Offset lift shakles #3114181
01/18/23 01:54 PM
01/18/23 01:54 PM
Mobile Al
hemirdrnnr Offline OP
Mobile Al
Does anyone have a source for offset 4" shackle lift kit ? I have a 67 Plymouth Belvedere.
Re: Offset lift shakles [Re: hemirdrnnr] #3114224
01/18/23 04:29 PM
01/18/23 04:29 PM
moparx Offline
moparx  Offline
what are you doing that needs these ?
spring into the inside of the frame rails?
you are looking for a 4" lift using shackles ? if so, that would make them twice as long as the factory ones, which would cause other issues, which in my opinion, would make the car handling an issue.
perhaps an added leaf or two to the spring pack would be a better solution, or having the springs re-arched ?
beer
Re: Offset lift shakles [Re: moparx] #3114285
01/18/23 07:58 PM
01/18/23 07:58 PM
Mobile Al
Mobile Al
I am trying to lift the the back of the car it is to low in my opinion.I had a set years ago and for the life of me can't remember where I got them. Getting old and coming off 2 years of chemo has taken its toll on me. Doesn't have to be 4" just more than stock.
Re: Offset lift shakles [Re: hemirdrnnr] #3114294
01/18/23 08:24 PM
01/18/23 08:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe a Dr Diff relocation kit ?
Mancini & others probably also sell them.
Re: Offset lift shakles [Re: topside] #3114333
01/18/23 10:38 PM
01/18/23 10:38 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I bought my last shackle kit from JC Whitney back in the 70s. Don't know if they are still around or not.
Re: Offset lift shakles [Re: bobby66] #3114340
01/18/23 11:04 PM
01/18/23 11:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
just need some strap steel, preferably a drill press, a couple of drill bits ad long bolts with jam of locking nuts wink
Superior industries is company that used to make them, not sure if the are still around shruggy
SUMMIT HAS SEVERAL OPTIONS
ADVANCE AUTO PARTS
or GOOGLE "Leaf spring Shackle kits" and go to Images.
Good luck on your continued recovery up
Re: Offset lift shakles [Re: TJP] #3114443
01/19/23 11:09 AM
01/19/23 11:09 AM
Mobile Al
Mobile Al
I think I found what I needed at Springs And Things "Great people to deal with". Thanks for the recovery thoughts LOL. Thanks everyone for the help and replies.
Re: Offset lift shakles [Re: hemirdrnnr] #3114529
01/19/23 04:06 PM
01/19/23 04:06 PM
moparx Offline
moparx  Offline
one tip for using longer than stock shackles, taken from off road use.
after the length is decided upon, drill a hole in the middle of the shackle and add a spacer the width of the distance when the shackles are tightened. this will add strength, as well as some stability. this spacer can also be welded in place.
as has been already suggested, if one has some strap steel [1/4 x 1 1/2 or 2"] and a drill press, these can be easily fabricated to your liking.
however, one thing that hasn't been mentioned. after getting so long, these seem to impart extra stress on the rear of the spring, causing the main and second leaves to bend downward.
i saw this 60 years or so ago, and i see this today, when using super long shackles.
beer
Re: Offset lift shakles [Re: moparx] #3114629
01/19/23 08:20 PM
01/19/23 08:20 PM
Mobile Al
Mobile Al
Thanks again !
Re: Offset lift shakles [Re: hemirdrnnr] #3114675
01/19/23 10:48 PM
01/19/23 10:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
yes they are. Didn't even think about Laura, the lady knows here stuff and sells QUALITY Springs wink
Re: Offset lift shakles [Re: TJP] #3114876
01/20/23 02:19 PM
01/20/23 02:19 PM
moparx Offline
moparx  Offline
yes they are. Didn't even think about Laura, the lady knows here stuff and sells QULITY Springs wink
"QULITY" springs ? does she knit them ? biggrin
HAHAHAHA !!!!!!!!! i know you meant "QUALITY" springs, but i couldn't resist.......... laugh2
beer
Re: Offset lift shakles [Re: moparx] #3114995
01/20/23 09:49 PM
01/20/23 09:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
My keyboards wering out from responding to too mny useless posts LOL
spank
Re: Offset lift shakles [Re: TJP] #3115360
01/22/23 10:49 AM
01/22/23 10:49 AM
Mobile Al
Mobile Al
The car does ride soft and smooth !
