Re: Hemi Head Torque
[Re: 71birdJ68]
#3119710
02/07/23 06:36 PM
02/07/23 06:36 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Same torque. But to do that you need the adapter from the Snap-On man. (Or others.) It is 2" long. So if you put the adapter on your torque wrench (and if it's 20" long) you would torque it to 90%. Assuming the adapter is sticking straight out.
2011 Drag Pak Challenger
[Re: 71birdJ68]
#3120120
02/08/23 11:24 PM
02/08/23 11:24 PM
Posts: 831 Missouri
galen
Missouri
Tim Banning told me the same thing as Ray Barton told you. I asked why. He said so I won't distort the intake valve seat. Tim said 45 to 50ft. lbs.
[Re: 71birdJ68]
#3120391
02/10/23 02:47 AM
02/10/23 02:47 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
That sir is a first, Which block are you using? is it a raised cam race block? I've never had or worked on one of those
[Re: Cab_Burge]
#3120427
02/10/23 11:39 AM
02/10/23 11:39 AM
Posts: 4,452 Morristown Tn.
71birdJ68
Morristown Tn.
It is a off brand block, the name is HP, but it is a POS, it leaks water into the valley, that is what I'm trying to stop. The boss for those studs have crack in them. Now the torque wrench is a non ratcheting click type that came from the Air Force and it doesn't take up much room. Not a race , or raised cam block. He had a good idea, but didn't know what he was doing, so almost every on of these block were junk. Ray Barton and Tim Banning said that they have pulled their hair out trying to make these things work.
