Hemi Head Torque #3119657
02/07/23 04:02 PM
02/07/23 04:02 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
For the guys that have Alum heads and block, what do you torque the head studs that go from the head down in the valley?
Re: Hemi Head Torque [Re: 71birdJ68] #3119710
02/07/23 06:36 PM
02/07/23 06:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Same torque. But to do that you need the adapter from the Snap-On man. (Or others.) It is 2" long. So if you put the adapter on your torque wrench (and if it's 20" long) you would torque it to 90%. Assuming the adapter is sticking straight out.
2011 Drag Pak Challenger
Re: Hemi Head Torque [Re: rickseeman] #3119896
02/08/23 11:15 AM
02/08/23 11:15 AM
Morristown Tn.
Morristown Tn.
Ray Barton says 45lbs and ARP says 55lbs, so I'm trying to get a lot of different points of view.
Re: Hemi Head Torque [Re: 71birdJ68] #3120120
02/08/23 11:24 PM
02/08/23 11:24 PM
Missouri
galen Offline
galen  Offline
Missouri
Tim Banning told me the same thing as Ray Barton told you. I asked why. He said so I won't distort the intake valve seat. Tim said 45 to 50ft. lbs.
Re: Hemi Head Torque [Re: galen] #3120126
02/09/23 12:21 AM
02/09/23 12:21 AM
Morristown Tn.
Morristown Tn.
ARP said 55, so I decided to split the difference and do 50.
Re: Hemi Head Torque [Re: 71birdJ68] #3120138
02/09/23 03:33 AM
02/09/23 03:33 AM
55 Ft. lbs. with a two inch long adapter, I use 180 degrees from the stud to tighten the nut and washer on them, not 90 degrees tsk
i'll try and remember to post a picture of that adapter luck
Re: Hemi Head Torque [Re: Cab_Burge] #3120165
02/09/23 08:50 AM
02/09/23 08:50 AM
Morristown Tn.
Morristown Tn.
I don't have to use adapter cause there is room to get the torque wrench on the nut on my block.
Re: Hemi Head Torque [Re: 71birdJ68] #3120337
02/09/23 07:30 PM
02/09/23 07:30 PM
shock work
Pictures please luck
Re: Hemi Head Torque [Re: Cab_Burge] #3120346
02/09/23 08:38 PM
02/09/23 08:38 PM
Morristown Tn.
Morristown Tn.
This
Re: Hemi Head Torque [Re: 71birdJ68] #3120391
02/10/23 02:47 AM
02/10/23 02:47 AM
That sir is a first, shock
Which block are you using?
is it a raised cam race block?
I've never had or worked on one of those confused
Re: Hemi Head Torque [Re: Cab_Burge] #3120427
02/10/23 11:39 AM
02/10/23 11:39 AM
Morristown Tn.
Morristown Tn.
It is a off brand block, the name is HP, but it is a POS, it leaks water into the valley, that is what I'm trying to stop. The boss for those studs have crack in them. Now the torque wrench is a non ratcheting click type that came from the Air Force and it doesn't take up much room. Not a race , or raised cam block. He had a good idea, but didn't know what he was doing, so almost every on of these block were junk. Ray Barton and Tim Banning said that they have pulled their hair out trying to make these things work.
