Re: Factory fast ratio steering boxes
[Re: Hot 340]
#3118686
02/03/23 06:28 PM
02/03/23 06:28 PM
Posts: 4,115 MD
floyd
MD
Original quick ratio steering boxes have a raised βTAβ in the casting. Pic from the web.
Re: Factory fast ratio steering boxes (manual)
[Re: Hot 340]
#3118717
02/03/23 08:18 PM
02/03/23 08:18 PM
Posts: 701 Northern California
lilcuda
Northern California
Sounds like fast ratio box to me. I had a '66 Barracuda that came with a standard ratio manual box, which was close to 5 turns lock to lock. I bought a fast ratio 16:1 manual box and it looked exactly the same on the outside, but it had a little over 3 turns lock to lock.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: lilcuda]
#3118747
02/03/23 10:52 PM
02/03/23 10:52 PM
Posts: 15,418 Omaha Ne
TJP
Omaha Ne
[Re: TJP]
#3118801
02/04/23 08:29 AM
02/04/23 08:29 AM
Posts: 892 MA
steve70
MA
Firm feel sells a kit to convert from the factory 24:1 ratio to a 20:1 or a 16:1. It was very easy to do.
1970 Challenger T/A 4 speed
[Re: Hot 340]
#3118874
02/04/23 02:47 PM
02/04/23 02:47 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
It would have been an upgrade / modification, Chrysler sold assemblies & kits;
[Re: Alaskan_TA]
#3119977
02/08/23 02:38 PM
02/08/23 02:38 PM
Posts: 3,395 Pa
Hot 340
Pa
[Re: floyd]
#3120147
02/09/23 07:16 AM
02/09/23 07:16 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Original quick ratio steering boxes have a raised βTAβ in the casting. Pic from the web. Nope. I ordered a '69 Barracuda with fast steering back in the fall of 1968 and still have it. There's no "TA" on the casting. It does have a green paint daub and some stenciled numbers/letters: "E0919G".
[Re: kentj340]
#3120151
02/09/23 07:24 AM
02/09/23 07:24 AM
kentj340
Cut and Shoot, TX
Here's the original factory green paint daub before restoration.
[Re: kentj340]
#3120237
02/09/23 01:55 PM
02/09/23 01:55 PM
Posts: 12,235 Looking for a way out of Middl...
IMGTX
Original quick ratio steering boxes have a raised βTAβ in the casting. Pic from the web. Nope. I ordered a '69 Barracuda with fast steering back in the fall of 1968 and still have it. There's no "TA" on the casting. It does have a green paint daub and some stenciled numbers/letters: "E0919G". Floyd forgot to put "Power Steering" quick ratio boxes had T/A cast on them. Manual boxes didn't have external marking that I know of but I could be mistaken on that. The standard power steering boxes were 3.5 turns lock to lock. The T/A boxes had modified stops inside to make them 2.5 turns lock to lock. It is still the same turning ratio but the internal stops prevent it from rotating more than 2.5 turns. To make the T/A box power steering cars car turn the wheels to the full amount it also had have the longer pitman arm. Less turns and longer arm made the wheels turn the same angle as the standard power steering boxes. I always felt the T/A boxes were a bandaid approach to faster steering. l think the engineers did the manual boxes correctly by changing the turn ratio and not slapping on a longer pitman arm and limiting the rotations. Kinda hokie,, but I still have one for my Challenger. Good detail on those pics.
