2013 caravan won't start unless it is jumped #3120520
02/10/23 06:00 PM
02/10/23 06:00 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
my van will crank fine but will not start. the battery has 12.4 volts when not running. I cleaned the terminals. The only way it will start is if I hook up the battery charger and set it to 200 amps on high. then it fires right up and keeps running even after charger is removed. once running the battery charges at 14v . I even tried a new battery and it still wouldnt start unless jumped with the charger.
Re: 2013 caravan won't start unless it is jumped [Re: dirt] #3120543
02/10/23 07:41 PM
02/10/23 07:41 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
You need to do a starter draw test to see how many amps the starter is drawing,it could be the starter on its way out,just guessing i would think any draw when cranking,should be less than300amps.
Re: 2013 caravan won't start unless it is jumped [Re: GarageDodge] #3120567
02/10/23 09:35 PM
02/10/23 09:35 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
New as in NEW, or just a different battery. What's more important then "static" battery voltage, is the voltage while cranking.
They may show 12.5v while static, but could drop down severely when any load is applied.
If you have a known GOOD battery, & still the same, then comment about starter could be pertinent.
Re: 2013 caravan won't start unless it is jumped [Re: PhillyRag] #3120568
02/10/23 09:44 PM
02/10/23 09:44 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Originally Posted by PhillyRag
Quote
Exactly. iagree
Re: 2013 caravan won't start unless it is jumped [Re: PhillyRag] #3120571
02/10/23 09:53 PM
02/10/23 09:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
I got stung by this last summer on our Kubota, Started fine and was mowing, Jumped off to move a branch without disengaging the deck. Lights would light etc. but no start. chased my tail for 4 or 5 hours, and it was the flippin battery. spank spank spank
Re: 2013 caravan won't start unless it is jumped [Re: PhillyRag] #3120585
02/10/23 10:34 PM
02/10/23 10:34 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I got a brand new battery 12.6V, and it cranked fine but would not start. I charged the new battery up to 12.9 volts and it fired right up. The strange thing is I have 2 , 2013 grand caravans. the old battery works in one van but not the other. Another weird thing is that when I jump started it and it started, It would only rev to exactly 3000 rpm. but after i let it run half an hour and charge the new battery up to 12.9v I could rev it up way over 3000 rpm.
I dont think my multi meter will test how many amps the starter is drawing.
Re: 2013 caravan won't start unless it is jumped [Re: dirt] #3120593
02/10/23 11:08 PM
02/10/23 11:08 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
You've gone online, asked the questions, and got good answers. Now take the vehicle to a local chain that will test the starter for free( I see autozone is 15 mins from you) and go from there... Let us know what they tell you..
Re: 2013 caravan won't start unless it is jumped [Re: moparjim79] #3120606
02/11/23 02:21 AM
02/11/23 02:21 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Question about CCA when your vehicle has two batteries? I still have my E350 van with a 6.9 L (International) Ford diesel that came with two batteries. The two batteries that are in it now are 850 CCA batteries so when I start it does that mean I have 1700 CCA available if needed? If so then does that mean when the OP says he can only start it with a jump that he is combining, let's say two 700 CCA batteries, and he's using or needs up to 1400 CCA's to get it to start. Wow that would mean the starter is really drawing some amperage and might be the problem as someone and some have noted. Can Auto Zone check how much draw during starting the OP's Caravan has?
Mike
Re: 2013 caravan won't start unless it is jumped [Re: GarageDodge] #3120651
02/11/23 12:20 PM
02/11/23 12:20 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Advance AP has a tester that checks the battery w/o load, starting and running, charging also. Stop by one of them. I'd think the other stores would but don't work at them
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 2013 caravan won't start unless it is jumped [Re: A12] #3120673
02/11/23 01:23 PM
02/11/23 01:23 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Mike
Yes, autozone has an all in one testing cart that prints out all of the tests and results.
