2013 caravan won't start unless it is jumped
#3120520
02/10/23 06:00 PM
02/10/23 06:00 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
my van will crank fine but will not start. the battery has 12.4 volts when not running. I cleaned the terminals. The only way it will start is if I hook up the battery charger and set it to 200 amps on high. then it fires right up and keeps running even after charger is removed. once running the battery charges at 14v . I even tried a new battery and it still wouldnt start unless jumped with the charger.
Re: 2013 caravan won't start unless it is jumped
[Re: GarageDodge]
#3120567
02/10/23 09:35 PM
02/10/23 09:35 PM
Posts: 1,754 Phila
PhillyRag
Phila
I even tried a new battery and it still wouldnt start unless jumped with the charger. New as in NEW, or just a different battery. What's more important then "static" battery voltage, is the voltage while cranking. They may show 12.5v while static, but could drop down severely when any load is applied. If you have a known GOOD battery, & still the same, then comment about starter could be pertinent.
[Re: PhillyRag]
#3120568
02/10/23 09:44 PM
02/10/23 09:44 PM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
I even tried a new battery and it still wouldnt start unless jumped with the charger. New as in NEW, or just a different battery. What's more important then "static" battery voltage, is the voltage while cranking. They may show 12.5v while static, but could drop down severely when any load is applied. If you have a known GOOD battery, & still the same, then comment about starter could be pertinent. Exactly.
[Re: PhillyRag]
#3120571
02/10/23 09:53 PM
02/10/23 09:53 PM
Posts: 15,343 Omaha Ne
TJP
Omaha Ne
I even tried a new battery and it still wouldnt start unless jumped with the charger. New as in NEW, or just a different battery. What's more important then "static" battery voltage, is the voltage while cranking. They may show 12.5v while static, but could drop down severely when any load is applied. If you have a known GOOD battery, & still the same, then comment about starter could be pertinent. I got stung by this last summer on our Kubota, Started fine and was mowing, Jumped off to move a branch without disengaging the deck. Lights would light etc. but no start. chased my tail for 4 or 5 hours, and it was the flippin battery.
[Re: dirt]
#3120593
02/10/23 11:08 PM
02/10/23 11:08 PM
Posts: 1,404 Central Pa
moparjim79
Central Pa
I got a brand new battery 12.6V, and it cranked fine but would not start. I charged the new battery up to 12.9 volts and it fired right up. The strange thing is I have 2 , 2013 grand caravans. the old battery works in one van but not the other. Another weird thing is that when I jump started it and it started, It would only rev to exactly 3000 rpm. but after i let it run half an hour and charge the new battery up to 12.9v I could rev it up way over 3000 rpm. I dont think my multi meter will test how many amps the starter is drawing. You've gone online, asked the questions, and got good answers. Now take the vehicle to a local chain that will test the starter for free( I see autozone is 15 mins from you) and go from there... Let us know what they tell you..
[Re: GarageDodge]
#3120651
02/11/23 12:20 PM
02/11/23 12:20 PM
Posts: 10,643 S.E.Ohio
Magnumguy
S.E.Ohio
You need to do a starter draw test to see how many amps the starter is drawing,it could be the starter on its way out,just guessing i would think any draw when cranking,should be less than300amps. Advance AP has a tester that checks the battery w/o load, starting and running, charging also. Stop by one of them. I'd think the other stores would but don't work at them
[Re: A12]
#3120673
02/11/23 01:23 PM
02/11/23 01:23 PM
moparjim79
Central Pa
Question about CCA when your vehicle has two batteries? I still have my E350 van with a 6.9 L (International) Ford diesel that came with two batteries. The two batteries that are in it now are 850 CCA batteries so when I start it does that mean I have 1700 CCA available if needed? If so then does that mean when the OP says he can only start it with a jump that he is combining, let's say two 700 CCA batteries, and he's using or needs up to 1400 CCA's to get it to start. Wow that would mean the starter is really drawing some amperage and might be the problem as someone and some have noted. Can Auto Zone check how much draw during starting the OP's Caravan has?
Mike Yes, autozone has an all in one testing cart that prints out all of the tests and results.
[Re: dirt]
#3120678
02/11/23 01:32 PM
02/11/23 01:32 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The ignition system is what fires the spark plug, correct? t sounds like one of the circuits, components, in the ignition system has a component that is not working below 12.5 V I would look closely at all the grounds, make sure they are really good , and then start by replacing the ignition ballast resistor first, the coil next and then the ECU Can you have someone help you by sitting in the car and have them do the starting while you use a voltmeter to check the voltage to both sides of the ballast resistor with the starter spinning the motor over and then check the voltage to the coil and last to the ECU Murphy loves messing with us hot rodders
[Re: moparjim79]
#3120679
02/11/23 01:36 PM
02/11/23 01:36 PM
TJP
Omaha Ne
I got a brand new battery 12.6V, and it cranked fine but would not start. I charged the new battery up to 12.9 volts and it fired right up. The strange thing is I have 2 , 2013 grand caravans. the old battery works in one van but not the other. Another weird thing is that when I jump started it and it started, It would only rev to exactly 3000 rpm. but after i let it run half an hour and charge the new battery up to 12.9v I could rev it up way over 3000 rpm. I dont think my multi meter will test how many amps the starter is drawing. You've gone online, asked the questions, and got good answers. Now take the vehicle to a local chain that will test the starter for free( I see autozone is 15 mins from you) and go from there... Let us know what they tell you.. if it all tests good you have a deeper rooted issue like a ground problem or component that is requiring extra V/I to function keep us posted
[Re: dirt]
#3120702
02/11/23 03:10 PM
02/11/23 03:10 PM
Posts: 19,383 north of coder
moparx
grounds, grounds, grounds. the next place i would look, is at the battery cables themselves. the newer vehicles have really cheaped out on cable ends, and "green death" is commonly found, starting where the cable is terminated to the end. if any "green death" is found on either cable, trace it to see how far up the cable it goes. you will most likely find the cable[s] need replaced. another place to examine closely on these minivans, is the fuse and relay box by the battery. as the battery outgasses, many times the gasses start to corrode the connections in that box, as well as any wiring around the battery itself. chasing wiring issues can be challenging to say the least. [right now, i am trying to figure out why the door locks on my "bus" won't lock or unlock using the door switches, yet the 'rolling lock' feature works. i am getting balder by the second chasing this issue, even using the factory diagnostic manual. ] please keep us informed as to how this progresses, and what you find.
[Re: A12]
#3120716
02/11/23 04:45 PM
02/11/23 04:45 PM
moparx
i perfectly understand your rant ! although i have no german car experience, [not much foreign experience really, but enough to be dangerous. ] i have loads of experience with the "green death"........... it's NOT any fun.
