Re: Old school 340 cam ??s
[Re: cknight]
#3118890
02/04/23 03:54 PM
02/04/23 03:54 PM
Posts: 1,073 oregon
greendart408
oregon
Crane did not make any cast roller cores for the LA engines. A 698851 would be ground on an 8620 carburized steel billet, which is copper colored between the lobes. It’s not copper between the lobes and looks like any ft cam ?
[Re: crackedback]
#3118902
02/04/23 05:03 PM
02/04/23 05:03 PM
Posts: 1,073 oregon
greendart408
oregon
Numbers on the end of the cam? Ba-1852 on the gear side and R-280/427-8 on the front, I will show pics when I can.
[Re: greendart408]
#3118944
02/04/23 10:10 PM
02/04/23 10:10 PM
Posts: 9,456 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Old DC book shows P3690795 R280-427-110 Crane 280 .640 108 Book lists this spring number if you can find the specs for it. P3412068 Probably got the old short crane roller lifters with it?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3118968
02/05/23 12:11 AM
02/05/23 12:11 AM
Posts: 1,073 oregon
greendart408
oregon
Old DC book shows P3690795 R280-427-110 Crane 280 .640 108 Book lists this spring number if you can find the specs for it. P3412068 Probably got the old short crane roller lifters with it? Thanks for the info, I got some crane lifters with it that I’m scared to use by the looks of them. Anyone ran these lol?
[Re: greendart408]
#3118974
02/05/23 12:33 AM
02/05/23 12:33 AM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
A big NO on running them. Myself, I can work with old parts and even cast core roller cams but not those lifters.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3118986
02/05/23 02:22 AM
02/05/23 02:22 AM
Posts: 1,073 oregon
greendart408
oregon
A big NO on running them. Myself, I can work with old parts and even cast core roller cams but not those lifters. 100 percent agreed....
[Re: greendart408]
#3118988
02/05/23 02:32 AM
02/05/23 02:32 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
Old DC book shows P3690795 R280-427-110 Crane 280 .640 108 Book lists this spring number if you can find the specs for it. P3412068 Probably got the old short crane roller lifters with it? Thanks for the info, I got some crane lifters with it that I’m scared to use by the looks of them. Anyone ran these lol? Yepper, years ago. I may have one or two pairs left in my cabinet still The bigger diameter solid roller wheel lifters are well worth converting to
[Re: greendart408]
#3118993
02/05/23 06:40 AM
02/05/23 06:40 AM
Posts: 3,076 Michigan
A727Tflite
Old DC book shows P3690795 R280-427-110 Crane 280 .640 108 Book lists this spring number if you can find the specs for it. P3412068 Probably got the old short crane roller lifters with it? Thanks for the info, I got some crane lifters with it that I’m scared to use by the looks of them. Anyone ran these lol? Those lifters were used well in to the 70’s, in B/RB/Hemi without any issues. We went to the Engles later 70’s. Those springs just keep the guide bars in place.
[Re: greendart408]
#3119751
02/07/23 09:07 PM
02/07/23 09:07 PM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I recently purchased a old school built in 74 340, and not ran since. Trw full domes, crane r280/427, 108. Mopar part number P3690795 Solid roller, block is o ringed. Etc etc, It’s a killer old school build. Anyhow does anyone know what the spring is that cam calls for pressure wise? I can’t find any info. The box of springs that came with it and was ran in the garage only says 475 on the paper work. Unfortunately it’s a cast core it looks like.... I'd map out the events at .200" and post and 'we' can recommend something based on the rocker ratio and rpm etc. It looks like the lifters have been run, they show some signs of 'forking' Cool find anyway!
[Re: HardcoreB]
#3120093
02/08/23 09:44 PM
02/08/23 09:44 PM
Posts: 1,073 oregon
greendart408
oregon
I recently purchased a old school built in 74 340, and not ran since. Trw full domes, crane r280/427, 108. Mopar part number P3690795 Solid roller, block is o ringed. Etc etc, It’s a killer old school build. Anyhow does anyone know what the spring is that cam calls for pressure wise? I can’t find any info. The box of springs that came with it and was ran in the garage only says 475 on the paper work. Unfortunately it’s a cast core it looks like.... I'd map out the events at .200" and post and 'we' can recommend something based on the rocker ratio and rpm etc. It looks like the lifters have been run, they show some signs of 'forking' Cool find anyway! They have been ran in the garage and at 1 sand drag in 1974.
