16/23 09:59 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
MagnaFuel 500 2 x -10 pick up with -8 return at the pump. -12 to the reg (Aeromotive) and -8 to the 2 x 4 Dominators. Overkill for the fuel system but I was chasing a fueling issue (top end lean out) at the time and upsized all the fuel lines. The fueling system turned out not to be the issue but according to the data it helped shruggy
Re: return or deadhead [Re: RAY1969CARS] #3121965
02/16/23 10:02 AM
02/16/23 10:02 AM
an8sec70cuda Offline
For several years I ran a simple deadhead system on my cuda using the little Aeromotive street rod 11203 pump and a -8 feed line. Ran 9.50s at 140+ mph at 3800 lbs. pump gas and all motor.
I upgraded to the Aeromotive A1000 pump using a -10 feed and -8 return. It ran no faster, but I didn't expect it to. I went w/ the return system to help vapor lock issues on the street...and it helped greatly. up
Still using the same system feeding both the motor and the nitrous system well into the 8 sec range.
Using a stock tank w/ a welded on sump. Two -10 feed lines Y'd at the pre-pump filter inlet. The return is plumbed into the stock pickup tube.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: return or deadhead [Re: an8sec70cuda] #3121975
02/16/23 11:11 AM
02/16/23 11:11 AM
CA.
CA.
how long would it take for it to vapor lock?
Re: return or deadhead [Re: RAY1969CARS] #3121980
02/16/23 11:28 AM
02/16/23 11:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is proably overkill. Feed is -12 to a Performance Engineering pump. Return to the tank is -8. From the pump a -10 feed line to a (hated by many) Barry Grant 4 port regulator. Four -6 to the carbs. Pump provides 30psi to the front. Regulated down to 5psi. 8.98@150mph, 3340lbs
Doug
Re: return or deadhead [Re: RAY1969CARS] #3121982
02/16/23 11:30 AM
02/16/23 11:30 AM
When you shut the car off after it was hot and then try to restart it. If I got caught in stop and go traffic during the hot summer months it would start doing it also.
CHIP
Re: return or deadhead [Re: an8sec70cuda] #3122002
02/16/23 12:15 PM
02/16/23 12:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Aeromotive pump, with two Aeromotive filters and Aeromotive regulator that is deadheaded. I have a separate Aeromotive regulator designed for a return, but just haven’t felt the need to change it as of yet. 500 stroker with a single carburetor puts out 615hp on the dyno.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: return or deadhead [Re: BloFish] #3122004
02/16/23 12:25 PM
02/16/23 12:25 PM
CA.
CA.
I have a 69 dart with a stock fuel tank, a blue pump, going to a regulator, and I noticed a hammering type sound at the regulator and my AFR gauge would go lean
to give you a more complete picture of the fuel system, which is being switched out today however, I just don’t want to do all this at the same thing occur
It’s a 3/8 sending unit going into the pump, going into a half inch aluminum line that goes to my regulator
The new system I’m putting in is a fuel cell with a -8 line going to the pump going to the 1/2 line. plastic tank
and of course, I’m trying to rethink it and thinking about a return line
however, I know I deadhead system as work for years for most people
Re: return or deadhead [Re: RAY1969CARS] #3122006
02/16/23 12:32 PM
02/16/23 12:32 PM
CA.
CA.
I was also going to suspend this tank over my spare tire in the trunk. I have a question I was going to use 1 inch angle iron, if not larger on the ends and flat stock in the center to hold the straps what would you think would be the best aluminum or steel??? also will one or the other past tech?
Re: return or deadhead [Re: RAY1969CARS] #3122009
02/16/23 12:42 PM
02/16/23 12:42 PM
CA.
CA.
I guess right now I’m not 100% sure if it’s vapor lock or cavitation
Sidenote, this happens when my fuel tank is full
Re: return or deadhead [Re: RAY1969CARS] #3122028
02/16/23 01:28 PM
02/16/23 01:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dead head stuff here on all of the cars. Weldon pumps with bypass to cell from pump set between 27-32 depending on car. All regulated down to 4.8-5lbs at carb. All 4 port Weldon regulators for single carbs. No issues ever with this setup. Been .99x-1.0 60's with this set up. Same stuff we run in the Vette. If its good enough for aerospace industry and Nasa it is good enough for a racecar.
Re: return or deadhead [Re: RAY1969CARS] #3122029
02/16/23 01:28 PM
02/16/23 01:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
How big is your vent?
Re: return or deadhead [Re: Al_Alguire] #3122047
02/16/23 02:02 PM
02/16/23 02:02 PM
CA.
CA.
Stock vent on the tank it is small the size of a vacuum hose
Great point though I’m a pipefitter so you think I would probably think about that
I know how important venr line is