Re: 2013 caravan won't start unless it is jumped [Re: dirt] #3120678
02/11/23 01:32 PM
02/11/23 01:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
The ignition system is what fires the spark plug, correct?
t sounds like one of the circuits, components, in the ignition system has a component that is not working below 12.5 V twocents
I would look closely at all the grounds, make sure they are really good wrench, and then start by replacing the ignition ballast resistor first, the coil next and then the ECU shruggy
Can you have someone help you by sitting in the car and have them do the starting while you use a voltmeter to check the voltage to both sides of the ballast resistor with the starter spinning the motor over and then check the voltage to the coil and last to the ECU scope wrench
Murphy loves messing with us hot rodders rant shruggy
Re: 2013 caravan won't start unless it is jumped [Re: moparjim79] #3120679
02/11/23 01:36 PM
02/11/23 01:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree if it all tests good you have a deeper rooted issue like a ground problem or component that is requiring extra V/I to function
keep us posted beer
Re: 2013 caravan won't start unless it is jumped [Re: GarageDodge] #3120686
02/11/23 01:54 PM
02/11/23 01:54 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I went to autozone and they tested the starter. They said it was fine but could not tell me how many amps it was drawing. With the starter cranking the battery reads a little less than 12v.
Re: 2013 caravan won't start unless it is jumped [Re: dirt] #3120702
02/11/23 03:10 PM
02/11/23 03:10 PM
moparx Offline
moparx  Offline
grounds, grounds, grounds.
the next place i would look, is at the battery cables themselves. the newer vehicles have really cheaped out on cable ends, and "green death" is commonly found, starting where the cable is terminated to the end.
if any "green death" is found on either cable, trace it to see how far up the cable it goes. you will most likely find the cable[s] need replaced.
another place to examine closely on these minivans, is the fuse and relay box by the battery.
as the battery outgasses, many times the gasses start to corrode the connections in that box, as well as any wiring around the battery itself.
chasing wiring issues can be challenging to say the least. [right now, i am trying to figure out why the door locks on my "bus" won't lock or unlock using the door switches, yet the 'rolling lock' feature works. i am getting balder by the second chasing this issue, even using the factory diagnostic manual. runaway]
please keep us informed as to how this progresses, and what you find.
beer
Re: 2013 caravan won't start unless it is jumped [Re: moparx] #3120711
02/11/23 04:07 PM
02/11/23 04:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
GREEN DEATH
laugh2 mad Funny but not so funny when it happens to you DAMHIK with a 90's German car I just had to replace the entire upper engine wiring harness. They are no longer available so used non-eco harnesses are going for upwards of $1500 mad Engine heat destroys the insulation and it just flakes off. Who the he77 thought eco (soy based) insulation was a good idea??? Sorry for the OT rant.
Re: 2013 caravan won't start unless it is jumped [Re: A12] #3120716
02/11/23 04:45 PM
02/11/23 04:45 PM
moparx Offline
moparx  Offline
i perfectly understand your rant !
although i have no german car experience, [not much foreign experience really, but enough to be dangerous. biggrin] i have loads of experience with the "green death"........... panic
it's NOT any fun.
beer
Re: 2013 caravan won't start unless it is jumped [Re: moparx] #3120718
02/11/23 04:51 PM
02/11/23 04:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
, shock mad
Re: 2013 caravan won't start unless it is jumped [Re: A12] #3120720
02/11/23 04:52 PM
02/11/23 04:52 PM
moparx Offline
moparx  Offline
OH YEAH ! up boogie fan
beer
Re: 2013 caravan won't start unless it is jumped [Re: moparx] #3120722
02/11/23 04:59 PM
02/11/23 04:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Before this a rodent (groundhog) chewed through two spark plug wires and all of the wires on both the upstream and downstream O2 sensors on my wife's Chrysler Town & Country and not knowing this until I started it, it shorted and took out the PCM/ECU. This took lots of $$$$ to replace all of those components as they don't sell just two spark plug wires and the PCM/ECU was several hundred dollars and on top of that the upstream O2 sensor exhaust manifold threads were damaged when I removed that sensor.
Re: 2013 caravan won't start unless it is jumped [Re: A12] #3120794
02/11/23 10:50 PM
02/11/23 10:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
IF you had comprehensive that could be an insurance claim beer
